Question about Plantronics Explorer 340 Wireless Headset
Charging bluetooth I was trying to charge my bluetooth. I don't see any lights while I plug it in to charge.
  • 4 more comments
  • Melinda Low
    Melinda Low Sep 04, 2008
    I don't have a multi meter - the light is on on the charger but there is no light on on the headset
  • Anonymous Sep 10, 2008
    I have tested the charging tip with a multimeter, it is actually a bit high - 5.5V - but that was with no load.
    I received an errata sheet with the headset, instructing me to try disconnecting and reconnecting the charger a few times until the charge indicator lights up, but I have been trying this for a long time now without success.
  • Anonymous Dec 25, 2008
    Brand new Plantronics Explorer 350
    No lights when plugged in to charge. Check output of charger on multimeter: 5.3V
    No charge after left in for 4 hours...
    I'm considering sending my pruduct back to my supplier...
  • Anonymous Apr 28, 2009
    Contacted plantronics known problem are replacing
  • lex_graber May 20, 2009
    Same issue here
    Exactly the same issue.
    Genius:
  • 1,239 Answers
Hi sir..
please do u have muiltimeter just verify whether the voltage is there ..
Posted on Sep 02, 2008
When I plug up the bluetooth to charge the red light appears then it blinks blue red does that mean it is charging or not because it is not working with phone
That might meaning that's it's draining the residual charge left on the battery, before it can be charged, but if it does this for more than an hour, your battery is "toast".
Aug 28, 2014 | Universal QuickCell Q7 Bluetooth Headset -...
MY LG TONE HBS-730 WILL NOT CHARGE
It is charged when the red light goes out. Press and hold the VOLUME DOWN button for one second and an audible will give you the battery charge level - high - medium - low.
Apr 20, 2013 | LG Tone HBS-730 Bluetooth Stereo Headset -...
Bluetooth is plugged into charger but keeps flashing red light, dont know if its charging or not
I had the same issue -- charged it for days and still red light flashing. I was ready to break it open and see if I could replace battery. Then I looked on the opposite end of the charger and seen a little round hole thingy. I put the end of a pen in there and pushed it twice and -- the red light went away . Plugged the charge in and steady red then purple and now blue. Looks like that is a reset ..Try it -- it worked for mine.
Sep 22, 2011 | Motorola Mobility H721 Bluetooth Headset
I just bought the bluetooth twin pack headsets and I can not get them to charge. I have tried the usb via computer and also plugging in to the wall through usb capable plug in. They will work and pair if...
It sounds like a defective unit, although I am not familiar with that model... If both charging methods don't work, I would recommend a manufacturer replacement.
Jun 29, 2011 | Cellular Innovations HFBLU1K Bluetooth...
Hello. My Plantronics 210. My headphones won't come on. I had this problem before, I took it back to the store. They said there wasn't anything wrong but now it's doing the same thing. The red...
I would try deleting the headset from your phone. Do a re pair or subscribe to your phone. I am sending you a Plantronic user guide for the Explorer 220.
Good luck from Headsets Direct!
Jun 28, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My headset will not turn on
Hello
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
Dec 30, 2010 | Jabra BT150 Wireless Headset
RAZR/bluetooth light/charging problems.
From the symptom it indicate that the bluetooth having charging problem.one thing you can do is to ensure the charge contact ( both charger & bluetooth ) is good ,mean you may need to do some cleanning.if still can't hold the charge then the battery in bluetooth may need to replace. hope it help.
Aug 24, 2007 | Motorola Mobility Bluetooth Headset H3 for...
Plantronics Explorer 340 Wireless Headset Logo
440 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
