Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
Can a lithium ion battery be overcharged?
Recently I bought a SONY DCR-HC40 camcorder, the SONY BC-TRP charger and an extra SONY NP-FP70 lithium ion battery pack (quick charge battery). I charged the battery that came with the camcorder (NP-FP50) in the SONY BC-TRP charger and, by mistake left the battery in the plugged in charger overnight. 1) Is it possible to overcharge a lithium ion battery by leaving it in the plugged in charger overnight, as I did? 2) According to the instructions for the charger, I can leave the battery in the charger for an hour after the charge light goes out (indicating a full charge) and the battery will charge even more. Are there any disadvantages in doing that? Thanks. Richard
    Master:
  • 473 Answers
Here's a small FAQ I found: 1) My lithium ion battery is the SONY NP-FP70 Battery Pack. Does the fact that the battery is called a battery pack mean that it has built in circuitry to prevent an overcharge? No. I write with some authority since I've dissected too many and there is no such circuit in the battery. From a system perspective it doesn't belong there. 2) Is there any way of knowing if my SONY BC-TRP charger has the circuitry for preventing an overcharge? You'll have to ask, but the key clues are: a. The documention tells you to not leave it plugged in overnight. b. The battery gets too hot and melts the plastic. 3) If I charge my battery in my camcorder (SONY DCR-HC40), can I assume it has the built in circuitry to prevent an overcharge? a. One can't assume anything. b. But from what I read on that model, you plug it in and forget about it. To do that, it would have a proper charge circuit.
Posted on Sep 13, 2005
    Master:
  • 473 Answers
Yes. But a proper charger will not do that.
I have used my Sony Handycam DCR-SR40 and the battery went dead. I then charged the battery several times and still won't turn on. I even attach the camcorder to the Sony base and connect it to the...
This is usually caused by a failed component in the power circuit within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 06, 2010 | Sony Handycam DCR-SR40 Camcorder
Vupoint dv-dv1-vp camcorder needs a new battery
Buy a "np-60" battery on ebay or other store. Some will come with a charger.
You can charge the battery via the usb cable from any working usb port.
Mar 19, 2008 | VuPoint DV-DV1-VP Camcorder
When I turn on the handycam dcr-dvd108 it gives me a blue screen that says cannot use this battery in the camcorder. It is a brand new battery that we bought because it gave me the same message with the...
This camera problem sounds as if the battery is not sitting in it's contacts quite right, check below to see if you have the right one, I think they are mostly grey to fit your model.
Battery Type: Li-ion
Voltage: 7.4V
Capacity: 1500mAh
Color: Dark Grey
Dimension: 44.95 x 31.72 x 43.37 mm
Product Type:Replacement Battery (Brand New)
Replace Part Numbers:
NP-FH30, NP-FH40, NP-FH50, NP-FH60, NP-FH70
May 22, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
NP-FH100
the 'charging' hole is for you to charge the battery. the 'fh' hole is to power the camcorder. no need to put battery on camcorder in either situation but it is convienent to attach the battery to camcorder.
Dec 12, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Konica Minolta Lithium-Ion Battery Recommendation (warning against the use of non-genuine or counterfeit batteries)
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
What is BP-400?
BP-400 is a exclusive external power battery pack for DiMAGE A1 and A2. It can be attached to the body and has portability and movability. It is very convenient for the customers who want to use AA size battery or take a long time picture. One or two exclusive lithium-ion battery NP-400 can be attached. 6 AA batteries; Ni-MH and Alkaline battery can be used. (Nickel dry battery and lithium battery cannot be used. Recording: Approx. 560 frames,continuous playback: Approx. 480 min.(2 pcs. NP-400 batteries) Recording: Approx. 290 frames,continuous playback: Approx. 270 min.(6pcs. 2100mAh Ni-MH batteries) Recording: Approx. 80 frames, continuous playback: Approx. 80 min. (6pcs. Alkaline-manganese batteries) Standard Accessory: Holding Strap HS-2 Optional Accessories: Dedicated lithium-ion battery (NP-400), battery charger (BC-400) INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V 700mA
What is the external battery pack "EBP-100"?
This is the external battery pack used for the DiMAGE A1, 7, 7i,7Hi, 5, S414, S404, S304, Z1, Z2 and A2. This is the type of external battery pack that connects the camera and the battery part with a cord. Taking a picture while keeping the battery part only warm in a cold place. As there is a belt loop at the part of battery, it does not bother to capture images. Two lithium batteries NP-100 Approx. 480 frames(recording), Approx.450 min(playback) Battery Charger BC-100, Lithium ion battery NP-100(2pcs), Battery holder BH-100 Battery Charger BC100 is sold separately. INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V1.1A
What is external battery pack "EBP-100"?
This is the external battery pack for DiMAGE 7, 7i,7Hi, 5, S414, S404 and S304. This is the type of external battery pack to connect the camera and the battery part with cord. Taking a picture while keeping the battery part only warm in a cold place. As there is a belt loop at the part of battery, it does not bother to capture images. Battery:Two lithium batteries NP-100 Battery performance: Approx. 580 frames(recording), Approx. 580 min(playback) Accessories: Battery Charger BC-100, Lithium ion battery NP-100(2pcs), Battery holder BH-100 Optional: Battery Charger BC100 is sold separately. BC-100 specifications: INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V1.1A
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100 For further assistance concerning Konica Minolta products, please contact Konica Minolta technical support by phone or Interactive Q&A or visit our website at http://www.konicaminolta.us Thank you for your understanding and cooperation in this matter. We look forward to your continued support for Konica Minolta products.
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
Sony DCR-HC40 Battery Charging Problem Hi Mates - I did purchase a Sony DCR-HC40 camcorder around an year back and it was working superb till few days back. As of date, i am facing a problem where...
Had the same thing happen to me. Went out and bought a new battery and it, too, does not charge. Apparently something messed up with the in-camera charging system. It will charge for several minutes (charge light illuminated) and then the charge light goes dark. Battery gage shows that there is virtually no time left on either battery (old or new). Anyone have any ideas other than a trip back to Sony?
Sep 14, 2005 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
419 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
