Question about Pioneer DEH-P4600 CD Player
Hello.
My CD player is facing some problem when I turn the volume scale up than 30. I hear some noise like distortion and if put it higher than 36 the CD just self turn off. This looks like a out amplifier issue. Could you help me?
My cd player beeped three times and then shut off. it will not do anything at all now
Posted on Sep 16, 2008
How to tune properly
make sure your speakers are wired to the amp with correct ohm load, turn gain, bass boost all the way down on amp, zero out your equilizer on the cd player and turn it all the way down then start raising volume on cd player., when u can start hearing music thru the subwoofers adjust the cd player volume till the sound from your subs is at its peak without any distortion. then start raising the gain on your amp till you are happy with the sound. It gives you the optimal signal strength coming from the cd player and the smoothest sound.
Jan 13, 2011 | Performance Teknique ICBM-774 Car Audio...
Tip
Adjusting your gain for your amplifier, or amplifiers
I contacted JBL, and Pioneer about the RCA outputs of the DEH-P5800MP. I got a question answered by JBL that you should gain your amplifier, or amplifiers at half of the Head Units volume, in which case the 5800 model has a max volume of 62. I would assume that this goes for any unit since I didn't give JBL the model or brand, which indicates that they are giving a tip on every, or most units unless specified. You can e-mail the manufacture on what unit you have just in case yours is different. I found after a good conversation with the technical support guy at Pioneer that you should turn your volume up to 25-30 (25 for your loudest CD, and gain it from there. I told him that I was an audiophile and he suggested that I could gain it at 45 for my lowest recorded CD. I have been installing and gaining systems at 3/4 volume, or if the max volume was 62 then I would gain my lowest recorded digital CD at that volume. I was amazed that JBL had an answer for probably 90% of the head units, and I have learned something new. I was under the assumption that the higher the volume the more voltage the RCA's put out allowing you to be able to have your amp gain at a lower level. From my experience of 12 years, hearing both companies say roughly the same thing it is apparent that Pioneer units with a 2 volt output should be gained at the 25-30 volume range(probably for your lowest recorded CD. I have CD's that are pure digital and bass CD's and CD's that are recorded louder (like techno music, or alternative music) If you know what you are doing, and can hear distortion, like I can, the tech said that I could gain it at 45 for the lowest recorded CD. This allows your lowest recorded CD to be played at max volume at 30-45, and your loudest CD's would be at peak volume before 30, or 45 if you choose that route. Keep in mind that less power blows speakers before more power does. That is the best advice I can give, and I will adjust my system accordingly to there recommendations. Thank you
on Sep 08, 2007 | Pioneer DEH-P5800MP CD Player
Have to turn the volume to 80-100 to hear the tv in my bedroom
If it's just playing DVD's that the volume is low some DVD players have their own volume control.
You could look at the back of your tv and see if the dvd or psp is hooked up to a "line in" or a 'variable' input. The Line in is a constant audio source. The variable will be also affected by the volume on the TV.
May 31, 2009 | Televison & Video
The music is distorted when i turn the volume all the way up
The battery is your problem and needs a replacement, as denigration of the sound quality is frequently
a symptom when an amplifier is not sufficieently powered.
Replace your battery, it will no longer take a charge from the usb.
Apr 07, 2009 | SanDisk Sansa e250 MP3 Player
Scratching sound from earphones at high volumes
Sounds like the beginnings of a rubbing voice coil in your MX160. Verify this by trying another set of headphones on your amplifier/MP3 player/etc. If the "scratching" sound disappears then your music source is not the fault. PLEASE REMEMBER...never turn music source volumes up past 60-65% (think of 1:00-1:30 on a clock face). If these setting are not loud enough, use a booster or move up to a unit with more audio output power. On a larger scale...How did I blow my 100 watt speakers with a 50 watt amp? It's easy....clip (overdrive) your amp....Glen
Apr 04, 2009 | Sennheiser Audio Players & Recorders
Denon DNS1000 distorted/fuzzy sound
Please visit www.denoindjforums for further help.
Jan 31, 2009 | Denon Dns1000 Table Top CD Player CD...
JVC Car stereo with cd shuts off when volume is turned up
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
Dec 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
Cd vs. microphone
A few possibilites.
1. Even though you have some kind of peak limiting on your mics, the signal might still be peaking somewhere along the audio path and causing distortion. Gain controls might be set too high somewhere along the way.
2. The amp you are using might simply be driving too much power for the speakers to handle.
3. A faulty connection, connector, wire or input could cause distortion of something like distortion which is of course would be more apparent at higher volumes.
4. Equipment placement could be picking up sounds or interference from other sources.
5. If you are able to discern level peaks but they are occasional and not flat out, then a compressor placed in the mic signal path could certainly help - otherwise see # 1 above.
Best of luck in solving this.
Cheers.
bd.
Oct 25, 2008 | Audio Players & Recorders
Volume settings on the Rio carbon
I'm afraid that there is not. What headphones are you using? I have found that when many people ask questions like that it is the headphones and not the player. People say that when using the 3.04 firmware (look in tips and tricks for this player), the volume is higher but I haven't noticed a difference personally.. When I put my Rio up to highest volume it would damage my hearing if I could put it up any higher and I can only hear people shouting when it is on full volume. Have you got another pair of headphones/earphones to try? You could buy some high ambient noise reduction earphones and this may help.
Hope this helps,
Mowcius
Sep 28, 2008 | Rio Carbon MP3 Player
CDX-S2000 Volume, Source, and Mode buttons not working????
Hey jshaff, try taking off the detachable front, and you will see a reset button, press and hold in for 10 secs, this should solve your problem. if it doesn't work first time keep trying. you must have power to the head unit for this to work. you will hear the cd make a noise and that should be that, try and let me know.
Jun 05, 2008 | Sony CDX-S2000 CD Player
Pioneer DEH-P4600 CD Player Logo
145 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
