Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
REPLACE CHUCK - Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
  • Anonymous Sep 03, 2008
    How to replace the chuck DC920
  • Anonymous Sep 20, 2008
    I removed the chuck/barrel on my dc920 as the 3 position slide was sticking....how can I align the three small gears to replace it?
    Top Expert:
  • Dewalt Master
  • 79,077 Answers
It screws off
Posted on Sep 02, 2008
How do I get the chuck off of my DeWalt DW 117 1/2" VSR Drill Serial #1229?
Open the chuck jaws and look down inside the chuck. You will see a screw head that is holding the chuck to the drill. Once you remove the screw, the chuck should pull off easily.
Jul 31, 2014 | Dewalt Drills
Aeg chuck 18 volt
yeah, you'll need to replace the chuck. to remove the chuck generally takes a special tool.that fits between the drive and the chuck, that keeps the drive from spinning when you unscrew the chuck, this tool varies by manufacturer,
Oct 21, 2013 | Drills
I can't release the bit from the chuck.
If it is jammed then hold the bit in a vice and try to knock the chuck off with a cold chisel or suitable piece of brass. then you can remove the chuck screw and replace the chuck. You should not be able to see the bearings underneath.
Jan 27, 2013 | Black & Decker 18 Volt Cordless Drill...
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
How do I change the chuck on my milwaukee right angle 1/2" drill? It has snapped off behind the chuck
Take digital photos when taking the front metal gear box off the drill. Next carefully remove the two plastic halves of the drill if needed to gain access to the shaft that holds the chuck.
Replace the broken threaded metal part that the chuck screws onto.
Normally chuck replacement involves unscrewing the small screw deep inside the chuck on a metal shaft has a left hand thread. Next use a large allen wrench tightened in the chuck with a mallet to loosen the bad chuck. Reverse to install new chuck.
Feb 01, 2011 | Drills
How do you remove the chuck of 18 volt cordless drill?
lock an allen key in chuck,,chuck has l/h thread so turn chuck anticlockwise to remove
Jul 07, 2010 | Craftsman 19.2V C3 DRILL/DRIVER
Remove chuck and replace on DeWalt DW959
the chuck is retained by a screw in the center of the chuck.open chuck jaws wide.use a vise or pipe wrench to hold chuck.
Oct 15, 2009 | Dewalt Drills
Chuck broke on Skil hammer drill
As long as the new chuck threads onto the old spindle then any chuck will work fine.
Dec 19, 2008 | Drills
Drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
114 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
