Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Fridge will not cool down
Just moved and fridge is only 4 years old after moving plugged it back in and now both sides will not cool. Cn hear it running and lights on inside work so know that power is there. Can you help?
  • Frigidaire Master
  • 5,568 Answers
Since it has been two weeks that you have posted this, you probably have a cold unit by now, but if it was ever transported horizontally, they are supposed to stand unused for a couple of days before you try to run them. The coolant system has lubricants in it that may drain from the compressor where they are needed and require a little quiet time to recover.
Posted on Sep 15, 2008
The refrigerator is approx. 4 years old (side by side model). It was recently moved 100 miles. It was working fine in its old location, moved it 100 miles and now it does not cool or freeze. The lights...
if you laid it on it's side you could have damaged the sealed system.the machine has to be standing upright just like when it's in your kitchen or the compressor can get damaged,if you stood it back up and didn't run it for a few days the oil might go back down into the compressor but if it was moved on it's side and started most likely you damaged the compressor,or a wire or something got knocked off while moving it if it was moved correctly.is the compressor running?
Apr 13, 2011 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
After relocating refrigerator, no cooling, middle panel very hot
Hwne you had moved the fridge it is quite possible that there could have been a damge to the compressor or the piping resulting in the gas leaking off. This must be confirmed , if so refill gas properly with the help of a technician. Next solution also could be if the fridge had been been transported upside down or side ways. If so the oil inthe compressor would have gone into the system and choked it. For a trial put off the fridge for about 24 hours so that all the oil drains back to base. then test it to check if the cooling comes back. Since I presume prior to your moving the fridge was working fine, the areas of fault could be these two factors. I hope you can check this up and decide . If not ask for a quote on the fault and we can review. I Hope I could help. Good day
Jul 21, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Fridge in storage for 4 yrs, now not cooling
Good day,
After that much time, be sure the fan motor in the freezer compartment is running, as well as the fan motor on the back bottom behind the cover by the compressor. Either could well have frozen up after 4 years of storage.
As well a refrigerant leak could have developed because of the time frame. However, if it is less then 5 years old, the sealed system would still be under factory warranty.
Apr 03, 2010 | Hotpoint HSS25GFP Side by Side...
After moving fridge (and waiting 36 hours) compressor won't start
You should worry , the 12 amps is a locked rotor on the compressor , it may be the over load relay control on the compressor as well , try replacing the over load start relay first , they are not expensive , if this does not fix it you can try installing a booster like a rco410 but the comp. can not take that abuse for years from the booster. when the comp. is running normal it will draw roughly 1.5 - 3.0 amps.
Phil
Apr 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Fridge and freexer are not working
the fridge has to be set upright for about 24 hours before using again.  we set our fridge on its side to move and it did not work after we got to our new place.  we ended up getting rid of it.  our repairman said if we had let it reset itself, fluids and all, then plugged it in - it would have been fine --after 24 hrs.
Nov 18, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerator not cooling
My fridge and freezer just stopped cooling all of a sudden. I hear the compressor running and every couple of min there is a clicking noise. Is there a reset switch or something that I can do to start it working again? The lights are working but the freezer and fridge are room temp.
Jun 22, 2008 | Refrigerators
Older subzero side by side not cooling
At sixteen years old it is almost through its life span. A change in ambient temperatures will change internal system pressures. Make sure the condenser is cleaned well. Use a vacuum cleaner to clean off the condenser, then blow it out with compressed air. Even though a condenser looks clean on its surface fins there may be dust down in between the fins.
May 05, 2008 | Sub-Zero 690 Side by Side Refrigerator
Kenmore side by side not cooling after a move
go to the back of the fridge see if it has a white relay on the compressor that's the piece that plugs onto the compressor if it does un plug the unit take it off and shake it if it rattles and little black stuff falls out of it replace it with a three in one relay from an appliance repair parts store just follow the instructions on the part its easy don't worry about water in the ice maker it will fill when it starts cooling if it doesn't have the relay try turning it off for 24 hours to give the oil time to run back down to the compressor and advise me further
Mar 30, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Fridge not working
may i suggest you Purchase A premium repair Solution. @ $19.99 or £10.00 G.B.P
One of our technical assistants, will usually have the Answer to your Problem, within the hour.
Mike @ Compurepair.
Mar 02, 2008 | Kenmore 44109 / 44102 Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
60 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
