Question about MSI K8MM3-V Motherboard
Lose of Master Harddrive
System loses track of master harddrive. If system is idle for to long a length of time, the system will try to reboot but will stall. A look at the CMOS and it will not locate the Master IDE but all other IDE items will show. If you disconnect all cable and power connections and reattach it will only then reboot. Got lastest bios update and still have problem. Downloaded harddrive diagnostic program and all harddrives check ok. Only the Master device is affected which is the system drive. Any thoughts. Thanks, Ellis.
  • 983 Answers
Have a check with the BUS cable once try replacing the BUS cable which is connected to the HARDDISK .. there may be some problem in the IDE BUS CABLE...
you can fix that by replacing with the new one ...
this problem is not where related to BIOS ..
because if there is any problem in the IDE BUS CABLE means you will face this problem ..
there is one more case it is not oftenly seen actually ..
ie if there is any problem in harddisk means you will face this problem ..
normally the harddisk will work without any problem for 10+ years ...
in very special cases the harddisk failure occurs which is called as catastrophic failure ie the harddisk makes some hissing noise before when it attempts run , this problem may be due to some manufacture defect or if the harddisk is not being used for a long period of time (may be years) ...
so just have a check with things everything will be alright ..
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Posted on Sep 02, 2008
Wont see slave Hard Drive in a Dell Dimension 2400
Did you set the Master harddrive as master?
Or is your reference that you set the jumper cap, on the jumper pins; of both harddrives to Cable Select?
What are the manufacturer names, and model numbers of the two harddrives?
If you just see something like - WD2500JB, that will work.
How many wire is the Flat IDE ribbon cable?
There are 40 wire versions, and 80 wire versions.
Notice I stated - Wire.
They will both have 39 socket holes that are used.
(40 socket holes, with 1 blocked off)
80 wire IDE ribbon cable has Master harddrive in middle.
Slave harddrive at end of cable.
Little weird, huh?
40 wire IDE ribbon cable, has Master harddrive at end of cable, Slave in middle.
As for, "Computer will not see it."
Not trying to insult your intelligence. Am trying to see if we are both on the same page.............
1) You go to My Computer, and there is no drive letter assigned to that harddrive you just installed?
If it is there, you double-click on it to open that harddrive.
Please post back in a Comment.
Regards,
joecoolvette
Mar 30, 2013 | Dell Dimension 8400 PC Desktop
How to add 2nd hdd to hp 513n
As I recall busy_bee96 the harddrive technology used is IDE. (Also known as PATA)
Let's see if there is information on HP Support;
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07813&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=90384
Yes, if we scroll down to the heading - IDE UDMA Modes, we see ATA 66/100 listed.
IDE (PATA) harddrives are used.
The HP pavilion 513n Desktop PC came with an IDE 60GB harddrive.
I don't know what size Slave drive you are going to install, but there may be a size limitation.
On the back of an IDE harddrive are jumper pins. For the original harddrive these may need to be set to Master.
To perform this function the jumper is placed on the two pins for the Master setting.
These are examples of a Jumper,
http://en.wikipedia.org/wiki/File:Jumperblock-shunts.jpg
Small plastic blocks that are hollow inside. There is a rolled spring clip inside the hollow block, that goes over two pins. Connects the two pins together.
General example of the back of an IDE harddrive, showing the Jumper Pins,
I'm going to use Western Digital's IDE harddrive jumper pin settings,
http://wdc.custhelp.com/app/answers/detail/a_id/463/session/L3RpbWUvMTMxODI2NDI0OC9zaWQvSjEzTHVkR2s%3D
Where it states Dual Master is the setting for the Master harddrive.
Where it states Dual Slave is the setting for the Slave harddrive.
Look at the label on your harddrive, and see if it shows the settings for Master.
If not write down the Model Number, and search it online.
OR, post the Model Number in a Comment, and I'll look it up for you.
It may be where there is NO jumper used on the Master harddrive.
Look up the information for the 2nd (Slave drive) harddrive, if it is not stated on the label.
You need to know where the jumper pin settings should be, when using two harddrives.
Past this point you need to look at the flat ribbon cable.
There are IDE ribbon cables that have 40 wires, and 80 wires.
Both styles have 40 contact pins.
(39 actually. 1 is not used)
With the 40 wire IDE cable the Master harddrive is plugged into the MIDDLE connector, on the cable.
The Slave drive is plugged into the END connector.
With the 80 wires IDE cable, it is reversed.
Master harddrive goes to the END connector, Slave drive goes to the MIDDLE connector.
http://www.mikeshardware.com/howtos/howto_connect_ide_hd.html
These videos may also help;
1) http://www.youtube.com/watch?v=4inX3nC6M1E
2) http://www.youtube.com/watch?v=OMTOgt3UiB4&feature=relmfu
(Ol' James is an Electronic Engineer. The lighting was bright, lol!)
For additional questions please post in a Comment.
(Believe upper right of your page. FixYa is undergoing major improvements)
Regards,
joecoolvette
Oct 10, 2011 | HP Pavilion 513n (P9850A#ABA) PC Desktop
I have just tried, for the first time, using my new 320GB Canvio. The white pilot light comes on, and I feel the disk spinning for a short time, but there is no operating software presented, and no file...
External harddrives do not come with an O/S. They are for external storage, beyond the master harddrive you have installed.
The master harddrive has the O/S.
