How to Factory reset Firebox X20e edge - Computers & Internet
  • 205 Answers
To set the Firebox X Edge e-Series to the factory default settings:
  1. Disconnect the power supply.
  2. Hold down the Reset button on the back of the Edge.
  3. Continue to hold down the Reset button, and connect the power supply.
  4. Hold down the Reset button. When the yellow Attn light stays lit, the Edge was successfully restored to the factory default settings.
    This process can take 45 seconds or more.
  5. Release the Reset button.
Do not try to connect to the Edge at this time. Before you can connect to the Edge, you must start it one more time. If you do not, when you try to connect to the Edge a web page appears with this message: Your WatchGuard Firebox X Edge is running from a backup copy of firmware. You could also see this message if the Reset button is stuck in the depressed position. If you continue to see this page, check the Reset button, and start the Edge again.
  2. Connect the power supply again.
    The Power Indicator lights and your Edge is reset.
Posted on Jul 31, 2009
How can I reset my galaxy s6 edge to factory settings if phone screen doesn't work at all
burnt pixels...repair or replace is your best option (Pro repair)
Aug 13, 2016 | Cell Phones
Tip
How to hard reset your samsung s7 or s7 edge
How to hard reset Galaxy S7 and S7 edge
Please note that hard resetting erases all the data on your device. Text messages, photos, videos, settings, everything will be removed in the process. So, don't forget to create a backup of your Samsung Galaxy S7 or S7 edge before proceeding.
Also make sure to juice up your smartphone to at least 60% or keep it plugged in during the process. You don't want to have your device turned off when you hard reset Galaxy S7 or S7 edge, or it will create further issues.
Factory reset Galaxy S7 or S7 edge the easy way
  • Open the Settings app.
  • Choose Backup & Restore > Factory Data Reset.
  • Now select Reset Device > Erase Everything.
  • Confirm the warnings and wait for the process to finish.
  • Once done, reboot your phone.
Hard reset Galaxy S7 or S7 edge using recovery mode
  • Power off your device.
  • Wait for a few seconds while your phone is shutting down.
  • Press and hold the Power, Volume Up and Home buttons simultaneously to get into Recovery mode. (read: how to get into Galaxy S7 or S7 edge recovery mode)
  • Use Volume keys to navigate and Power button to select an option in Recovery mode.
  • Once in, from the main menu, using Power key, select wipe data factory reset.
  • If you want to clear app data cache too, choose wipe cache partition. Clearing cache often fixes various software related issues.
  • When done, go back to main recovery menu.
  • Select reboot system now and that's about it.
Hope the above tips help you fix Galaxy S7 issues and bugs.
on Jan 16, 2017 | Cell Phones
How do yuou reset Edge series chairthe quantum Q6
Turning it on and off will reset everything, but I am not sure what you mean by resetting???? The chair is configured for normal operation at the factory and cannot be changed by a layman, unless you buy a hand-held programmer for the particular controller your chair uses. Some/most technicians have these and can change the factory presets using it to reprogram the controller.
May 04, 2014 | Pride Mobility Products Quantum Jazzy 500...
WatchGuard Firebox v 10. How to reset this. No reset button. Has to be by using serial port somehow.
connect trusted and optional with a crossover cable and reboot the box. that will bring it back to factory default setting
Feb 14, 2011 | WatchGuard Technologies WatchGuard Firebox...
Presonus Firebox doesn't sync up.
1. check the drivers update for you device
This is found at the manufacturers site.
2. See if your device is compatible with the OS (operating system) on your laptop.
3. Check the connecting cable to see if you have a broken wire inside the "strain relief".
The cord at this point will have a puffy part that indicate that there is a broken cable.
Apr 16, 2010 | PreSonus Firebox 6x10 External Sound...
I have a Watchguard Firebox x10e and i can not log into it
To recover your Firebox X Edge e-Series device, you must first reset the Edge to its factory default settings, and then FTP the Edge v10.x appliance software to the Edge.
  2. Hold down the Reset button on the rear side of the Edge.
  3. Connect the power supply while you continue to hold down the Reset button.
  4. Continue to hold down the button until the yellow Attn light stays on. This shows you that the Edge was successfully restored to the factory default settings.
To FTP the Edge v10.x appliance software to the Edge:
  1. Copy the Edge v10 upgrade file (yakfw.sysa-dl) to the root of your C: drive.
  2. Edit the network settings on your computer so that it is part of the 192.168.111.0/24 subnet.
  3. Connect your computer to any of the LAN interfaces on the Edge.
  4. Open a command prompt.
    To open a command prompt, select Start > Run. Type cmd and press Enter.
  5. Type ftp 192.168.111.1 and press Enter. When prompted, enter the user name admin and the password admin. Press Enter.
  6. Type bin. Press Enter.
  7. Type put yakfw.sysa-dl. Press Enter.
  8. Type bye. Press Enter.
  9. Type exit. Press Enter.
    The command prompt window closes.
  10. Power cycle the Edge.
Oct 01, 2009 | WatchGuard Technologies WatchGuard Firebox...
I need help resetting firebox firewall password
You can always do a hard reset to the soho, but backup your system settings for this will factory reset the box because it will erase everything!
1) Unplug any devices from the all ports.
2)Unplug power cord.
3)Use paperclip to hold reset button.
4)While continuing to hold the reset button plug the power back in.
5)Watch the status light in front, when it turns on(the red light) wait until it turns back off, then release the reset button.
The whole reset process is about a one minute wait for the status light.
Dec 01, 2008 | WatchGuard Technologies FireBox SOHO 6...
Wireless Config for XP OS with Firebox Edge network firewall
Hi
Any help please let me know and sorry about the chat window not responding for me
Jun 24, 2008 | WatchGuard Technologies WATCHGUARD TECH...
Watchguard site to remote offices
What have you done to date, what is the Config on both sides.
Let me know
Aloha
Bob
Jan 19, 2008 | WatchGuard Technologies FireBox SOHO 6...
Setting up a VPN through watchguard
The key with any VPN solution is to make sure that the configurations on both ends match. I am not very familiar with this particular product, but it looks like you need to have the proper VPN licenses installed first. There are two types of VPN you can do. 1) Site to Site - This is where the are two static boxes that you want to create an encrypted tunnel between 2) Remote User access - This is where mobile users connect to a central site over an encrypted tunnel from their home or on the road. Next, take a looks at the User Guide PDF here: https://www.watchguard.com/help/documentation/soho6.asp Chapter 10 tells how to configure the VPN on the Firebox side. You would just duplicate your settings if your doing option #1. Chapter 11 tells how to configure the VPN on the client side. This section would tell you how to configure the client software for option #2. Hope this helps.
Aug 29, 2006 | WatchGuard Technologies FireBox SOHO 6...
Computers & Internet Logo
4,264 people viewed this question
David Payne
David Payne
