You should just be able to set the cooktop in after you attach the downdraft, usually there are tabs on the downdraft that clamp on to the granite cutout. There is probably a closed-cell foam strip that runs under the lip of the cooktop, I would just make sure it seals to the granite properly (no gaps) and put a couple dabs of silicone in between the lip of the cooktop and the granite. Usually the cooktop is heavy enough that the silicone will keep it from moving around.
From my experience, most cooktop manufacturers give cutout dimensions that almost always need modifications to get the screws or nuts on the stove to fit the cutout. Have your granite fabricator come enlarge the opening by grinding specifically where there is interference. They should be able to tent off your granite and use a vacuum to minimize dust. Feel free to contact me with any questions. Brandon Wiese - [email protected] - http://.www.StoneRepairman.com
Turn off the gas,unplug the power. Take the cooktop out of the cutout and support it on the countertop. Remove all grates and valve knobs. Remove all screws from the valves and the burners. Remove the burner base plates. You may have screw on the side holding the top to the base,if so,remove these too. The top will separate from the bottom exposing your parts.
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
There should be removabe clamps attatched to the bottom of the cooktop which tighten with a screw to the bottom of your countertop. Loosen the screws to the countertop, then remove the screws that attach the brackets to the cooktop. The cooktop should then be able to be pulled out.
