Question about Plumbing
Leaking Kitchen Tap
I have this tap in my kitchen (Atlanta Single Lever Tap PVD Stainless Steel Atlanta Single Lever Tap PVD Stainless Steel) and it has two sections, and the top section leaks, and we have to leave it in a certain position otherwise the tap will slowly leak eveywhere.
Is it the washer? if so how does the tap come apart? Do you have to turn the water supply off prior to dismantling the tap?
    President:
  • 1,263 Answers
Yes your right it's the seal inside and it can be replaced you should shut the water off after all why make a mess when you don't have to. however I'm not familiar with this typ of faucet. you more than likely be able to get help from your local area hardware store when you purchase your gasket for replacement.
Posted on Sep 02, 2008
How to repair kitchen mixer leaking from swivel not the tap
You will need to take handle of to see where the leak is coming from. It could be from the cart. or the spout o rings or both.
Aug 24, 2014 | Plumbing
We heard a loud gushing sound and the dishwasher leaked all over the kitchen floor. Why?
The drain hose may have disconnected from the dishwasher or at the waste trap or the drain hose maybe broken.
If the drain hose is OK then the water supply hose may have disconnected from the tap or the water hose is broken and fresh water is leaking from this hose.
Jan 03, 2013 | LG LDF6810ST Stainless Steel Built-in...
Is there any reason why the hot and cold can't be changed over in a mixer tap? Our model is a Monda. The instructions are to connect hot and cold to specific sides of the tap, but this doesn't suit our...
The only way is to get a new faucet. This one was designed for separate hook ups. Any plumbing supply house can get you what you want. Its an easy install, but will have to be a new unit.
Dec 25, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Single handle Spray faucet leaks at it's base, leaking under the kitchen sink
If you still have the receipts from the purchase call Moen directly as they warranty their faucets for life and will send you the replacement parts you need. If you need to purchase replacement parts then you can purchase a Moen single lever repair kit from your local hardware store which should run you around $10. Go the the Moen website and look for your model. They generally have an exploded view of every one of their models that will assist you in dissassembling the tap without any surprises. Reassemble the tap with the new o-rings etc installed and test.
Aug 10, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Can't get the replacement hose through kitchen faucet
you will need to undo the tap from the sink pull the tap up a little and feed the hose through the hole and connect it to the tap then re fix the tap to the sink most pull out taps are painfull to change the hoses
Jul 13, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Oven won't light, but if I tap on the box with wires connected to it that is behind the bottom drawer, it will light.
Kitchenaid slide -in-range gas oven KGST307HBS4 will not heat beyond 235 degrees slight smell of gas
Dec 18, 2009 | Frigidaire PLGS389EC Stainless Steel Gas...
Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
Leaking single lever kitchen tap
on most of the single handle faucets there is an erasure like button ( may have a hot and cold blue and red indicator or be silver ) usually located right under the faucet arm on the manifold chrome sleeve or back behind the arm or it could have a large ring nut over the doam of the lever take your hand and feel the area that covers the area where the spout arm swivels and feel for the button or take your fingers and fel the to of the lever doam
if you find the button just take a sharp screw driver( be sure to plug the drain holes and turn hot and cold water off under sink) pry the button off and use a hex wrench and loosten
if no button then there has to be a large nut on top you may seee two grooves oppsoite each other wheich would mean a special tool
use an adjustable wrench (put cloth ofer chrome to protect and turn counter clock wise( the ring nut will not be very thick
after removing you should be able to replace the cartridge
good luck
Dec 30, 2008 | Danze D403412 Melrose Single Handle...
Plumbing Logo
1,512 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
