Question about Danby DWC283BLS Wine Cooler
Wont cool! We just moved in this home which has the wine cooler; it wont cool and I unplugged it for 2 hours 2 times. It would start the cooling process and would go from 84 to 82 and after 10 minutes or so, I suppose the cool air stopped coming. Any easy solutions (dumb question). The previous owners had it fixed to the cabinets and it will be a bear to break it up and take it out. hankq@hotmail.com
  • guptarameshr Sep 17, 2008
    what will be expense of compressor refrigerant ( R134A ) filling 75 gm in 285 litre Electrolux fridge
  • 126 Answers
UNFORTANETLY YOU NEED IT REPAIRED BY A TECH AS THERE IS NO HOME REMEDY FOR THAT PROBLEM.YOU MIGHT HAVE A FAULTY COMPRESSOR (MOTOR) OR A GAS LEAK.LET ME NO IF YOU NEED FUTHER ASSISTANCE ALSO THE VENTALATION COULD CAUSE IT AS YOU SAY THAT IT IS BUILT INTO THE CABINITS SO REMOVE IT AND TRY IT BEFORE YOU CALL A TECH.GOODLUCK.MOHAMED
Posted on Sep 17, 2008
  • MOHAMED UZAIL ESSACK
    MOHAMED UZAIL ESSACK Sep 18, 2008
    the cost of filling the refrigarent depends on you tech its difficult for me to advise you as im not sure which country you are from.mohamed
Everstar hdwc35
Do you still have your Franklin HDWC35 wine cooler?
Feb 08, 2014 | Furniture
Wine cooler cools but it does not turn on again . need to unplug and plug again ,but in doing so I erase settings thank you
Possible that the error is in the main program controller unit of the coolerr. It might be hanging up due to some errors in the voltage or the sensors.
make sure the connections are tight , check the thermostat settings, reduce to lower level, allow the unit to cool off , unplug for few hours and check again. if not check your program controller unit.
Oct 26, 2010 | Haier BC112G Wine Cooler
Moved cooler and wont restart
try leaving unplugged for a couple hours then plug back in
May 18, 2010 | Avanti EWC28 Wine Cooler
Moving a Eurocave wine cooler laying flat
the reason you should not lay a fridge/freezer on its side is that you will get air bubbles in the cooling pipes,which you may not be able to get rid of when you turn it back upright.I have moved loads of f/f, in the past and have had no problems,as long as you give the unit at least 24 hours to right itself.....and keep the door(s) closed while it is "resting"
Apr 17, 2010 | EuroCave Comfort 260 Collector's Package...
Vinotemp VT-16TEDS has light on but doesn't cool
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Does not cool. Compressor Hot
Sounds like the compressor starting relay. This should be available from from most appliance parts retailers that carry refrigeration parts. It is probably a plug-in relay which is easy to replace. PULL THE PLUG UNTIL YOU GET IT! Constant cycling on the thermal protector will damage the unit.
Ray
Oct 19, 2008 | GE PWR04FANBB Wine Cooler
Magic Chef MCWC8DSCT Wine Cooler
I had the same problem. I fixed the problem by replacing the main cooling fan that is mounted over the electrothermal cooling unit.. Fan can be ordered from RepairClinic.com.
Sep 16, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Danby DWC283BLS Wine Cooler Logo
303 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
