Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Weed trimmer primer bulb does not pump full, and trimmer will run out of gas
  • Anonymous Sep 16, 2008
    replace the 3 fuel lines
  • 163 Answers
Check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
Page 4 and 14 of the manual. A choke is just a device that reduces air flow to the carburetor by closing a flap. You don't pump it, you just move it to the full choke position. I think you may be confusing the 'primer bulb' which pumps fuel from the tank to the carburetor.
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/s430_ry34441.html
To start a cold engine:
? Slowly press the primer bulb 10 times.
NOTE: After the 7th press, fuel should be visible in the primer bulb. If it is not, continue to press the primer until you see fuel in the bulb.
? Set the choke lever to FULL CHOKE position.
? With the throttle trigger at idle, pull the starter handle sharply until the engine attempts to run. Do not pull the starter handle more than 4 times.
? Set the choke lever to HALF CHOKE position.
ryobi s430 4 cycle weed eater manual Google Search
Mar 20, 2018 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Primer bulb not filling
Bulb or fuel line could have a crack or a clog in fuel line/filter or carburetor. Here's a video on how to change the bulb and fuel lines and another video on how to clean/rebuild the carburetor.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
May 02, 2014 | Homelite Mighty Lite Lawn Trimmer
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
My TP30 Ryobi weed eater turns and stays on while
You have a hairline leak in one of your hoses or a small gasket under primer bulb.
Jul 05, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Can,t prime fuel with primer ball on my weed eater XT 400, lots of fuel and lines look good
be sure the line in the tank did not disconnect. that would cause you to pump all you want but never get a drop.
Jul 08, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
319 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
