Question about Canon EOS-1Ds Digital Camera
Lighter Band On top of the picture
I noticed that when shooting outdoors specifically, there is a lighter band going across the top of the frame of my 1Ds (mark I). This occurs especially under bright sun. With an overcast sky, it's either unnoticeable or not there. In shade or indoors, it's non- existant. Occurs with fill flash and without. Occurs at different ISO's as well as different appertures. It stands out particularly when the frame is underexposed and it almost seems like the lighter band is properly exposed versus the rest of the frame. Anyone familiar with this or can give me a clue??
    Sergeant:
  • 255 Answers
It's a shutter problem--it's not the amount of light per se that causes it, it's the shutter speed. This issue often only shows up at a few shutter speeds. My 1dsII does it around 1/125, although not nearly as badly. Apparently the shutter is bouncing or hanging up at the end of its travel. Sorry, it's either send it to Canon or learn to live with it.
Posted on Sep 14, 2005
CASIO EXILIM digital camera photo resolution
The Digimax A7 Doesn't work outdoors, because on top of the camera, try taking a picture, but hold your hand on the top of your camera (Cover it) it's light sensitive. On top their is a built in sensor, the Darker it is the darker the picture is, the lighter, the lighter. If you cover it, (Usually on top) It should work fine outdoor, just don' t cover it indoor. Hope this helped. -CA
Jul 14, 2008 | Samsung Digimax A7 Digital Camera
Vizio VW46L10 TV has a 6 inch dark band across the top of the picture.
Change input device to some other like a DVD player.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Televison & Video
Band of darker good quality colour at top quarter of screen - below lighter colour and poor quality text
Try having your colour depth at 32 bit, right click on your desktop and goto graphics properties and select 32 bit instead of 16bit
Feb 28, 2011 | Acer Computers & Internet
Why are documents printing with a black stripe on right side?
You most likely have a defective cartridge. It is also possible that your Charge and/or Transfer rollers have become defective.
Inspect the cartridge for any band of remaining toner.
You should notice one or two long thin rollers, with the cartridge removed. There will be a dark roller that should appear textured, but not dull. And they may also be a lighter colored roller with no marks.
These are the three common problems that create lines.
Lastly
If the band is mostly straight, it is most likely the cartridge
If the band is wavy or broken in anyway, it is probably the roller(s)
Let us know what you find
Apr 15, 2009 | Dell 3000cn Color Laser Printer
The display has two bands running vertically down the screen they allow you to see the image behind them but the bands are lighter than the rest of the screen one band is lighter than the other and the...
Check LCD harness does its not loose on LCD or motherboard, otherwise its a faulty screen.
If you'll give me exact laptop model, then i'll give you instructions how to check connections and if connections are tight, then i'll give you advice where to buy and how to replace screen.
Mar 28, 2009 | Computers & Internet
Discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
Jan 25, 2009 | Nautica N07574 Wrist Watch
Lighter bands across copy using Canon F 132500 copier
Open the flap to expose copy platen and press print you should get a flat even black
if you get the white bands do the following:
Clean the corona wires open the cover pull out the sliding charge wires and clean with q tio and acoho or a pencil erasure
If that does not work remove top glass and clean mirror and bottom of glass
Dec 24, 2008 | Office Equipment & Supplies
RCA r56wh78 scrolling vertical bands
it is going to need to be tested to find the component that is causing the problem
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Canon EOS-1Ds Digital Camera Logo
59 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
