Question about Kenmore Elite 45986 Front Load Washer
F2 error on Kenmore Elite...
Removed the front panel as per the instructions.
Cleaned the filter as per instructions.
However I am not sure how to clean the pump, there is a sponge thing at the entry to the pump and I am not sure if that is how it is supposed to be or if there is anything stuck in there.
Any help is appreciated.
    Genius:
  • 1,028 Answers
If you're talking about inside the pump housing..nope ain't supposed to be there pull it out if possible if you can't try removing all hoses and pull pump out completely remove 3 screws holding motor to housing sponge may be wound around impeller remove it ck impeller should turn with some resistance but not freewheel if it freewheel replace pump
Posted on Sep 03, 2008
I have a kenmore elite oasis 110.27042602 with fault code f2. Should I try replacing the control board? I already cleaned the contacts on it. Thanks!
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 25, 2011 | Kenmore Washing Machines
My kenmore elite mod 42832 has a error code f2 does not drain or spin
Hi
Error F2 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
Daniel
Jan 23, 2011 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore Elite HE3 model 44832 200 washer. Will spin sometimes, but doesn't seem to get to full speed. Often won't spin at all and gets F02 error, but it does roll during wash/rinse cycles. ...
he F02 message is a long drain error and it may mean the pump is clogged or bad. You don't provide a lot of detail about if the water is draining out or not but the first thing to check for this error is the drain pump.
The image below shows how to access the pump and remove the filter. This may be your only problem. With the access panel removed you can also make sure the pump is running. Remember to unplug the washer before removing the access panel.
Check the pump for the F02 and make sure you're using HE detergent and there's not excessive suds.
Jan 20, 2011 | Kenmore Elite 45986 Front Load Washer
I have an F2 code on a kenmore elite he3. I have removed the filter and cleaned it out (penny and bra underwire, hoses are clear but I still get a noisy drain and the alarm code. The impeller on the end of...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 18, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Oasis HE washer error code F2
The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test.
Diagnostic Test Mode Procedure
  1. Close the door.
  2. Select the DRAIN/SPIN.
  3. Select NO SPIN by pressing the SPIN SELECT button.
  4. Press RINSE/HOLD or PREWASH OPTION button four times within five seconds.
  5. "C:00" will show on the display indicating that the door is locked and the diagnostic test starts.
  6. Press the button you pressed in step 4 above two times. "C:01" will show on the display and the machine starts to fill.
  7. Press PAUSE/CANCEL button two times when there's enough water inside the tub to stop the test.
  8. Observe the water level falls as the pump starts draining the water. Replace the pump if the water inside the tub does not drain. You have removed and cleaned the pump so you can easily replace it too.
Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
Jan 20, 2010 | Washing Machines
Kenmore washer he3t F2
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
F2 error
Apr 21, 2009 | Kenmore Elite 45986 Front Load Washer
F2 error code
check your drain hose for kink,,when you cleaned filter did you check for coins in the impeller..also check drain pipe for slow drain problem,,check the pump connection and make sure its not slipping off..onthejob
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore elite HE3t
F2 is a drain erro. Take the 3 screws off the botom panel in the middle, bottom you will see a large white plastic looking pump. this unscrews counter clock wise. have something ready to catch the rushing water. The trap is probably full of the rubber backing or strands of the rug. After you unscrew it, there is a trap there that can be cleaned. You may have to repeat this a couple of thimes to get all of it out.
Jun 13, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
