Question about Magellan eXplorist XL GPS Receiver
My eXplorist XL is locked up
Hello
I have an eXplorist XL from Magellan (I have heard all the bad things about Magellan already, so please don't go there). The unit is completely locked up, an will not boot. It starts, says checking media and beeps, and goes into a loop from there on the same checking media screen. I have spoken with support and they are saying that I can throw it away because it cannot be repaired because it is discontinued.
I have tried pushing buttons to reset the unit, and it will not budge. Does anyone have any ideas on how to repair the software on my XL?
Thanks
Ron G
  • Anonymous Feb 16, 2009
    i have the same problem my gps wont stop saying checking media
  • Anonymous Apr 13, 2009
    I have the same problem.
    When I put it away it was working fine, next time it locked on "loading" I had to remove batteries to get it to shut off.
    I did remove the SD card thinking that might be the problem but that didn't help either.
    I really feel I spent too much money to just throw it away. I guess I should have known when Tigergps.com discontinued this product from their GPS line.
Error message at start-up reads: "Press ENTER to continue NAND, Press ESC to cancel". Either choice I seclect and the unit shuts-down.
"With you XL turned off press nav + power; then change the numbers in the box from 00 to 95 by using the joystick and then press the joystick itself; (ENTER), accepting what is proposed...
Either FORMAT or SCAN... LET IT RUN!
After turning the gps on again and pressing enter the NAND will be configured and your gps will become in order again. Your system will immediately start to re-set itself.
If necessary, in usb file transfer mode, reload the basemap in the directory background maps..."
The only difference is that I had to load my SD card in the unit for it to work during the FORMAT.
My unit is NOW re-booting back to normal!
Posted on Jul 31, 2009
I've had a problem similar to this and found that it was caused by the GPS having trouble reading the SD card, either because it wasn't seated properly or because it was dirty.
Hope this helps
Posted on Nov 05, 2008
Magellan explorist XL won't power up past a blue screen
Sounds like you got a bad update, you might be able to download an update from magellan, and put it on your sd card then load it that way to finish the update.
Jul 14, 2013 | GPS
My Explorist 210 does not connect with any computer. What can I do.
What is happening is your computers are not recognizing your unit. Means you have to update unit via the registered site for updates.
first Perform a hardware reset to return the minor settings of the GPS to the original condition. Press the small "Reset" button on the side of the unit for several seconds until it powers off and powers back on.
If that doesn't solve the problem, then it means you will have to perform a firmware upgrade to put the GPS back in order.
Download and install the Content Manager software available for free from the Magellan support website. Connect your GPS to your computer with a USB cable, and the software will automatically search for firmware updates for your GPS.
Here is support to copy and paste in your browser for Magellan.
http://support.magellangps.com/support/index.php Thanks Mike
Oct 05, 2011 | Magellan eXplorist 210 GPS Receiver
My Garmin Explorist GC freezes upon startup (Garmin logo, no rotating stuff). I have tried the 3-button (menu, joy up and power) solution suggested by some, with no luck. Any ideas??
The Explorist GC is made by Magellan.
You may want to contact Magellan support for assistance.
http://support.magellangps.com/support/index.php?group=default&languageid=1
Sep 17, 2011 | Magellan eXplorist GC Handheld Geocaching...
When powered up, unit only displays
May have gotten salt water in it and causing shorts, needs to be disassembled, cleaned and dried out carefully..... The corrosion film is almoner invisible and the small surface mount parts can suffer from small amounts.....
Feb 14, 2010 | Magellan eXplorist XL GPS Receiver
Need user manual for hand held unitn100 magellan gps
Hello Please find the user manual Below
http://static.fixya.com/Manuals/M/Magellan/_99DD0BB42FFF6CE81E5872286BD30D62.pdf
Please Rated !
Sep 05, 2009 | Magellan eXplorist 100 GPS Receiver
No drivers avalible for magellan Explorist 500 for Vista 64 bit
Windows 7 has a windows xp mode that seems to work. I have been using a VMWare image with windows xp for cranky hardware like my explorist xl.
Apr 05, 2009 | Magellan eXplorist 500 GPS Receiver
Drivers for the Magellan explorist 400
I want drivers for the megellan explorist 400.Please! resent this software to me quickly.
Thank for that!
Sep 12, 2008 | Magellan eXplorist 400 GPS Receiver
GPS Logo
776 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
