Question about Singer 7462 Mechanical Sewing Machine
I have a singer touchtronic 2000 sewing machine. I am trying to retread it (someone else usually does this for me) and I can't get it to redo the bobbin. The bobbin does not move at all and the thread is very loose.
You could have the bobbin in backwards???
You may want to try switching it around. You can always download a manual online they are about $5-10 and show you exactly how to thread your machine.
Posted on Sep 06, 2008
My singer curvy starts beeping and lights flashing and won't sew
I just got mine to stop flashing lights and function again when I unplugged the cords from the machine and let it sit for a minute. You can always give that a try.
Dec 20, 2012 | Singer 8763 Curvy
Error code c4
try these suggestions
try changing the needle
make sure the bobbin is turned the right way in the bobbin case
if these suggestions don't help then the machine needs to be checked
Oct 06, 2012 | Singer 7258 Sewing Machine
Singer touchtronic 2010
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
adjust the top tension one number or letter higher when the stitches
on the bottom are loopy, until the stitches become normal
also change the needle--flat side to the back side of the machine
check with singer website for a manual--some times they have free
pdf downloads
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number( example 2010)
Click search
having a machine serviced once a year is a good idea & makes the machine last longer
and the sewing machine shop will tell you if they can get parts for the machine & if the machine is worth the money to fix it.
I myself have 2 sewing machines, when one is being serviced then I have the other one to use, so I'm not with out a sewing machine when I need one.
good luck
Debbi
May 17, 2012 | Singer Sewing Machines
Bobbin threading for Singer 2001
singer has some free manuals
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 117) & click search
or try youtube
May 15, 2012 | Singer 6423 Sewing Machine
Thread keeps bunching on the bottom of the material when I sew. Have a Singer Futura 920
Generally bunching underneath is related to the top tension. Check your tensions - you might have to fiddle around a bit to get it right
Feb 28, 2012 | Singer Sewing Machines
SINGER TOUCHTRONIC 2001, I FORGOT HOW TO MAKE A BOBBIN, CAN'T FIND MY MANUAL
Singer manuals are available from the Singer website,
link is http://www.singerco.com/accessories/instruction-manuals
YOu need to type in the model number and click "search" and hopefully, your manual will be there as a free download.
Four thumbs up if this helps you.
Aug 17, 2011 | Sewing Machines
Trouble shooting a Singer Athena touchtronic 2000 Sewing machine I have a Singer Athena touchtronic 2000 Sewing machine. The light comes on but the needle will not move when you step on the foot pedal. ...
Yes it's true, most parts are not available for this machine anymore. You might try to push the red reset button on the bottom of the machine. Also make sure that the reset button is not being depressed by anything that the machine is sitting on, and that the reset button pushes in and out freelyl.
Apr 27, 2011 | Singer 3116 Simple
I am trying to retread the bobbin for my singer sewing machine but the thread is not tight but is very loose
I think that you have wound the bobbin with the thread unwinding the right way. Retry winding again and do not speed, just a steady pace.
Jan 02, 2011 | Singer 3116 Simple
Singer 7462 Mechanical Sewing Machine Logo
162 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
