Bulbs blown require s a new bulb for LG 44sz8r-za where can i get one?
Replaced bulb on 44sz8r-za still no picture just sound.
when i press menu i get that on screen.
Posted on Oct 18, 2009
Is there an internal reset button?
The short may have blown an internal fuse.
Jan 20, 2015 | LG LMV1630ST Microwave Oven
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
How do I change the headlight bulb for 2002 lexus sc430
bulb located on the doghouse of whatever side is blown some snap in others require some dissassembly to access the bulb
Jul 07, 2012 | Sylvania 2002-2006 Lexus SC430 Headlight...
Hello, I have a LG rear projection tv model number LG 52SZ8R-ZA that has recently stopped working at 100%. The screen appears alot duller as though the brightness has been turned right down. Is the problem...
Hello, You can get better prices for bulbs on the Internet. I went through this problem with my set.
Sometimes there is an upgrade in bulb Wattage on an individual basis by Model. What you may be having problems with is a system called a "Light Engine". This assembly has the power module and a spinning part called a "Light Wheel".
Your problem then can be from any of these devices. Your old bulb could have a dark spot (As normal light bulbs can develop), a weak power module, or a light wheel not spinning at the correct RPM for clarity.
You can take a chance and try a new bulb yourself or call for a Technician to give you either a "Convergence Set-up" or Evaluation and Repair estimate.
I learned about the insides of these TV's from the Front-Projectors and my own Rear-Projectors which had Warranty Recalls. So I have seen Messed-up and know what it looks like and somewhat about the causes and cures.
If you are getting a Convergence service, you may want to get the Estimate, then install a new bulb through the Internet, and then get it all set up fresh with the new bulb.
Oct 11, 2011 | LG Televison & Video
Blown bulb for a LG microwave oven MS3448XRK what bulb and how do i change it?
Just opened mines today .... guide below is almost correct ....when you lift the cover off the bulb is shielded behind a metal box.... theres one screw that connects it to the magnotron .... take off that screw and pull out the plug with the brown and white cables that is connected to the bulb... the bulb is a T170 KEI 240v 25W on mines at least which no one around stocks so will just try and claim under warranty as 2 years labour 6 years parts... bulb has never worked just never got to opening it up ...bulb looked trashed when i took it off... element was all black and in bits rattling inside the microwave ... only use the thing for warming kids milk and sterilising bottles...
May 25, 2011 | LG LMV2053 Microwave Oven
I have a 50 inch Philips Magnavox LCD TV. It worked fine till the power went out this morning. Everything came back on fine except for my TV. It still receives a signal but it has no picture and no...
The projection bulb came on,but didn't stay on mean the bulb have problems,dosen't mean projection bulb it still good.First must replace a new projection bulb to make sure for the elimation for the projection bulb is the problems.These DLP tvs require new projection bulb every 1 1/2 or 2 years by watching the tv like 4 or 5 hours daily.So there no lost there for trying a new projection bulb alway can save it for later use.The secound could be the board that call the Ballast board have problems too.The Ballast board only job it is to ignite to the projection bulb and make it work.Replace the Ballast board too,if the tv new projection bulb react the same way.
Mar 23, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
For a while there was a whining sound - as if maybe a cooling fan motor wasn't working properly? finally the bulb must have blown, because now there's audio, but no picture. what do i need to do? ...
Hello sir, hi, this requires that projector be checked, to fine the whining sound this requires disassembly, or have the unit checked for loose fan blades by a technician, and find that whining sound. If not replacing the bulb is useless, the bulb will always blow up.
Nov 13, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
Headlight repair on 2003 Mercedes Benz E320
how do you change left low beam bulb on 2003 mercedes e320
Mar 15, 2009 | 2003 Mercedes-Benz E-Class
MICROWAVE LG MODEL MC-806BL LAMP BLOWN
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
In the UK, LG customer support is here. You may find your owner's manual online here.
Dec 19, 2008 | Microwave Ovens
DLP TV Blown Bulb: LG RE44SZ21RD
what kind of tv do you have I need that info so I can help you
Apr 10, 2008 | Televison & Video
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
