Question about Kitchen Ranges
Cant get the grill compartment to work - Kitchen Ranges
  • 70 Answers
Hi, you either have the clock set to automatic or your grill bake switch terminals are burnt out. :)
Posted on Sep 07, 2008
How do I get the front grill off Renault master,cant open bonnet
jack it up and get under the front, laying down reach up behind the grill
Mar 19, 2015 | Renault Cars & Trucks
Dodge Ram Pickup, 2004/ A/C System
It should be moving air from outside the grille thru the radiator and into the engine compartment.
Oct 08, 2012 | 2000 Dodge Ram 1500 Truck
I have a kitchenaid superba ksrs25ilwh side by side fridge. The freezer is working fine but the fridge wont get cold enough even at the lowest temp
check the damper vent door for proper opening and closing as if this door is frozen shut or broken and jammed it cant open to let cold air in from freezer it will be behind a plastic grille between the freezer and fridge compartments and you should hear a fan in there running to move cold air too
Jul 02, 2011 | Refrigerators
My grill on my cooker keeps going off and on... you cant grill cheese on toast as the grill goes off and the cheese goes cold?
We know that the grill element is working because it does get hot. It sounds like a problem with the grill control.
Feb 11, 2011 | Zanussi Ovens
The auto starters on the grill are no longer working. We changed the batteries, but the grill will only start using a gas hand starter.
Before changing any parts, check the contacts where the battery compartment is, because corrosion on the contacts will make any good battery appear dead. If this is not the problem, then the ignition module has failed either through age or moisture that has ruined it. This ignition module is a common somewhat generic part that is known to go bad.
Aug 10, 2010 | Vieluxe 370102 (NG) All-in-One Grill /...
Wont get hot grill works think the element has
If it is a fan assisted oven, then it is probably the oven element that has failed.
This is usually located at the rear of the inner oven compartment behind a removeable panel
May 04, 2010 | Ovens
Fan and grill works, grill actually cooks but oven wont heat up - is this the element
Without a doubt this is the element that is faulty.
It is located at the rear of the inner oven compartment behind a removeable cover.
Mar 30, 2010 | Belling XOU252 Electric Single Oven
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
Electrical problem under dash How do I remove dash?
Instrument panel upper trim panel
Instrument panel
  1. Disconnect the negative battery cable.
  2. Disable the Supplemental Inflatable Restraint (SIR) system.
  3. Carefully pry upward, using a small, flat-bladed tool, to remove the defroster grille.
  4. Remove the Sunload and Headlamp Auto Control sensors from the defroster grille.
  5. Working through the defroster grille opening, remove 3 upper trim panel retaining screws.
  6. Remove the heater/air conditioning vents from the front of the instrument panel by releasing the tab on each side from inside the vent and pulling out.
  7. Working through the vent openings, remove 4 upper trim panel retaining screws and remove the upper trim panel.
  8. Remove the instrument cluster.
  9. Remove the right and left A/C vent trim panels.
  10. Open the trap door in the rear of the glove compartment and remove the passenger inflatable restraint wiring connector from the retaining clip on the rear of the glove compartment assembly.
  11. Remove the 4 glove compartment-to-instrument panel retaining screws.
  12. Pull the glove compartment assembly outward enough to access the wiring connectors for the glove compartment switches. Label and detach the wiring connectors.
  13. Remove the glove compartment assembly from the instrument panel.
  14. Remove the retaining screws and courtesy lamps from the right and left sound insulators and remove the sound insulators.
  15. Remove the steering column opening filler trim by grasping at the front and rear edges and pulling downward.
  16. Remove the 4 retaining bolts and the steering column opening bracket.
  17. If equipped with full console, remove the console.
  18. If equipped with mini console, remove the radio.
  19. Remove the headlamp switch module.
  20. Remove the 2 bolts and the hood latch release.
  21. Move the driver's seat to its full rearward position.
  22. Remove the steering column.
  23. Remove the 8 instrument panel retaining screws, detach the wiring connector at each side of the instrument panel, and remove the shims at the lower mounting screws.
  24. Remove the instrument panel with the aid of an assistant.
To install:
  1. With the aid of an assistant, position the instrument panel in the vehicle.
  2. Attach the wiring connector at each side of the instrument panel, install the shims and the 8 instrument panel retaining screws.
  3. Install the steering column.
  4. Install the hood latch release with the 2 bolts.
  5. Install the headlamp switch module.
  6. If equipped with mini console, install the radio.
  7. If equipped, install the console.
  8. Install the steering column opening bracket and the steering column opening filler trim.
  9. Install the right and left sound insulators.
  10. Position the glove compartment assembly and attach the wiring connectors to the switches.
  11. Push the glove compartment into place and install the retaining screws.
  12. Place the passenger inflatable restraint wiring connector on the retaining clip on the rear of the glove compartment assembly and close the trap door.
  13. Install the right and left A/C vent trim panels.
  14. Install the instrument cluster.
  15. Position the upper trim panel on top of the instrument panel, making sure the sensors are through the trim panel.
  16. Install the upper trim panel retaining screws through the heater/air conditioning vent openings.
  17. Gently push the heater/air conditioning vents into place.
  18. Install the upper trim panel retaining screws through the defroster grille opening.
  19. Install the Sunload and Headlamp Auto Control sensors to the defroster grille.
  20. Gently push the defroster grille into place.
  21. Enable the SIR system.
  22. Connect the negative battery cable.
Dec 01, 2009 | 1995 Cadillac DeVille
Cant find water filter so I can replace it.
most built in filters are in the top of the fresh food compartment or in the front grill at the bottom front of machine.
Jun 11, 2009 | Whirlpool GS6NVEXSL Side by Side...
Kitchen Ranges Logo
60 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
