Question about Whirlpool Duet GHW9150P Front Load Washer
F06 error means what? - Whirlpool Duet GHW9150P Front Load Washer
  • 5,911 Answers
"F06" is a motor speed error code. The following link explains the error in detail:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Read through the information thoroughly and perform all the recommended procedures for eliminating possible problems. If you cannot find anything obvious, and if the error code persists, unplug the washer for at least 30 minutes to reset the computer. Sometimes momentary glitches can be "cured" by resetting the control board.
The most common failure for this error code is the Motor Control Unit (MCU). You will need to doublecheck everything, however, to be sure.
Replacement parts, if needed, can be located at searspartsdirect.com. Just type in your complete model number to search for parts. The MCU and Drive Motor can be located under the "Pump and Motor Parts" heading as items number 1 and 16, respectively. For cost comparisons, repairclinic.com also carries parts for your washer and may have them at a better price.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 02, 2008
What is error code F06
The "F06" fault code indicates a drive motor error. This means the control is unable to properly detect motor speed and the machine will shut down.
Mar 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
What do these 2 codes mean on my maytag washer , F06 and E02?
The error code E02 and F06 on a Maytag washer could mean that the hot water solenoid went out. It could also mean that that the hot water control is not working properly.
Sep 23, 2014 | Maytag Washing Machines
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
I have this written in my machine F06 what is that meanning
The F06 code will indicate a drive motor tachometer error.This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes.
The error code F06 is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). Since the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU). I recommend calling a service technician to check the connection.
Hope this helps.
Shane
Mar 15, 2011 | Whirlpool AWM8143 Front Load Washer
Often fails to execute spin cycle with error F06
THE F6 MEANS THE CONTROL IS NOT GETTING A READING FROM THE TACHOMETER ON THE MOTOR. CHECK THE CONNECTIONS FROM THE MOTOR TO THE MOTOR CONTROLLER,(THE CONTROL BOARD MOUNTED TO THE BASE).
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
VCR shuts down automatically after displaying the error code F06
Your vcr seems to use the K Mech. F06 Means that the mechanism locks after unload.
The cause of which might be the loading motor or the carriage alignment.
Apr 13, 2009 | Panasonic Televison & Video
Error code f06
hello fo6 means drive motor techometer error check wire harness connections between the drive good luck
shaun
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
172 people viewed this question
Dan Webster
Dan Webster
Sal De
