Question about Sony Handycam DCR-SR42 Camcorder
Lcd screen My screen is rolling from top to bottom
  • 13 more comments
  • Anonymous Oct 13, 2008
    Yes, I have the same problem. When I start the camcorder it doesn't show the screen (Flickers/rolls). Sometime, after 3-4 trys, it starts. I have never dorpped/bumped it anywhere.
  • starbuck37 Oct 14, 2008
    I, have the same issue with the picture rolling up when the viewing panel is opened. Sony will done flat rate fix for 201.00 plus taxes & shipping for est total of $260.00. This seam like design problem with the screen cable & rotate and mounting connection. Do you think it is weath the money to fix this unit (15 month old) ?
  • Anonymous Nov 08, 2008
    sony is bad, I guess
  • usdw5 Nov 09, 2008
    SAME PROBLEM!! Used one time and not been out of box but for that time and now Sony wants over $100 to fix!
    Does anyone have any ideas to try to fix it? It like the vertical hold is out and pic is rolling with interference.....
  • hannahholly Nov 13, 2008
    I have the same problem! And Sony does want $261.00 + to fix it. Jeez, it looks like we all picked a bad camera. My LCD screen is mostly black with horizontal, wiggly lines that move. There is no discernible image, but it looks like the rest of it works. How can I fix this or what is wrong with it that someone else can fix?
  • tlehhema704 Nov 16, 2008
    Sony Handycam DCR-SR42 Camcorder . The screen is rolling from the top to the bottom
  • Anonymous Nov 20, 2008
    I also have the exact same screen rolling problem like everyone else. You would think Sony would test a product more vigorously before releasing it to the public.
  • Anonymous Nov 23, 2008
    I have the same problem..I thought I did it, but I take very good care of it...Sometimes it does it and it will stop all on its on.
    Mines does it on its own and will stop whenever it wants.I thought it was my fault and now I see its just the camcorder.
  • jodiandterry Dec 06, 2008
    I have the same rolling screen problem, it is driving me crazy it will roll and then for some unknown reason stop then start rolling again. Is there any solution to this? Please post if possible, thank you
    Jodi
  • jk-s Dec 06, 2008
    Screen rolls when camcorder is on. Would briefly stop is the flap was gently wiggle back and forth. Suggest that a connection is loose or defective. Screen stops rolling completely is flap is reversed and placed flatly against body of camera with screen pointing away from camcorder body.
  • Chughtai S Jan 01, 2009
    I have DCR-SR 82. Screen rolls when camcorder is on. Suggest that a connection is loose or defective. if some one have answer to this problem please let me know. Thanks
  • supercomput Jan 06, 2009
    my handcam's sreen is rolling from top to
    boottom.please suggest how to solve this problem.
  • bwarpup Feb 04, 2009
    My camera is 2 years old and the screen rolls at startup. It will eventually stop after a few minutes but is very anoying. How do I fix this "vertical hold" problem?
  • bubblespink Apr 04, 2009
    The screen goes plain white on my DCR-SR42 or it scrolls horizontally. I bought it from Canada and i live in the UK. What do i do??
Here is the solution to rolling view screen. First, set your camcorder in the cradle or station and it's plugged in. Secondly, press the icon that looks like a home. At the bottom of the screen select the icon that looks like the tool box (far right side). Next, you will get one screen with 4 options on the first page, and if you select the down arrow you will get to "General Set". Then select "calibration" and touch the x's when the camcorder prompts you to. It worked for me and it should for you. Don't bring your unit in for repair, just send me a best wish and we'll call it even... :) Good Luck!
Posted on Aug 28, 2010
  • darrelldesig Mar 26, 2011
    Wonderful, had to persist for some time chasing the X, however it worked, can't thank you enough, has saved me hundreds of dollars literally, thank you very much.
  • bigbadwolfto Jun 05, 2011
    Sorted my rolling screen problem within 5 minutes of trying.! Many thanks for the advice. Most difficult part was clicking the down arrow, but got it eventually when I actually found out where it was. Many thanks again!
My handcam's sreen is rolling from top to
Posted on Dec 24, 2010
    Problem Solver:
MY SONY DCR-SR42 EVERYTHING IS WORK THE ONLY PROBLEM I HAVE IS WITH MY TOUCHSCREEN DONT'S WORK PLEASE GIVE SOME HELP THANKS
Posted on Jan 22, 2009
I've got the same problem. It looks like the cable connecting the lcd screen and the camcorder may be damaged.
Have a look at this article:
http://www.fixya.com/support/t813518-sony_dcr_sr200_screen_slowly_scrolls
The part that this article talks about can be found in Nexttronics or the Partstore.
HOWEVER: I don't know if the same part is used in the DCR-SR42. Can anyone else confirm this or not?
