Question about Samsung SyncMaster 940MW 19" LCD Monitor
Samsung-SyncMaster-940MW power problems
The monitor takes an extremely long time to power on, and it seems to take longer depending on how long it was left off. I have to hold down the power button for a minuet or more before it turns on, and if it has been left off for hours it can take quite a while before the light even starts blinking. The speakers make a popping sound as it turns on as well. I have tried different power outlets, but not different power cables.
  • whumprys Sep 03, 2008
    Monitor took an extremely long time to power on, and now doesn't power on at all. Initially, I would have to hold down the power button for a minuet or more before it turned on and would take quite a while before the light would start blinking. The speakers make a popping sound as it turns on as well. I have checked all the power cables
  • Anonymous Dec 31, 2008
    similar problem, it blinks and pops before it turns on, sometimes not at all
  • 3 Answers
I experience the same "power on" problem with mine, bought february 2007.
Just called the Dutch servicedesk of Samsung Electronics, just gave the serialnumber, next tuesday I will receive a new monitor.
Thumbs up this time for Samsung service
Posted on Sep 12, 2008
Help with power/ on
The normal cause of power up problems is a failure in the power supply. Check out this repair guide that shows how to disassemble the unit, what to look for and how to repair the monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/
I hope this helps.
BuddyMc
Mar 18, 2012 | Samsung SyncMaster 940MW 19" LCD Monitor
I have samsung syncmaster 940mw monitor. The monitor for the most part will not turn on. When the power button is pushed or attempt to turn on with the remote the little green pilot light will blink or...
That is a hell know problem with the 940MW tv/monitors. The power supply has failed because of parts called capacitors have shorted. If you can solder then you should be able to repair your monitor. Here is a link to the repair guide for this issue.
I hope this helps, if so please rate my solution.
Oct 30, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
On and off switch not working
Hello Michael,
The most common problem with the Samsung 940MW units that don't turn on is a failure of the power supply board. There are parts called capacitors that fail which in turn causes the power supply to not startup correctly so the monitor never powers up. Here is a link to a repair guide that should get you back watching tv and using the monitor in no time.
Oct 13, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
I have TV/Monitor Samsung 940mw. it is having powerup problem. When i put it on sleep. And tried to turn on after while it took long time to turn on. enen sumtimes it takes more than a day. But if i put...
The power-up problem you are having is usually caused by a failing power supply board. There are parts called capacitors that will exhibit this type of problem until they are warmed up. As time goes but after they start failing they will take longer and longer for the power supply to stabilize before you get a picture. If you can solder then you should be able to do the repair yourself. We have a step by step repair guide that should get you going posted on our site at: http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/ If you don't want to do the repair yourself, we do offer a repair service for this model. The repair runs $35 plus shipping and can be setup at: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Mar 12, 2010 | Samsung SyncMaster 940MW 19 in. LCD...
Power light was blinking took a long time to turn on, now power light does not blink or go solid and screen does not work
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com This model is on Monitor repair page #2 We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung Synchmaster 940MW - Will no longer power up.
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Nov 14, 2008 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsunng 940mw lcd monitor will not power up. was blinking several times before it would turn on. now no power light nothing.
Jul 21, 2008 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung SyncMaster 940MW 19" LCD Monitor Logo
473 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
