Question about Panasonic NV-SJ205 VHS VCR
Panasonic NV-SJ205 Changing Rf ?
My panasonic is set for a rf 38 and needs to be changed as there is already a broadcast channel on that setting.
How do I change the RF setting ?
Ok. This is a really easy one.
All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
This will then display your current rf output.
You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
all the best. Top tech
Posted on Feb 27, 2009
  • 10,594 Answers
You have another option to connect this VCR in Audio-Video input of TV and don't need to change RF output channel any
more.
Regards,
Posted on Sep 02, 2008
Have Panasonic The;37pw5 plasma tv . How do I get broadcast tv?
You will need some sort of digital (ATSC) to analog (NTSC) OTA signal converter (set-top box) with an antenna. The Panasonic TH-37PW5 only has NTSC (in the US) or PAL (UK) tuners. There may be a few low power NTSC stations still broadcasting in the U.S. However, you need to be close to their transmitter to receive the signal. You can use one of the original converter that were available with the government coupon. There are some newer models available. Look at your choices carefully. You will need a converter with RF, composite video or component video output. Any model with only HDMI out will require an additional converter connected between the set-top box and the TV.
The specifications for the TH-37PW5 are available on page 38 of the manual. This is available from Panasonic here: ftp://ftp.panasonic.com/television/om/th-42pw5_en_om.pdf .
I hope this helps.
Dec 14, 2016 | Panasonic Televison & Video
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Apr 09, 2015 | Televison & Video
How do you tune a Panasonic VCR model number NV-HD100 in please
You need to connect the RF ( cable or TV) to the input and connect the output to the TV. Now select the menu to auto scan the channels. The you can select timer to set the channels,time and date.
please find the link below for support.
http://www2.panasonic.com/consumer-electronics/support/Video/VCRs.75427
Apr 05, 2011 | Video Game Consoles & Games
Tried the RF Out setting and now Ican't reset it or even get the STB to respond to set up or anything.
If you changed the RF out channel setting on the DTV converter and now can't see the output of the converter try changing the channel on the TV set. THe DTV converter boxes are designed to output either RF channel 3 or RF channel 4. If you were on channel 3 and changed the converter output to channel 4, you will have to change the TV channel to channel 4 to see it again.
Hope this helps.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Bad reception w/ Panasonic RF-544
I solved the problem, but I did not "fix" the problem. Rather than rig an antenna to the old Panasonic RF-544 radio, I put it upstairs where it has good reception. I put the new Sony ICF-38 downstairs where it brings in the stations I listen to. The advertsizing claim for the Sony ICF-38 is that it has "Good Sound and High Sensitivity." I believe it does have "high sensitivity" because even in the basement it brings in my desired stations. (I am still curious to know if I could have rigged an antenna to the old Panasonic RF-544.) RL
Dec 07, 2008 | Panasonic RF-544 Radio
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
My 83 year old dad wants to hook up a VCR to his television do you have inbstructions?Thanks
ok one normal coaxal lead in goes in to the back of the tv were the areal goes and into the vcr rf out put
the areal from the roof goes into the areail on the back of the vcr
Jul 04, 2008 | Panasonic NV-SJ205 VHS VCR
Changing from RF to digital on Panasonic DMR-ES20DEB
Audio? Video? input? output? Short questions are nice but vital details are helpful....
Lets assume your talking Audio output since those are the only digital settings you can change, but first a little bcakground.
RF would refer only to you video input via the tuner if thats what your referring to it should simply be a matter of changing the input (channel up/down or input up/down).
Your audio output can be changed from analog to digital and vise versa and can be chaged from the Menu(hit Menu when no DVD playing) settings under audio.
Mar 24, 2008 | Panasonic DMRES20D DVD Recorder
Programming panasonic vcr
First, check in the VCR setup and see if it set for cable or off-air/broadcast/antenna (not always named the same).  If it is set for off-air... then it won't tune cable channels beyond 13.  It must be set for cable mode in order to tune those upper channels (mid-band, superband etc.).
I assume you have the VCR hooked up correctly- cable into VCR antenna/RF input, VCR RF/to TV output to the RF/Ant input of the TV.
Oct 15, 2007 | Panasonic AG-1980 S-VHS VCR
Panasonic NV-SJ205 VHS VCR Logo
499 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
