Home | Fellowes | Powershred 480 Shredder | Jammed shredder
Fellowes Powershred 480 Shredder
Problem for Fellowes Powershred 480 Shredder
Jammed shredder
By Plentsch on Sep 02, 2008
I have jammed the shredder pretty bad. Is there and easy way to unjam? It's a 480 powershredder.
Solution #1
posted on Mar 03, 2009
Not Rated)
anthonyzig
Rank: Wiz
Rating: 88%, 8 votes
First UNPLUG THE MACHINE.
Unscrew four (4) screws, two in front underneath top cover and two in back of top cover. BE careful not to disconnect any wires.
Rotate motor gear or belt in reverse to remove jam. Do not put oil on paper because it expands the paper thickness and only makes it worse.
Was this helpful?
Yes
No
Popular Solutions for Fellowes Powershred 480
Questions and Unsolved Problems for Fellowes Powershred 480
Do you recommend Fellowes Powershred 480 Shredder?
Answer
Answer
We were shredding - a red light has come on & stayed on - looks like an upright saw/teeth -... (More)
Answer
My SPL616x Shredder I had a jam and I cleared it up. It runs in reverse but not forward Any advice?... (More)
Answer
Fellowes Powershred 480. I overfed the machine then something popped and now it will only go in... (More)
Answer
The shredder operates in reverse, but not in forward.
Answer
the shredder does'nt shred and and the red light is lit what do i do
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fellowes Powershred 480...:
Top Shredder Experts
Rank: Guru Guru
Solutions: 1504
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Shredder Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
