Question about Belkin (F5D5231-4) Router
Connection problem I recently bought a compaq laptop and want to add it to my home network. I can't. I have 3 computers and 1 laptop already linked to my wireless network and have tried many ways to connect, removing security etc. I have a Belkin N1 mimo wireless router. What am I doing wrong?
    Scholar:
  • 53 Answers
Don't shout at me, but many of the older compaq laptops did not come with a wireless nic installed, and the ones that did sometimes did not support G let alone N.
If able you need to check that the Wireless NIC if installed/avaliable supports your wireless router or most likly the otherway round.
firstly I would try removing any USB wireless adapters that you may have in use from one of your other computers and try it in the compaq, if sucessful you know that it is not your setup of your home network at fault.
Posted on Nov 04, 2008
I cannot set up an ad hoc network.. i also cannot connect to an ad hoc network with WPA security type.. it says that the capability of my network adapter does not match the requirement of this...
Recent computer devices are wireless compartibilbles least requiring network adaptors to establish. Ascertain the computers recent innovations also from where enabling the Wi-Fi features capturing available peripherals. For example, ascertain that another device from where networking requires establishment has wireless feature from where computer recognizes. Where each device are wireless compatible would recognize requiring passes to communicate with network structures. In a situation that one of the device has password sets, would require ascertain what entry passes makes connectivity. For example, networked computer already established requires verifying from network administrator to capture another device on the structures. Also, condition where the computer devices are prior innovations would require modems or adaptor devices or routers to complement the network structure or signal sharing. Such a situation requires ascertain the host computers as the administration point from where passwords are distributed to each device peripherals.
Mar 12, 2011 | Computers & Internet
My computer does not detect wireless carrier networks as I can do to find them already?
Hi
To find your wireless connection, do the following steps
1. Start - Network Connection and then click
2. See whether there is any connection is active
3. If you don't have a connection, you have to add a new connection follow as per your manual
4. Check your wireless router password and signal strength
Still cannot find the solution, reset your wireless router in your laptop.
Thank you
May 14, 2010 | Computers & Internet
Network and wireless was not detected
Hi i understand the importance of your problem
there could be 2 reasons for your issue
1) Wireless Switch of the Laptop is off (Wifi is Off)
it is located somewhere on the edge of the laptops
or Fn+F2 might turn the switch ON and OFF
2) The setting required to configure wireless connection
Check the following steps
Windows XP
1. Click on the Start Menu, and click on Control Panel.
2. Find and double-click “Network Connections” to open up the list of connections that your 3. computer uses to connect to the internet.
4. Right click “Wireless Network Connection” and select “Properties”.
5. Go to the “Wireless Networks” Tab
6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
7. Click “Add” to add a wireless profile.
* Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
* Uncheck the box “The key is provided for me automatically”.
* Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
* Push “OK”
# Open Internet Explorer (with the computer connected to the Router)
# Enter 192.168.1.1 into the Address Bar, push Enter
# Leave the User Name field blank
# Under the password field enter “admin”
# Click “OK”
# Click “Wireless”
# Click “Basic Wireless Settings”
# Enter a desired name into the “Wireless Network Name (SSID)” field
# Write down your Wireless Network SSID, it will be used for later.
# Click “Save Settings”
For WEP:
* Click “Wireless”
* Click “Wireless Security”
* Select “WEP” in the “Security Mode” field
* Bubble “1” under the “Default Transmit Key” field
* Select “128 bits 26 hex digits”
* Enter a desired passphrase into the “Passphrase” field
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field on paper, and store it in a safe place. THIS IS YOUR WEP KEY, it will be needed later on.
* Click “Save Settings”
Jan 01, 2010 | HP Compaq Presario F500 F700 and G6000...
I recently bought a linksys wireless router i've
Make sure your wireless feature is turned on on the computer. There may be a switch on the edge of the computer somewhere, you don't say what kind of computer it is.
Find the wireless connection wizard on your computer and run it. Find it in your network folder in the control panel.
If this is too much, post a comment to this question and we will back up and start over.
BTW, if your laptop has a ethernet outlet (looks like a big phone jack), you can wire your laptop to your router.
I want to help you with this problem
thanks
Dec 08, 2009 | Linksys Wireless-G Broadband Router
File sharing isn't happening
You need to go to control panel and into system, Click on teh Computer name tab and give each computer it's own name if it doesn't have one already. Then click on the change button and give your workgroup a name. Make all computers part of the same workgroup.
Oct 04, 2009 | Dynex 5 Port 10/100 Ethernet Switch...
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Windows networking issue
all computers must have same workgroup name and diffrent descriptions and names. try to use set up home and small office network in every computer. its located under control panel network connections if u put there all the same workgroup names and diffrent descriptions and comupter names
Jan 21, 2009 | Learn.com Windows XP Networking Tutorial...
Help please....printer name does NOT appear
You must have a network set up, and you must enable file and printer sharing on the desktop. The laptop and the desktop should be in the same workgroup. Some firewalls will cause this problem.
Start with the network setup wizard in Settings/Network.
Jan 25, 2008 | D-Link NETWORK CARD DFE550TXREF Network...
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Belkin (F5D5231-4) Router Logo
125 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
