Question about Canon EOS-10D Digital Camera
Error 99 I have a Canon 10D that worked fine for a little over a year, than I started getting Error 99's. You click the shutter button and nothing happens except an odd sounding click, and the "error 99" blinking in the LCD. At this point the camara is usless until you turn it off and than back on. This became more and more frequent until now I just can't depend on my camara any more. The problem, with my camara seems to have nothing to do with lens contacts or the memory card. I have search several message boards, and it seems that this this Error 99 thing is not that uncommon with Canon DSLR's. I am wondering if there is a similar problem with Nikon, or any of the other DSLR's. I am trying to decide whether to pay to get this thing fixed, or just buy another camara or both. I have heard that getting an error 99 problem fixed can be quite expensive. If I opt to buy a new camera should I switch brands? Any openions on this? Thanks:
    Sniper:
  • 51 Answers
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Posted on Jan 30, 2009
    Sergeant:
  • 255 Answers
It's probably the battery/battery contacts. It was relatively common with the 10D. I now use a 20D and a Rebel XT. I've had an Error99 once on my 20D, when I first got it, but none since them. I've never had an Error99 on my Rebel XT. By the way, upgrading from the 10D to the 20D would be well worth doing. The 20D simply has better electronics all around than the 10D. Even the Rebel XT does. I replaced my 10D with the Rebel XT. The XT really is that much better.
Posted on Sep 14, 2005
    Sergeant:
  • 255 Answers
I get error 99 sometimes on my 20 D but it?s usually to do with a lens that is attached. Sigma lens have been known to cause error's. If it's not that or dirty contact on the lens then it could be a more serious problem. I would at least check it out with a canon dealer/repair centre.
Canon EOS 50D camera error 231
If you have another lens, try it with that lens and see if it works properly. Many times ERR 99 is caused by a failure of either the circuit or the aperture unit in the lens.
Otherwise the most common cause usually is a faulty shutter.
Jan 19, 2013 | Cameras
I have a canon 10D that is getting an "error 99".
You could've used a non-compatible lens or the contacts are dirty. Turn the camera off then use a clean micro fiber cloth or pencil eraser to clean the contacts.
Dec 17, 2010 | Canon EOS-10D Digital Camera
D40 "Error: press shutter release button again." Nothing happens.
If you can dare servicing youself You can open bottom cover of and turn a little red wheel manually. try pressing the release button now and will start working. If you have this problem re-accuring, then get it checked wih professional.
Dec 19, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon eos 40D error 99
Check this link: www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Oct 20, 2008 | Canon EOS 40D Digital Camera
Canon 20D error 99 shutter stuck
Exactly same problem, shutter clicks until battery removed. Power may be on or off.
Apr 04, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I have error 99 in my camera canon 400d
Error 99 is a general fatal error.
which includes the problems above mentioned by Q4SteveB but also many others.
It can be caused by a dicky shutter, problems with the CF card interface.
If cleaning and trying a different lens has not worked. Not definitive but as a rule of thumb...
If it letting you take one picture then giving error 99.. and the picture is saved to the card (but may just be black) this is most likely the shutter needs replacing..
If it takes a picture and gives error 99 but there is no picture on the card or the picture is 0KB its a CF interface problem.
If you get an error 99 when you plug in the USB its a USB interface error, you can try a different cable but unfortunately in most cases if another lens or cable wont work it needs repair
Feb 22, 2008 | Canon EOS 30D Body Only Digital Camera
Err 99
Although you may have cleaned the lens contacts, did you clean the camera contacts? This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
From RICHARD'S NOTES
Dec 04, 2007 | Canon EOS-10D Digital Camera
Canon EOS 10D Shutter getting in the way on fast shutter speeds
Only Canon Technical Support will came to your rescue here
Jul 21, 2007 | Canon EOS-10D Digital Camera
My Canon is displaying - Err 99 what should I do?
Just found this info which should help diagnose the err 99 issues (info direct from Canon apparently)
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 10, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Canon EOS-10D Digital Camera Logo
304 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
