Question about HP Jornada 548 Pocket PC
Duplicate alarms I have two alarms set in my Jornada 548 and periodically I get multiple notifications for the same alarm. For example I have an alarm set for 5:45 PM Sun - Fri. At least once a week I will get multiple notifications for the same alarm at one time-many times on Friday I will get two to three notifications at the same time for the same alarm. Any suggestions?
    Master:
  • 450 Answers
I may be off base but might the problem be as simple as the frequency being set for the alarm. What I mean to say is, might the default reminder time for the alarm be set to such a low setting like sec's or minutes leaving the unit to repeat the alarm rapidly prior to your being able to dismiss/snooze. Good luck.
Posted on Sep 14, 2005
SOURCE:
Alarm on notification bar
If you open the clock app and click on the alarm page, you should see all the alarms you have created, if any of the little alarm icons next to them are green it means that that alarm is enabled, tap the icon to turn off the alarm, this should make it go away.
Jan 17, 2016 | Samsung Galaxy S5
Tip
Adding mp3's for the alarm clock.....
If you are like me, you are not impressed with the alarms that came with the hero (sprint). They were too short, and I slept through all three that I had set. However, you can use any of your mp3's as alarms. This is not a difficult process, but it will involve using your phone as an external storage device, and creating a directory on your SD card.
Connect your phone to your computer and through the notifications screen, mount the SD card so you can see it on your computer. Navigate to the /media/audio directory. Inside the /audio directory, create a directory titled 'alarms'. Copy any mp3's you want as alarms into this newly created directory.
Remember to turn off usb storage from the notifications screen.
Go to the clock function, set an alarm, and you should see those mp3's available on the alarm sound list.
Good luck waking up!
on Oct 13, 2009 | HTC Hero Smartphone
Alarm setting
What settings in alarm do you need to set? In case you want to set the alarm time, tap Start >> Settings. Go to System tab and open Click and Alarms, tap on Alarms tap at the bottom and you may set the alarms from there.
In order to set the alarm tone, tap Start >> Settings. Open Sounds and Notifications in Personal tab, make sure that the checkbox for Programs and Notifications is checked. Now go to Notifications tab, in the event select Reminders and you may configure the alarm behavior and ring tone in there.
Please rate the solution.
Dec 14, 2009 | HTC Touch P3450 Smartphone
HOW DO YOU SET AN ALARM? CAN YOU SET MULTIPLE ALARMS?
Hi, To turn on the alarm function in the Clock application on the BlackBerry smartphone, complete the following steps: In the Clock application, press the Menu key. Click Set Alarm. Set the alarm time by highlighting the hour, minute, and 12-hour notation fields and rolling the trackball. Highlight the text beside the alarm time. Roll the trackball and select either ON (everyday) or WEEKDAYS (weekdays only). Press the Escape key. An alarm indicator appears in the bottom left corner of the Clock application. To set alarm notification options To set the alarm notification options, complete the following steps: In the Clock application, press the Menu key. Click Options. In the Alarm section, choose an option for the Alert Type, Alarm Tune, Volume, Snooze Time, and Number of Vibrations fields. Press the Menu key. Click Save.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 11, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
T-mobile dash multiple alarms
The solution is a follows; If you have any legit alarms already set, disable them before proceeding
1) As soon as the unwanted alarm goes off , look at what time your phone says it is and make a note of it. (if you know EXACTLY what time it goes off at, then go to the next step)
2) Goto Start -> Clock & Alarm -> Alarm
3) Set the alarm time for the exact time from step #1. Set alarm to On.
4) Click Done, done, and done
5) Goto Start -> Clock & Alarm -> Alarm
6) Change the alarm to Off.
7) Click Done, done, and done
That's it, the alarm should now be disabled for this unwanted alarm, if you have multiple unwanted alarms, repeat this procedure for each.
Dec 11, 2007 | T-Mobile Dash Smartphone
Is an audible alarm software available?
I'm not sure of the HX4705's capabilities to sound multiple alarms, but I have downloaded a free alarm program called Wolfclock to my iPaq rz3715 which I use for the exact same reasons (meetings, wake up, take medication...) Try this link: http://www.pocketpcfreewares.com/en/index.php?soft=1045
Sep 14, 2005 | HP iPAQ HX4705 Pocket PC
AC Adapter Buzz Noise
The jornada 548 power adapter should not be buzzing - it should be very quiet.
Sep 12, 2005 | HP Jornada 548 Pocket PC
Sync problem w/outlook contact
I use my 548 to keep my work and home versions of Outlook syncronised. I have about 70 contacts stored. Three suggestions.. 1) Do you have enough free memory? Emails can take up megabytes, and for that reason I choose not to sync emails. 2) Are all of your contacts in the same Contacts folder? I have two contacts folders on my home Outlook, one for me and one for my wife, I only sync my contacts to my 548. 3) In Activesync, click on Options, Sync options, contacts, settings and make sure that "Syncronize all contacts" is checked
Jornada 548 won't print to IR on hp 450 mobile printer
the ipaq automatically adjusts for daylight savings but the PC does not. On your PC double click on clock, click on Time Zone tab and then on that screen you will see the box that needs to be checked. also check that both PC and IPAQ are set to same time-zones.
Help setting alarms
To set an alarm for an event: 1. Create a new event or double-click an existing event. 2. In the New/Edit Event dialog box, select the Alarm check box. 3. Click the time interval selector and select Minutes, Hours, or Days. 4. Type a number between 0 and 99 in the Time Measurement box. 5. Click OK. To set a default alarm for all new events: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Date Book tab. 3. Select the Alarm Preset check box. 4. Click the time interval selector and select Minutes, Hours, or Days. 5. Type a number between 0 and 99 in the Time Measurement box. 6. Click OK. Setting Alarm Options You can configure the Alarm Manager settings for the Desktop application in the Alarm tab of the Options dialog box. To set Alarm options: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Alarms tab and click one of the following actions: * Always available: Click this option if you want alarm notifications to appear regardless of whether the Desktop application is running. * Available only when Palm Desktop is running: Click this option if you want alarm notifications to appear only when the Desktop application is running. * Disabled: Click this option if you do not want alarm notifications to appear on your computer. 3. If you want an alarm tone to sound when the alarm notification message appears, click Play audible notification with alarm dialog. 4. Click OK.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
HP Jornada 548 Pocket PC Logo
164 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