The Platters are spinning because BIOS had a look to see what is on the Toshiba 320GB external harddrive.
[You press the Power On button. The first chipset to receive power is the BIOS chipset.
(Basic Input/Output System)
BIOS looks to see what devices are connected to the computer, does a Ram Memory count, turns the Processor on, then hands the computer over to the operating system.
BIOS finds THE harddrive with the O/S on it ]
http://en.wikipedia.org/wiki/BIOS
http://computer.howstuffworks.com/hard-disk.htm
When the Windows O/S (Operating System) is installed on a computer is assigns hash values to certain major hardware components in the computer.
A) Processor
B) Harddrive
C) Motherboard. (Motherboard chipsets and BIOS software on the BIOS chipset)
D) Graphics chip. (Whether it is Integrated Graphics, {OnBoard}, or a graphics card)
Change any two of these hardware components and Windows throws up a 'red flag'.
Microsoft's User License states, "One genuine copy of Windows per One computer"
If a hash value has changed, such as there are different hardware components, Windows 'feels' it is being stolen.
Why do you feel there should be an O/S already installed on the external harddrive?
Awaiting your reply please state in a Comment.
Regards,
joecoolvette
Jun 07, 2011 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Hi . I have trouble with Dell optiplex GX280 . In the PATA I have two devices . DVD and HD . Both set with jumper . DVD as Slave and HDD as Master ....But the install os cannot detect HDD . where is...
I don't know where the trouble is without more information.
Some tips/information I will list, however,
1) The master harddrive that came with the computer, and has the operating system on it, is a SATA unit.
Therefore any harddrive installed along with it has to be installed as a Slave drive.
BIOS will look for the harddrive with the operating system on it. This harddrive has to be set as a Master drive. (Primary Drive in BIOS)
Installing a harddrive that is a PATA (IDE) unit, AND a PATA optical drive on the same flat ribbon cable, has to be done accordingly;
A) It depends on what flat ribbon cable you have.
There is a 40 wire cable with a 40 pin connector. (39 actually. One socket hole is not used)
There is an 80 wire cable with a 40 pin connector. (39 actually)
http://en.wikipedia.org/wiki/File:ATA_cables.jpg
http://en.wikipedia.org/wiki/Parallel_ATA#IDE_and_ATA-1
Proper method of connecting,
2) Proper method of using jumpers on an IDE (PATA) harddrive, and connecting the flat ribbon cable,
Regards,
joecoolvette
Jun 05, 2011 | Dell Optiplex GX280 (99301) Motherboard
Slave Harddrive I have an extra harddrive that I wish to install as a slave, unfortunately I cannot at the moment, due to some problems. First, the current harddrive I have is a Maxtor I believe, and it...
Dear soviet guy
these are the jumper settting for both the drives
please check that they are on the right place before if you want to use seagate as a slave try placing the jumpers as mentioned.
Maxtor Jumper Settings
Seagate Jumper Settings
Thanks
GAGAN GUPTA
Mar 17, 2011 | Microsoft Windows XP Professional SP3 Full...
Mother board came with pc with 160 gb hard disk I have added 500 gb hard disk in addition thepc isworking well and it cannot recogognice the extra hard disk and I have to tighten the jumper connection of...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is
Dec 16, 2010 | Asrock P4I45GV R5 Motherboard
How do i install a used hard drive into an eMachines T2341? The hard drive still has information on it. do i set it as master, slave, or cable select? hard drive is an IBM 10.1 gb
There are two possible solutions depending on how your desktop is setup.
#1 install the 2nd hard drive and put jumper to CABLE SELECT. When you start the computer it should now appear in the bios as a SLAVE or 2nd hard drive. If not go to #2 below
#2 Turn system off again and change jumper on 2nd hard drive to SLAVE.
Now when your computer restarts it will appear in your bios correctly as the 2nd drive/SLAVE.
Do not make it "MASTER" or you will be trying to boot up to this drive and it may not work as you planned.
FYI: "Cable Select" means the hard drive determines which one is Master and which one is Slave by where it is on the data cable.
Good Luck
Dec 30, 2009 | Computers & Internet
Jumper settings
If you try to enter in safe mode or at last known config and the laptop reboots or freezes then you need to reinstall the operating system if you want to use that hard drive on hp pavilion a1000n. The laptops have different chipset and XP requires to be the same or similar chipset to boot properly.
Oct 06, 2009 | Maxtor Hard Drive
Help
This kind of device its usually a plug and play thing. are u using it as a slave or a the master disc?? make sure the that u plugged it in the right spot, and that the jumpers are correctly positioned. if this isn't your problem, i would recommend doing a zap on it, and the formatting it
Dec 27, 2008 | Computers & Internet
Wan't boot up
If the dvr isnt booting the harddrive, then the harddrive isnt seated properly in the removeable harddrive drawer, or the harddrive is improperly formated, or you have the wrong type of harddrive, or the master/slave settings on the harddrive are not set properly (master). what ive found is an 80gig/160gig is the most that these things will handle. and some brands work and some brands don't. and the harddrives have to be IDE/EIDE type drives. but it sounds like a harddrive interface problem. They like the older harddrive formatts/(not xp/vista)....good luck!!!!
Oct 27, 2007 | Samsung SSC DVR Digital Video Recorder...
MSI K8MM3-V Motherboard Logo
44 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
