Question about Hotpoint WD62 Front Load Washer / Dryer
Water got stock in the machine
After washing then drying the clothes water was still in the machine and and the clothes was socking wet and really hot.
what could be the problem? Can you help?
  • djgenius10 Oct 14, 2008
    Hey, I have the same problem. And I think the daining motor is gone, but I have no idea where to get it and how to fix it.
  • Hotpoint Master
  • 3,463 Answers
It sounds like the drain pump has failed.
It is located at the rear right of the m/c, and has 2 hoses connected to it.
Posted on Nov 28, 2008
MY washer fills, sometimes stops without completing the wash, sometimes it shows a completed cycle but the clothes are too wet to dry, sometimes during a cycle it will turn off with the door locked.
Sounds like a draining problem - Check the drain filter isnt blocked, if fitted before doing anything else - remove the filter and clean it. Then, can you hear the drain pump running on the drain cycle (drum not moving but pump should be) - a chug chug chug noise and water should be flowing down the waste pipe. Door WILL lock if the machine is full of water or is slow to drain - to prevent floods. Do NOT force the door open without draining - you will only break the door handle.
If water not flowing on drain - and filter clear - may be blocked pipe, sock stuck in sump hose - coin or counter flipped on edge in a pipe and blocking it - something like any of the above. Clothes too wet to dry is classic partially blocked drain pipe symptom - or spin aborted as drum out of balance.
Feb 01, 2018 | Washing Machines
My washer is not spinning clothes dry and the end of the cycle. Everything is soaking wet, what can I do?
is the pump free to spin? when the pump operates(when it spins) is the water getting out? something like a sock may have got past the drum into pipe that joins to pump allowing only some water to escape
Jun 06, 2015 | Bosch Nexxt 500 Plus WFMC5301UC
How do I open a lock LG WM 1832 CW front end washing machine with water and clothes inside?
First you will need to get the water out and really the only way to do that if the unit won't drain it is to open the filter to get the water out and besides that, there is probably a blockage at the filter that is preventing it from draining in the first place. You will need a lot of towels handy or a wet/dry vac at the ready!
Nov 28, 2012 | Washing Machines
Does not always clear soap , no increase in quanity ,and does not always spin clothes dry ??
The easiest solution to this problem is a sock or other small item has passed out of the washer and is clogging the filter of your water pump. Open the front panel and look at the water pump. If there is a round access door next to this pump, then spread some large towels out to catch excess water then turn the cover of this access door to remove it. Look inside and pull out the stockings/socks/pencils/coins etc that are stuck in there.
This is a 10 minute fix and if you find something big in that trap, 99% chance your problem is solved.
Feb 02, 2011 | Kenmore Elite 45986 Front Load Washer
Clothes come out still very wet...all water isn't draining I think. I tried to run it with no clothes (only detergent), and the service light came on at the very end of the wash cycle. My opinion...
john let's find the sock .. not knowing the brand .? take the front off the pump may have a turn cover /turn it and remove sock . other brands you will have to remove hose to get sock .. give it a good try . i think your on the reight track..mm hope this helped.
Dec 06, 2009 | Washing Machines
The machine washes fine, but adds water on the drying cycle
The machine sounds faulty. You can bypass this by turning off the tap and respinning the clothes until the machine is fixed properly,
Oct 19, 2009 | Washing Machines
Can you adjust the water level on the LG Tromm WM1814CW? The water level when washing and rinsing is so low that the clothes are barely wet when the washer has finished.
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Mar 29, 2009 | LG WM1814CW Front Load Washer
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Hotpoint WD62 Front Load Washer / Dryer Logo
67 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
