Question about Keurig B60 Coffee Maker
My B60 keeps showing Not Ready. And refuses to brew .
No matter what I do. I think it is becaue somehow the setting for auto off got put on it by my friend by accident and I tried to reset without the instructions; which I cannot locate.
  • 8 more comments
  • Anonymous Sep 06, 2008
    Brand new B66 from COSTCO, after 10 cups of brewed coffee, it flashed NOT READY and you can't turn off the machine and it won't brew, DEFECTIVE UNIT ! Customer service said call back monday when someone can help!!!!. Tried all sequences of button pushes to try and reboot it, no luch
    You must unplug it to turn off the display, what a pile of JUNK !
  • Mysomerset Sep 20, 2008
    I started the initial setup and followed the directions. It just keeps flashing "not ready". It did start to get a little warm at first but then it cooled off completely. I called customer service and I was told that someone would call me on Monday to tell me what to do.
  • gpkimmd Sep 28, 2008
    I also just bought B66 at Costco today - did not prime, only blinking "not ready" and none of the buttons respond even when unplugged and replugged. Not even a SINGLE cup of coffee!
  • shaver06 Oct 27, 2008
    I have a b66 from Costco new out the box and when I tried to prime it nothing happened and now it says not ready.
  • Anonymous Dec 25, 2008
    Same problem here.
  • Anonymous Dec 26, 2008
    MY SYSTEM WOULD NOT PRIME AND STAYS ON NOT READY
  • JDMoet Dec 27, 2008
    It primed and after that it keeps flashing not ready. Called Keurig and was told someone would call me back and still waiting. Just called them again and said someone will call me on Monday. So we shall see.
  • WarrenS Jan 14, 2009
    I am eternally Not Ready.  It partially primed and then didn't finish as best I can tell.  No matter what I do it keeps saying Not Ready.
  • bagwmn1 May 05, 2009
    I had a not ready and couldn't do anything. Tried the reset I found on here didn't work. Called customer service. Called me back a day later and offered me $30 off a new one. Mine was only 1.5 years old. Said "no, I want a new one". After getting a supervisor, am getting a new one. Apparently this is a comon problem.
  • Anonymous May 09, 2009
    Ditto. The machine is frozen and the owners manual is silent.
If you need the user guide to help with your problem you can go here: http://www.keurig.com/help/brewerguides.asp
Hope this helps.
For cheap prices on kcup coffee visit:
http://cheapercoffee.biz
Posted on Oct 02, 2008
Do call customer service. i had a similar problem and they're sending me out a new machine.
Posted on Sep 08, 2008
Keurig B60 screen flashes "Not Ready," "Auto Set Off" and "Brew Temp." The machine also will not shut off. Unplugging it does nothing, nor does the reset sequence of button pushing. Is there anything else...
Lots of problems with the B60/65/70 units. There are some really good videos on you tube, but trust me, the process to fix is going to be a pain and cost ~$50. You should consider taking yours back for an exchange. There is a known problem with these models and it appears the retailers are being very generous on exchanges (check this out: http://babelniche.wordpress.com/2012/03/10/keurig-dumps-inventor-builds-millions-of-junk-coffee-makers/) .... Good luck
Nov 22, 2013 | Keurig Platinum B70 Coffee Maker
Turn clock off on keurig coffee maker
Don't use the clock or other features until you read the manual.
Dec 24, 2012 | Keurig B60 Coffee Maker
My keurig is flashing NOT READY and AUTO OFF SET and won't brew or even turn off
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 02, 2011 | Keurig B60 Coffee Maker
My Keurig B60 will not brew. The "ready to brew"
Having same problem with B60 turns off after 1 minute and little circle won't go away.After unit was stored for 5 months, So this is what I did. 1. I took it over to the sink and turned it upside down and shook it. 2. I dried out the whole where the water sucks up and blew through there with a straw. 3. then I sucked water out the rubber tube up top for the over flow. Then I put vinegar in the intake whole and put vinegar in the tank and let it sit overnight. When I got up in the morning i turned it on and after 1 min it shut off again so I restarted it and after a couple minuets it started to heat and my display came back and circle disappeared. Problem solved. Not sure which one worked but it is now working fine and I am now descaling it.
Feb 25, 2011 | Keurig B60 Coffee Maker
Directory shows "Ready to Brew". How do I start
Sorry to read about your problem, I hope this helps you out.
Just hit the big button, its flashing have k cup in and handle down
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
i
Dec 21, 2010 | Keurig B60 Coffee Maker
Our Keurig B60 displays "NOT READY Auto off set" and does nothing. What can we do to bring it back to life?
Press the off/on switch and poof on the machine and then check. If that is not helping then try this procedure as follows:--- 1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen .) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
--------- If this instructions also not helping then try this, instead of holding the medium cup while pushing and releasing menu .you simutaneously push and release medium cup and menu and then medium cup and small cup and then check out. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Aug 28, 2010 | Keurig B100 Coffee Maker
Keurig b60 wont brew
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
Jan 25, 2010 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
3,410 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
