Question about Apple iPod nano
Ipod is stuck on disk mode.
No buttons work all it says is disk mode and ok to disconnect..when i plug it in it says disk mode and it says dont disconnect..what do i do? my ipod nano classic is stuck on disk mode and resetting isnt working. none of my buttons work.
what do i do?
  • Anonymous Apr 05, 2009
    stuck in disk mode and says ok to disconnect
  • 1,879 Answers
Ipod instructions here
too many to paste in here
Posted on Sep 02, 2008
I reset the Ipod and it still has a white screen saying ok to disconnect. What do I do now?
Welcome to Fixya
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Press and hold the Menu and Select buttons until the Apple logo appears
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Thanks
Dec 27, 2010 | Sony TDM-IP1 Media Port iPod Cradle...
Tip
How to put your ipod into disk mode and restore your ipod.
  1. Switch hold button to on then off.
  2. Hold down the menu and center buttons (select button) simutaneously until Ipod powers off.
  3. Immediately after Ipod powers down, hold the play and center buttons simultaneously.
  4. Ipod should say "OK to disconnect" or "Disk Mode"
  5. Plug ipod into computer and restore via itunes.
Congratulations! You just learned how to restore your ipod by putting it into itunes.
For more information check out http://repair-scratched-ipods.blogspot.com and www.huskyipodrepair.com
on May 05, 2010 | Apple iPod MA446LL/A MP3 Player
Its stuck in disk mode screen displays a check mark that says ok to disconnect player wont turn off or go to menu screen
Try resetting it. Hold down the middle and menu buttons at the same time and it should reset itself. Then it should go to the main menu. Good Luck!
Jul 08, 2010 | Apple iPod MA446LL/A MP3 Player
White screen
This is probably caused by not allowing the firmware update to finish
the installation before disconnecting the iPod.
Try these steps.
Reset the iPod:
1.Turn the Hold switch on, then back to off.
2.Press and hold the Menu and Select buttons for 10 seconds (until the
3.You may need to repeat the reset several times.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following
the next step. How exactly you check a charge on an iPod screen that
is completely white has yet to be revealed. But hey, give it a shot
anyway. Plug the iPod into a high-powered USB port, let it sit for 2
2.Press and hold the Menu and Select buttons until the Apple logo
appears
3.Immediately switch your figures to press and hold the Select and the
settings).
Don't disconnect or eject the iPod until the store is totally done.
I hope this helps
Please do not forget to rate me
Thanks
May 17, 2010 | Apple iPod MA446LL/A MP3 Player
Stuck ipos in disk mode
Plug it into the computer, and in the ipod's main screen, uncheck the box that says allow disk mode. Hope this works!
Aug 31, 2009 | Apple iPod nano 3rd Generation
My Ipod is frozen
Press and hold the home button and the power button for 20 seconds.
Apr 23, 2017 | Apple iPod nano
My 30g ipod is stuck in the restore mode. i follow the instructions on how to restore it, and everytime i plug it into the computer, it says it needs to be restored. how do i get it out of the restore...
Try this out: And let me know the status
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
Then try restoring the ipod using Itunes...
Feb 23, 2009 | Apple iPod MA446LL/A MP3 Player
IPod Nano A1137 with disk mode message
I have a iPod Mini. I dropped it while in the gym. Now,...
Feb 05, 2009 | Apple iPod nano
Frozen Screen I have a frozen screen which says "Disk Mode", then there is a large "tick" in the centre of the screen, and another message saying "OK to disconnect". Nothing I try unfreezes this - I have...
I do not know which ipod you have, but here are instructions on how to get a nano in and out of DISK MODE:
To turn iPod Disk mode off:
  1. Toggle the hold switch on and off
  2. Press and Hold the Select and the Menu button for more than ten seconds
  3. The normal selection screen should appear, your iPod is out of Disk mode.
To turn iPod Disk mode on:
  2. Press and Hold the Select and the Menu button for six+ seconds
  3. Release both buttons when the Apple logo appears
  4. Press and Hold the Select and Play button until the Disk Mode text appears.
If it does not work, you may need to reset your ipod. The following link has extensive instructions on that procedure for many types of ipods.
Good luck my friend!
Dec 28, 2008 | Apple iPod nano
Apple iPod nano Logo
556 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
