Question about Microwave Ovens
Light as gone out on my pacific microwave and do not know how to get to or change the bulb there are screws around the casting but thats it
  • michael29116 Sep 20, 2008
    Decidec to buy new one could not be bothered but thanks for your help
  • Microwave Ovens Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 06, 2008
How do I change the light bulb in a magic chef microwave?
  1. Unplug the Magic Chef microwave from the wall outlet.
  2. Remove the screw from the light cover located on the left side of the underside of the microwave. ...
  3. Unscrew the light bulb, then screw in the new light bulb.
  4. Raise the light cover, then secure the cover with the screw that was originally removed.
More items...
How to Replace a Magic Chef Microwave Light Bulb ' Hunker
https://www.hunker.com/13407988/how-to-replace-a-magic-chef-microwave-light-bulb How do change the light bulb in magic chef microwave Google Search
Oct 24, 2017 | Magic Chef Microwave Ovens
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
I would like to Know the cubic capacity of the above ,and is it possible to change the light
Know the cubic capacity Mike, Pacific PMW2 microwave 700w / 17 liters capacity.
Mar 28, 2016 | Microwave Ovens
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
How do you change the light bulb in a JVM 1440?
1 Unplug the microwave oven from the outlet. Wait 20 minutes for the capacitor that is inside the microwave to discharge.
2 Unscrew all the screws around the casing by turning them counterclockwise.
3 Remove the cover by lifting off.
4 Locate the light bulb in the microwave. This will be located on either the right or left side.
5 Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to unsecure the bulb, then pull out of the socket.
6 Place your new bulb in the empty socket and secure by turning clockwise until tight, or if the bulb is one with notches on both sides, then guide the notches into the slot on the socket, push gently and turn clockwise until clicked into position.
7 Replace the cover and screw back on. You are now done and may plug back in the microwave.
May 02, 2011 | GE JVM1440 Microwave Oven
How do I change a burned out light bulb
The cover has to come off the microwave to access the bulb. There are several screws around the back and sides. Remove these and the cover should lift off, revealing the bulb. For your own safety, make sure that the microwave has been unplugged from the outlet for several hours before attempting this repair.
Mar 20, 2011 | Microwave Ovens
How do i change the light bulb on a Kenwood Ken GJ/SS25 microwave
Mar 02, 2011 | Microwave Ovens
The bulb has gone on my microwave. How do I change
take the screws out of the cover take it off can now access the light-check appliance store or hardware for the bulb.
Dec 22, 2009 | LG LRMM1430 Microwave Oven
How do get to the light bulb on the Balay 3WT -3047 microwave oven to change it?.
Generally you have to take the cover off the whole microwave.
Unplug the unit and find the screws that hold the cover on, underneath and around the sides and unscrew them.
Lift the cover off.
The bulb holder can then be seen. Some holders slide off a peg for easy access, others may have to be detached from the housing via screws.
The bulb is normally a small edison screw type on most microwaves.
Dec 19, 2009 | Microwave Ovens
Need to change the Cooktop light on a GE JVM1441. The directions say "After breaking the seal, remove the bulb by gently turning." To what seal are they referring and where do I find it. All I see is a...
Just gone through it myself. Wife was trying to change the bulbs and broke them both leaving the screw part stuck inside. I took the whole bottom panel off. It is 5 screws and comes completely off the microwave. Makes things much easier access
Jul 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
63 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
