How do i delete a dtv channel
Hi there i have a samsung lcd tv and was wondering if i can delete a channel from the digital channels, my son has been calling a dating channel which i'm not happy about. i've tried the parental lock but it wont work because the channel has "no block" on it which means i can't block it.
  • lynzee_50 Sep 05, 2008
    the digital is built into the tv the model number is LE32A456C2D
    the type number is LE32A456, i've looked in the manual but it only tells me how to lock channels with the parental lock but like i say, the lock is no good because the channel i want to ged rid of has a no block rating. Any help is much appreciated. :)
  • 19,396 Answers
Yes, usually on most models you can delete channel for presets. Depends on the digital box model, or if TV has built in digital, on the TV.
Post here digital box and TV model, I will see if I can find detailed instructions.
Posted on Sep 02, 2008
  • Ginko
    Ginko Sep 05, 2008
    Your TV set does not have delete channel.
    What you can try is going to the channel that you do not want (suppose it is program 60) and storing manually a different channel on top of it, or use fine tuning to tune out the channel, so that it wont be visible.
    Here is the guide, check page 14 on manual channel storage.
Vertical lines on my plasma tv
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 08, 2017 | Samsung Televison & Video
What recording disc do I use for bdhddcombo when recording o TV channels
It is better to use the slowest eg 4X disc possible but some channels may not record due to encryption
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 02, 2017 | Televison & Video
Codes for channel master dvr
What model?
Dec 31, 2016 | Channel Master Televison & Video
Troubleshooting tv
you need to buy tv converter box,
Jun 16, 2014 | Televison & Video
I have a 39 inch element tv i cant program the cable channels
Typically you can access the menu, select "tuner" or something similar, make sure you're selected either on CATV or ANT (or similar), then do a channel scan. Should be pretty straightforward. Oh, and make sure you actually HAVE cable. If it's digital cable, you may need an external converter box for it to work.
Feb 23, 2014 | Televison & Video
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
My panasonic DMR-EZ45V will not auto -setup restart the dvb freeview channels it goes through the channel numbers but they do not download only the anologue channels download. it is connected to a...
I have one of these with the same problem. I couldn't find any others with answers but there are people giving answers about the DMR-EX75 showing the same problem due to power supply decoupling capacitor failure.
I just ordered a manual for mine from manualzone.com to try to locate the culprits. - Wish me luck!
Jul 25, 2011 | Televison & Video
How to unlock e.tv in mytv decoder and how to open scrambled channels in DStv?
How to unlock etv and scrambled channels on Mystrong Decoder
Nov 15, 2010 | Televison & Video
Need instructions to add TV button to AKB36157102
1. While pressing and holding down the TV POWER button, press the CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on (or turned off if you had it on). 2. Release TV POWER button when the TV turns on or off. The remote's TV POWER button will now control the TV.
Jul 19, 2009 | Televison & Video
Televison & Video Logo
1,898 people viewed this question
Top Televison & Video Experts
Electro Med Services...