Also, it looks very difficult to replace the cable. Has anyone done this? How difficult is it?
Posted on Dec 04, 2008
I have the same problem, rolling the pic. from top to bottom. when i open to take pict. it is keep on rolling, some times it stop. please give some kind of remedy. thanks i think quit buying sony's products.
sam joseph
okc,ok.-720-2278
Posted on Nov 16, 2008
The screen falls from top to bottom over and over again. like it is on a wheel of some sort. Thats the best description I can come up with. How can you fix this without going to sony?
Posted on Oct 29, 2008
Somebody please post a reply. I am having the same problem.
Posted on Oct 13, 2008
    Master:
  • 383 Answers
Wht do u mean exactly .....cant understand rolling means what
Posted on Oct 10, 2008
My screen rolls very fast from top to bottom and back again. It does it all by itself. How can I stop this?
if it does this without it being plugged into a computer then the horizontal hold is out on the main board of the lcd.
if its ok w/o a computer connected then check the cable an pins, connect it to your laptop to test your computers video out issues.
May 23, 2014 | Relisys RLT1720 17" LCD Monitor
Picture keeps rolling over
If you know electronics there's few capacitor or one need to be change. or call a technician.
Oct 15, 2012 | Sharp LC-20S7U 20 in. EDTV LCD Television
Hp pavilion dv8130us laptop rolling screen at start up, cant see boot of computer put on projection plugged into computer see windows just fine on tv . is it video card or lcd gone out? just place new lcd...
By using the VGA output with a projector and having it show up clearly and as expected is a sign that the video card/GPU is working properly.
Furthermore, the symptom that you explain of a rolling screen I interpret as meaning that you can see the image that is meant to be displayed, but it keeps moving from the bottom of the screen to the top and rotating. IF this is correct it sounds like DA converter on the LCD is your culprit. It is the chip that is in charge of interpreting the signal coming from the GPU and sending it to the LCD elements at the prescribed refresh rate (generally 60 hertz). The rolling image is an indication of the refresh rate not being met by the LCD.
Things to check:
1) While plugged into the projector, open the Windows Control Panel then the Display Icon. Go to the Settings Tab.
2) If the Display settings show 2 output displays, ensure the built-in LCD is the one clicked on in the graphic then click the Advanced Settings button/link.
3) Once that window appears go to the Monitor Tab and set the option to the lowest numbered option. Generally this will be 60 or lower. Then press OK. The screen will flicker and HOPEFULLY you will get a clear/non-rotating LCD display. If not, I'd venture that the LCD itself has gone bad again. Perhaps there is a root cause such as a powering issue that is providing too many amps to the LCD but that would take some hefty investigation to resolve the power that is supposed to be provided and a multimeter to figure out the actual voltage/amperage.
Hope this helps!
Mar 17, 2011 | HP Pavilion dv8130us Notebook
DS turns on and right back off. The top screen doesn't attempt to turn on
No, this is not a battery problem. This is not a top screen problem as well. This is a bottom lcd problem.
The top screen flickers when the bottom lcd is messed up and the bottom screen flickers when its the top lcds problem.
Follow the links below. You can purchase a bottom LCD for cheap and there are instructions on how to change it.
1.)http://www.amazon.com/dp/B000RWXCE2?tag=wit08-20&camp=14573&creative=327641&linkCode=as1&creativeASIN=B000RWXCE2&adid=0JJ799NSS5VV0XTY8DYK&
2.) http://www.instructables.com/id/S3ZZJPKFA0CVIFO/
Nov 27, 2009 | Nintendo DS Console
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
Sony DCR-SR42 LCD problem
fp-610 or 1-871-457-21 or old part number 1-871-457-11 is a flexible connector, runs for about $40 with shipping on ebay or web
Apr 26, 2008 | Sony Handycam DCR-SR42 Camcorder
Laptop has lines rolling thru the screen
Im Chad from Dell and it looks to me that you may need to Flash the BIOS. If that does not work you may need driver for updating the video card of the system. This may be a also a known issue for the system specially if system is running vista. Try also to go to website of Compaq and install the latest driver.
Feb 16, 2008 | Compaq Presario M2000 Notebook
Osd locked
I had precisely the same problem... I depressed the Menu Button for about twelve seconds or more and the menu actually finally popped up; and does so now every time I depress Menu! Hope this works for you.
Big Jim
Dec 30, 2007 | HP vs15 15"LCD Flat Panel Monitor
My tv rolls from bottom to the top
It's a bad cable connection. Move the cable wire and see if there is a difference. The bad connection can also be at the cable box outside.
Jun 29, 2007 | Sony FD Trinitron KV-28FQ75 28" TV
Sony Handycam  DCR-SR42 Camcorder Logo
1,087 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
