Question about Canon imageRUNNER 2200
Canon Error Code E000001-0002
I tried the additional function key and it did nothing.
The error screen still shows and I cannot enter the #2 & #8.
Am I doing something wrong?
  • camoduk Nov 04, 2008
    Same problem, but pushing the additional function (funcation) key doesn't do a thing. None of the buttons do a thing. It is just stuck on the error message and won't let you do anything except restart. Are there any options besides calling a tech? I was right in the middle of a high-priority task and this is our only copier. Thanks.
  • Canon Expert
  • 1,326 Answers
Did you press additional funcation? You have to in order to get in to service mode. Then go to copier, then funcation, then CLR/ Clear, then ERR, the hit the OK on the display, then turn the main power switch OFF then back ON. It should reset the code, if not you have a problem with the fixing unit.
Posted on Oct 08, 2008
How to solve the error of canon iR2016 photocopy system error E003?
How to reset E000, E001, E003, and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Canon Printer Support Phone Number
Dec 06, 2017 | Canon Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2002n please
Description
The main thermistor reading does not reach 40C 14 sec after the fixing heater goes ON (fixing low temperature error)
Remedy
1) Wiring Is the connection of the connector (CN8) on the power supply PCB and the connector (J103) on the DC controller PCB and the wiring to the fixing assembly normal? NO : Correct the connection and wiring. 2) Fixing assembly Try replacing the fixing assembly. Is the fault corrected? YES : End. 3) Power supply PCB, DC controller PCB Try repacking the power supply PCB. Is the fault corrected? YES : End. NO : Replace the DC controller PCB. 4) Error With the power switch ON, clear E000 through E004; then, turn off and then on the power switch.
Aug 05, 2015 | Canon Office Equipment & Supplies
ERROR CODE E000350 001...
This is a fuser/thermistor error. You may have to get it serviced, but try to reset the error code using the following:
Apr 20, 2015 | Canon imageRUNNER 5000 Copier
How to remove error
E000007 error for fixing film rotation Error
Press *key (Additional Function) then 2 and 8 same time than*key (Additional Function)
you are in service mode
enter in copier
enter in function
enter in clear
touch the Error and touch the ok and power off and on
Error Will clear
Feb 25, 2015 | Canon imageRUNNER 3225 Black and White...
How can I fix error code E002-0000 on my Canon image runner 2202N
Dear
To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.Ok
To Enter service mode.
Press the operation panel user mode key(or additional function key), 2 key, 8 key and user mode key in this order.
To exit test mode, press the user mode key (or additional function key),to return to standby mode or make power OFF and ON.
Do not enter other than the above if you are not sure.
Thanks.
Jan 20, 2015 | Canon Office Equipment & Supplies
How to fix the Canon Image Class Printer 4750 error code e001-0000
for more details : www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Jan 04, 2015 | Canon Office Equipment & Supplies
Canon iR2318 show paper jam
try this :
Instructions
    • 1 Tap the "Additional Functions" button on your Canon copier.
    • 2 Press the "2" and "8" keys on the number pad simultaneously, and then quickly release them.
    • 3 Tap the "Additional Functions" button again.
    • 4 Tap the "Copier" button when you see the "System Management" screen.
    • 5 Press the "Function" button and then the "Clear" button.
    • 6 Tap the "ERR Button" to highlight all error and status codes that are active.
    • 7 Press the "OK" button, and then restart the copier to finish clearing the error and status codes.
Jul 23, 2014 | Canon Office Equipment & Supplies
Canon ir 5055 has an error e000004-0010. how di I fix this?
This is a fixing error code - there is too much temperature difference detected by the thermistors. Mostly a error reset will take care of the problem. You have to get into service mode first. Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Then copier, function, clear, err, then OK. This clears the error code from the copier. Then power cycle the copier and the copier should be operational. If this doesn't work then you will have to have a technician fix it. DO NOT keep resetting the code. There is something wrong with the copier that needs to be taken care before major damage is done to the copier. Good Luck
Dec 08, 2010 | Canon imageRUNNER 5570 Copier
How to solve the problem of error E000004-401
The book says that this is a 13V trouble error. I've never had this but the book says to reset the error by going into service mode. I would only do this once because there is something wrong with the copier that needs to be fixed. That could be the connector of the relay PCB, the IH power supply, the fixing hermoswitch, or the fixing unit. You get inot service mode by pressing the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Then copier, function, clear, err, then OK. This clears the error code from the copier. Then power cycle the copier and the copier should be operational. If this doesn't work then you will have to have a technician fix it. DO NOT keep resetting the code. There is something wrong with the copier that needs to be taken care before major damage is done to the copier. Good Luck
Dec 05, 2010 | Canon imageRUNNER iR C4080 Color Copier
I just want to do a cold reset
Press the following keys to enter the service mode.
Additional functions key > 2 key > 8 key > Additional functions key
Scroll to the #clear screen and select all
then exit
good luck
Oct 20, 2009 | Canon Laserbase MF6530 All-In-One Printer
Canon imageRUNNER 2200 Logo
819 people viewed this question
old marine
old marine
