Question about Electrolux Vacuums
Battery needs to be replaced in eletrolux pronto 2 in 1 stick vacum,can i order one
  • 3 Answers
The battery replacement for the PRONTO is not a consumer level maintenance procedure.
However, I just replaced the 4 original EMX1600sS batteries by anotther model with the same specs and my PRONTO is working fine now. The battery model is
Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs
Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web.
There are other similar models available that could be used but have in mind the limitations for the dimensions and capacity in mAh.
The dimensions of the original cylindrical batteries are aprox. 33 mm (1 1/4") X 22mm (7/8").
Anything under those specs should work.
Good luck.
Posted on Dec 08, 2010
  • BenShoemaker Aug 31, 2011
    Actually if you look closely there are 4 more batteries in the unit for a total of 8 (8 x 1.2v = 9.6v). The size of the original EMX1600css are SUB C. You can get 2000mAh batteries like these which will last longer:http://www.all-battery.com/nimh45scsubc2...
Electrolux 2 in 1 Ergorapido stick Vacuum. Motor runs then cuts out after 3 - 4 seconds. Sometimes it will run properly for 10 minutes so batteries are good. Why does it cut our usually?
If the hand held is working correctly (By itself) try pulling up a little bit on the 4 metal connection tabs on the wand. The connection tabs were not making a proper connection on my unit.
Oct 20, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I just purchased the pronto 2 in 1 stick vac, however the instructon manual was not included, how do i change the battery?
When opening the pronto, make sure that you check close to the motor for more cells, depending on the model and voltage you may have a few more away from the ones in the handle...
Mine has 6 cells, 4 in the handle and 2 on the sides of the motor. I'm not certain, but I don't believe there is a model with only 4 cells. Replacing only a few cells would help, but isn't a long term fix
Sep 25, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Batteries are not recharging. Where can I get replacements for Model EL1000 Pronto Vac?
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web. The battery's are in the hand held unit bottom or back side area, you access them by taking out all the screws in the back side of the hand unit.
Jan 15, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Rechargable batteries need to be replaced
you may not need batteries just a new charging plug. if the batteries are damaged all you need to do is replace the handheld part of the pronto, this is where the batteries are located.
Jul 09, 2010 | Electrolux EL1000A2 Pronto Bagless Stick...
Electrolux 2-in-1 Pronto does not hold charge, I believe it's a battery problem. How do I get then replace the battery, since it is located in the hand vac part of the vacumn?
Good luck.
Jun 28, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Can the battery be replaced?
No but there was a recall on the battries, so try calling electrolux usa and they should replace it for free.
Apr 17, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Battery for electrolux pronto stick vac 2 in 1
This battery works perfect too (for your model), take a look on amazon: Amazon com tenergy 2 3a 1600mah nimh. Cheers
Dec 22, 2008 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Vacuums Logo
1,518 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
