Question about HP PSC 1610 All-In-One InkJet Printer
Connection problem My computer is no longer recognizing the printer and I can't get it to print anything. I have an HP media center computer with windows XP. Please help me fix this issue as soon as possible.
    Novelist:
    Scholar:
  • 111 Answers
Check and make sure that all of the cables are firmly connected including the printer's power cable and the cable that connects the printer and your computer. Cables can seem connected but occasionally, they can work their way loose just enough to interrupt the contact.
Check the cables to make sure they aren't damaged. It's pretty common for a cable to become damaged if a chair with wheels has rolled over it a time or two. That would be enough to interrupt the connection between the computer and the printer. If it looks like you have a damaged cable, you'll have to replace it.
If the cables are well connected and undamaged and the printer is turned on, try rebooting the computer, then see if it will recognize the printer.
If those steps don't work, you'll probably need to uninstall and reinstall the printer software and drivers. It would be ideal if you had the original CD with the printer software on it, but those disks usually get lost over time.
The HP web site has a page that describes how to uninstall your printer's software:
Uninstalling Your Printer Software in Windows
If you don't have the original software disk, you can download the necessary software from HP's site:
Drivers and Software
I didn't find a web page that provided the specific instructions for reinstalling the printer, but you can download the user's manual from the site:
Printer User Manual page
I hope the solution is a relatively simple one, but if it comes to uninstalling and reinstalling the printer, it is a "do-able" task.
Post back your results and let everyone know which solution worked for you. Good luck.
Posted on Oct 07, 2008
Lost ip/connection on Dell 1720dn
try resetting the "print spooler"
  1. start
  2. control panel
  3. admin. tools
  4. computer management
  5. services and applications
  6. services
  7. scroll down till you see "print spooler"
  8. left click once
  9. "restart"
Jan 06, 2010 | Dell 1720dn Laser Printer
My printer will no longer print after using CCleaner. I've tried to use the starter CD uninstalling and re-installing and to my dismay printer still does not print documents. Also, when I tried opening...
It is possible that Ccleaner somehow deleted temporary files or that your drivers were installed into a temporary folder the Ccleaner cleans. you need to go to HP's acutal website click on download drivers, select printers and multifunction, select your printer model, download the host based drivers, then install them. Delete your printers current profile in the printer floder of your control panel so plug and play will recognize it as a new printer. reboot your computer. when you computer has started up again, plug in the printer and select "have disk, or specify location" during the installation and select the newly installed HP drivers, that should properly install the new drivers into a permanat location that ccleaner won't access
Aug 25, 2009 | Office Equipment & Supplies
The printer won't open the printer connection.
Most printers do not open a connection. Computers open the connection. Has something changed from the way it worked before? Go to Control panel......printers and other hardware.......printers, to find out if the printer is recognized by the computer. If not, click on "add a printer". If it is recognized, you should be able to print. Put a few words on Wordpad, and click on "print".
Aug 21, 2009 | HP Photosmart C3180 All-In-One InkJet...
Problems with HP Photosmart C6280 All-in-one Printer
Populate the destination list You must populate the destination list in HP Solution Center for the Scan To function to work. Follow these steps to populate the destination list.
NOTE: HP Solution Center is the software that came with the product. You must make sure the software is installed on the computer for all the product functions to work correctly. The software is also necessary for completing this procedure. Install HP Solution Center if it is not already installed.
  1. On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center . HP Solution Center opens.
  2. Click Scan Settings .
  3. Click Scan to... Setup .
    NOTE: It might take several minutes for the list to populate. If the appropriate programs are already listed as scan destinations, discontinue this procedure. You must reinstall the software.
  4. Click each program to include on the Scan To Destination list. Figure 2: Add destinations c01404190.gif
  5. Click the Add arrow. The program listing moves from the left side of the screen to the right.
  6. Click OK .
Jun 23, 2009 | HP Photosmart C6280 Printer
Scanner Error - Power On > Power Off
1) Unplug any connection to your computer from this device (usb wire, scsi, cat-5 cable)
2) uninstalling the drivers from the hardware menu
3) reboot your PC
4) confirm the printer is no longer installed on your PC by going to the printers section of your control panel.
5) Follow the installation proceedure ducumented for your printer.
6) restart your PC if requested, if not go to step 7
7) test that you can print to your printer.
If there are still errors, contact HP and describe your issue in full detail.
May 29, 2009 | HP LaserJet 3380 All-In-One Printer
Will not print anything?
Check the cartridges first
Try doing this
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Jan 28, 2009 | HP Deskjet D4260 Printer
HP Photosmart Printer, Mac won't recognize with USB
Sounds like their is not communications between your printer and computer. Could be a bad USB cable - swap out and see if that fixes it. If not it could be a faulty USB port on the computer or printer. You can check the computer USB port by connecting another device, but there is no way to check the HP's USB port. I would also check printer USB port for dust bunnies! If you're not able to resolve, I think it is time for another printer.
Jan 07, 2009 | HP Photosmart 8050 InkJet Printer
Samsung CLX-3160FN won't print from my HP Pavilion Media Center M7467C
I have a brand new HP pavilion, but it wont print from my HP deskjet. If i am lucky i get the first p[age and a couple of lines on page 2. My new laptop (ACER) is quite happy to print using the same cable. printer etc. Conclusion...HP pav is defective. Am I wrong?
May 01, 2008 | Samsung CLX 3160fn All-In-One Printer
HP PSC 1610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
