Question about Dean SR14E Deep Fryer
Dean fryer we just purchased a used sr14 fryer, propane is leaking around pilot valve knob. Are their parts available or do you by a whole new valve? thanks
  • 640 Answers
You need a new valve,Goto search for the make and model.Make sure you get a propane valve.
Posted on Sep 04, 2008
How do I troubleshoot my fryer when I cannot get it to start?
In order to turn the knob to the pilot position you need to push the knob in slightly and then turn. Once the pilot position on the knob is lined up with the indicator on the valve, you can push it in and gas will flow to the pilot assembly.
Feb 28, 2015 | American Range AF45LP Deep Fryer
I am trying to switch a natural gas deep fryer to propane and cannot fimd the correct part
Hi there.
You can visit , you can verify there the correct parts list for the model of your fryer for the conversion from natural to propane and you will be able to search there the nearest authorized parts and service provider in your area.
You will be needing burner orifice for propane, pilot orifice for propane (if available, if not, the whole pilot assembly), Gas valve spring for propane (if available, if not, the whole gas valve for propane).
Aug 03, 2011 | Imperial IFS40 Deep Fryer
I got a dean that that is for natural gas and now I need to use propane...does it have to be re jeted or can I adjust the regulator or something
It will be safe if you use a Conversion kit from natural gas to propane. The kit consists or burner and pilot orifice which has smaller holes compared to the natural gas orifice, gas valve spring which is thicker than the natural gas spring, and ann instruction manual. You can visit the frymaster website and ask the local dealer on your country for the conversion kit.
Apr 11, 2011 | Frymaster Dean GF14-SD Deep Fryer
Unit ( model SR142gp serial 0608MA0448 - propane fuel ) operates as designed, but can not cut flame to pilot with the thermostat. must cut the gas control to pilot to the get pilot flame & pilot...
The pilot light should remain "ON" all the time. It is not intended to ever go off, unless you are not going to use the fryer for several months at a time. Then you can just shut off the propane which will shut off the pilot light flame. It does not cost that much to run the pilot light all the time. About one to two dollars a week.
Sep 11, 2010 | Frymaster Dean SR142GP001 Deep Fryer
I am going to purchace a deep fryer from a resteruant and would to know if they can be converted to use propane gas
Yes. The burner orifices and the pilot orifice need to be changed. Also, the regulator or regulator spring needs to be changed on the gas valve.... depends on the brand. That's it.
Aug 17, 2010 | Frymaster Dean 1824G Deep Fryer
Dean gas deep fryer m# SR142GN
Thermocouple is getting weak. Replace the thermocouple with a new part.
Apr 21, 2009 | Frymaster Dean 2424G Deep Fryer
Pilot light will not stay lit
You can not check a thermocouple by resistence. You have to check it by millivoltage when it is hot and sensing it should be above 500mv. I would be willing to bet that you have some type of particulate in the gas valve that is causing this problem.
Jun 23, 2008 | Pitco Frialator SG14 Deep Fryer
Fryer maybe leaking propane
To see if this is leaking you can make a soap solution of 1 tablespoon of dishwashing soap to 1 cup of water to see if it bubbles. Just apply it around the knob on the gas valve or pilot valve.If it bubbles it is leaking and will need replaced. This will rule out a draft of air coming from somewhere else.
Hope this helps
May 31, 2008 | Pitco Frialator Kitchen Appliances -...
Dean deep fryer
need to change from natural to propain sr42 g
Oct 08, 2007 | Frymaster Dean SR42G Deep Fryer
Dean SR14E Deep Fryer Logo
199 people viewed this question
Top Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Paul Carew
Are you a Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
