How do i change my keyboard - Computers & Internet
    Problem Solver:
  • 7 Answers
You have to fold the keyboard...as if you were going to watch tv, and remove the plastic and about 6 plastic or rubber squares that will reveal some screws, take those out, and then in the hinge where you fold the keyboard(hard to see) there are two small screws on each side, remove those as well. Then to remove it you have to kinda force it out because it is held with clips on the end.
Posted on Dec 27, 2008
    Sergeant:
  • 359 Answers
Unplug it from the back of the computer and plug a new one in...
Posted on Sep 02, 2008
Change laguvage
Go to Start- Control Pannel--------Region And Language ----- now under Region and Language Click Keyboards and Language-----Change Keyboards--------- under Change keyboards you Click ADD------- now chose ever language you want and restart the computer.
Jun 07, 2011 | IBM ThinkCentre S50 PC Desktop
I type on my Lenovo a3 wireless keyboard, and I only get numbers. Help
you may need to change your keyboard input language.
Control panel (clasic layout) / region and language / keyboards and languages.
You can now change or add the keyboard layout / language you need
Sep 30, 2010 | Computers & Internet
Keyboard typing wrong fg when pressing f key l comes out l/ on gateway Fpd1520
Might have a bad milar/memory in your keyboard, this is a sheet behind the keys. I would try another keyboard. Or you might set a diffferent languague to your keyboard. You can change it back by changing the input language (i.e. keyboard language). http://www.conversationexchange.com/resources/keyboard-language.php
Dec 02, 2009 | Gateway Computers & Internet
I get keyboard failure when i put on my PC
How keyboard problem can be solved by changing harddrive ??
Try a new keyboard . If ps2 does not work, you may try an use keyboard too.
May 29, 2009 | Dell OptiPlex GX50 (GX50SC1338420) PC...
Loose keyboard connection
You will have to either repair the connection with a soldering iron, replace it (which means finding a connector from another board and desoldering that one, then desoldering yours and installing the good one), or simply change to a USB keyboard.
By far the easiest thing to do is change to a USB keyboard. You could also use a simple USB to PS2 converter if you don't wish to change keyboards, the converter would simply allow you to plug your keyboard into a USB slot on your computer.
May 24, 2009 | Dell Dimension 2400 PC Desktop
Wireless keyboard went dead. Have changed batteries & pushed all green buttons
I had the same problem with my keyboard and it turned out to be a manufactureing problem I just got another keyboard.
Apr 20, 2009 | Dell Dimension 3000 PC Desktop
My husband has acer 4520 cant get question mark..when presses ? key he will get E or e
Oh this is a returning issue with my Canadian users. The keyboard is french, that is the one with the E letter things at the place you normally have the question mark. It is indeed a keyboard layout but it gets randomly selected. Saw this problem only on VISTA so I will describe how to do it in Vista.
Go to Control Panel, Regional and Language Options, Keyboards and Languages, Change Keyboards. Here you will see all keyboard layouts installed. Make sure you remove any that you do not need or if you see the french one even, remove that by selecting the one causing you problem and choose Remove.
If you don't remove the keyboard map, when this switch happens, you'll have to exit the application you're in (Outlook, for example), change keyboards, and restart the app. Changing keyboards without restarting the app doesn't change the mapping.
If the above solution for whatever reason does not work, just push Shift and Ctrl at the same time, hold it pushed for about 5-10 seconds and let go at the same time. You have to be in the active window (the application in which you tried to type and it gave you E-s instead of ?-s) for this to work. But please try my first suggestion first with the keyboard layouts because I am confident that is your problem.
Please rate if this solution was helpfull. :)
Jan 31, 2009 | Computers & Internet
My wireless keyboard model YRA156A will not work changed batteries still failed mouse ok
have you resynched the keyboard to the wireless module. if not press the button on the wireless module and then press the button on the bottom of the keyboard also check where you installed the batteries and make sure you didnt change the channel for the keyboard.
Jan 05, 2009 | Computers & Internet
Keyboard keys
sir,
I have problem in my Keyboard keys, i have just buying dot station computer, i geting the problem in setup keys, i want to go in BIOS for setup what can i do for that please give me solution. Can i change keyboard or i change with other USB keyboard.
Dec 18, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Compaq laptop can't get the ? symbol
Looks like the French keyboard mapping is still in effect.
You can try changing the keyboard keys back to where they were by pressing:
Left CTRl + left Shift at the same time. then try typing the ?/ key. You may have to try this a couple of times to get it to work.
If it does work, try the right ctrl/left shift key.
Also found this:
Change Keyboards. Select the keyboard you that's causing you grief and
choose Remove.
seem to change the mapping.
Hope this helps!
Sep 06, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
