Question about Goldstar Microwave Ovens
Locked - Goldstar Microwave Ovens
  • Goldstar Master
  • 9,098 Answers
Try holding the CLEAR pad for 3-4 seconds.
If that doesn't work, do that with each of the other pads one at a time.
If you still have trouble, Please reply back with your brand and model number so we can help you.
Posted on Sep 16, 2008
I have a whirlpool microwave WM1107ADWC and I want to turn off the Child lock. How can I do it? I don't have kids and i want to save time when I use my microwave. Thanks
Child locks on microwaves act as a safety feature to prevent children from getting harmed or from causing other possible damage. The child safety lock does not lock access to the microwave; it simply prevents the microwave from being operated. To remove the child lock press the Stop button three times.
Lock the microwaveIf you wish to re-lock the microwave, perform a similar procedure. Instead of pressing the Stop button you need to press the Start button. Press the Start button three consecutive times to lock the microwave. This enables the child lock once again and prevents the microwave from being operated.
check this video also. Many Whirlpool microwaves are made by LG. between these two you should get it.
How do you remove the child lock on microwave
Jun 12, 2017 | Whirlpool Microwave Ovens
Frigidaire microwave key shows a lock and no keys work
Here is a previous answer that might be of help.......
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it is still locked or goes into lock mode by itself, the "clear" key on your keypad may be shorting.
Here's how the child lock works on model FMV145:
Child Lock-Out
You may lock the control panel to prevent
the microwave from being accidentally
started or used by children.
To lock or unlock the controls, press and
hold CLEAR/OFF for about three
seconds. When the control panel is
locked, an "L" will be displayed to the
extreme right.
Jun 07, 2016 | Frigidaire Microwave Ovens
Microwave is in Lock -- how do I unlock it?
" 1. CHILD LOCK
The Child Lock prevents unwanted oven operation
such as by small children. The oven can be set so
that the control panel is deactivated or locked. To
set, touch Custom Help, the number 1 and Start/
Touch On. Should a pad be touched, LOCK .
.. ON will appear in the display.
To cancel, touch Custom Help and Stop/Clear. "
Also, to find manuals........
Oct 03, 2014 | Sharp R-1480 Microwave Oven
My mother mistakenly locked her samsung microwave. She can't figure out how to unlock it and she can't tell me what model it is. Can you help?
On a friend's Samsung (she didn't tell me her model number either), you lock the keypad by pressing "0" and then "2". Press the same sequence to unlock the pad. Maybe this will work on her model.
May 31, 2011 | Samsung MW7490 Microwave Oven
Says "locked' an unable to use, no buttons work
The child lock is on. Turn off the lock by pressing and holding 0 until the word Locked disappears.
To turn on the lock, press Stop/Clear and then press and hold 0 until the phrase appears.
The manual for the Jenn-Air JMC8130DD is available from http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMC813&siteCd=JA_EN_US&userType=Consumer .
I hope this helps.
Feb 02, 2011 | Jenn-Air JMC8130DD Microwave Oven
Control locked
Howdy:) Try this:
Microwave - Explanation of the Child Lock Out Feature
Many microwave control panels can be locked to prevent accidental use or access by children.
There are two different ways to lock the control panel:
1. Press and hold the CLEAR/OFF pad for 3 seconds. The display will show "LOCK" and then revert to the time of day.
A small "L" will appear in the corner of the display as a reminder that the control panel is locked. If anyone tries to use the microwave, the display will show "LOCK".
2. On some models, press and hold the 5 and 7 pads simultaneously for 3 seconds.
To unlock the control: Repeat the procedure which was used to lock the control. (Press and hold the CLEAR/OFF pad for about 3 seconds or hold the 5 and 7 pad simultaneously for 3 seconds.)
Farmerbear at FixYa.com
Sep 14, 2010 | GE Advantium 120 Convection/Microwave Oven
I have accidentally locked my microwave oven (profile performance convection oven). I was cleaning the front. Can you tell me what to do?
Got you covered. Here you go:
That info is from GE
Hope that does the trick.
Regards, Farmerbear at FixYa.com
Sep 13, 2010 | General Electric Microwave Oven
When I turn on my oven for cleaning it shows a f9 problem...could you help me with that
An F9 error code on a General Electric oven indicates that the oven's electronic control system has detected a problem with the automatic door lock. The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode. The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
Things You'll Need:
  • Ohmmeter or multimeter
  • Phillips screwdriver
#step1
Disconnect power to the oven.
Step 2
Open the oven door. Remove three screws from underneath the oven's control panel. Lift the control panel straight up to disengage the mounting pins on the top corners of the panel, then tip the panel toward you.
Step 3
Inspect the door lock mechanism. The mechanism is in the lower left area of the space behind the control panel. Rotate the cam on the door lock mechanism to be certain it moves without binding. Replace the mechanism if its mechanical parts do not function properly.
Step 4
Inspect the wires that connect the door lock mechanism to the control panel. Check for pinched or broken wires. Check for wires with frayed insulation. Repair wires as needed if defects are present.
Step 5
Locate the six-pin connector on the door lock motor on the right end of the door lock mechanism.
Step 6
Rotate the cam on the door lock mechanism to the unlocked position. Test the resistance between Pin 3 and Pin 1 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 2 of the door lock mechanism if the resistance reads other than 0.
Step 7
Rotate the cam on the door lock mechanism to the locked position. Test the resistance between Pin 3 and Pin 2 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 1 of the door lock mechanism if the resistance reads other than 0.
Step 8
Contact a certified repair facility if the source of the F9 code has not been discovered.
Troubleshooting the oven with the electric power turned on is a job for a certified technician.
Do not perform troubleshooting on the oven with the power connected. Personal injury and damage to the oven can result.
Aug 04, 2010 | Microwave Ovens
How do I unlock the key pad? The display shows locked and I don't know how it locked.
Here you go.
The Child Lock shuts down the control panel pads to prevent
unintended use of the microwave oven.
When the control is locked, only the Vent Fan and Light pads will
function.
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound
and a lock icon appears on the display. Repeat to unlock and
remove the lock icon from display.
May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave is locked. It says "Keypad touch locked"
Hold lock button for a few seconds and it should return to normal
Apr 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
