Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
Canon EOS Rebel XS - won't turn on, unless I remove the battery first. How to correct problem??
  • Robert Sauv? Aug 04, 2011
    I would like a second opinion.
  • Robert Sauv? Aug 05, 2011
    I'm in Canada - so I will have to send it to Sun Camera in Toronto.
    Thanks for your advice.
    My battery was good, tried another battery, but that didn't work.
Cannon rebell xs bump turn on it did earlier but after the battery died and I recharged a different battery it won't come back on
Posted on Oct 10, 2019
  • 10,319 Answers
It seems that the most common cause is a battery that isn't working quite right, it may accept a charge but may still not be working right.
Take it to a camera shop and ask if they have a battery you can try in the camera. Even if that doesn't work, if it's a good shop you may get some good suggestions
Posted on Aug 04, 2011
  • frank thomas wilson
    frank thomas wilson Aug 05, 2011
    keh.com repairs this model at a decent price
  • Canon Master
  • 19,396 Answers
Hi.
Test using a different battery. When it does like that it is often the battery shorted inside. If the problem occurs using a known-good battery, then the contacts in the battery slots or the circuits behind the contacts have a short. When there is no battery the shorted wires or contacts are not "hot" and the short does not prevent the camera from starting.
If the problem is not the battery the camera must be disassembled. In that case disassembling will start from the screws on right hand side (watching from front), then screws in front, then left and back. Unless you have done similar repairs before it is advisable not attempting to disassemble the camera. The camera is very easy to damage. There are springs, wires and tricky parts near to shutter button on top, selector wheel and strap holder. If problem is camera and not the battery you can get a good quote on repair here:Repair.
Regards.
Ginko
SOURCE:
Tip
Canon Rebel XS Firmware Update MAC Models: Canon EOS Rebel XS / Canon EOS 1000D...
Solves: BUSY Error & Error 99
Doesyour Canon EOS Rebel XS / Canon EOS 1000D suffer from either of thefollowing error messages that prevent it from normal operation?
  1. Some cameras may exhibit a phenomenon in which theLCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. Themessage, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears onthe camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from theactual language setting.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems.
To download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware upgrade, click here.
I hope that helps.
__________________________
Follow this link to download the Windows version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
Follow this link to download a pdf version of the firmware installation instruction guide.
Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
on Apr 15, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Tip
Canon Rebel XS Firmware Update WIN Models: Canon EOS Rebel XS / Canon EOS 1000D...
Does your Canon EOS Rebel XS / Canon EOS 1000D suffer from either of the following error messages that prevent it from normal operation?
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
To download the Windows version of the Canon EOS Rebel XS / Canon EOS 1000D firmware upgrade, click here.
I hope that helps.
Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
Canon Rebel XS has stopped recording images...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS .
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Apr 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
My Canon 1000D won't operate even when turned on. There is power somewhere because there is a lighted display in the viewfinder and it flashes busy
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Apr 06, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
My camera wont turn on. The battery is freshly charged, it is installed properly and the battery compartment door is shut correctly. At one point the flash would come up, but no display on the lcd and the...
I hope that helps.
Mar 25, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Camera saying busy
I hope that helps.
Jan 20, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Rebel XS was working fine... yesterday, all of a sudden, the LCD screen went blank and it displays 'busy' when trying to take a picture. Recharging the battery and replacing the sd card didn't change...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
I hope that helps.
Nov 30, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Camera has no display, appears to be locked up, shows busy through veiw finder, otherwise focus ok but no picture taken. Battery and SD card ok.
I hope that helps.
Nov 29, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon 100 d screen is blank seems to be frozen when trying to take a pitcure flash will pop but will get busy sign battery fully charged
I hope that helps.
Oct 10, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
381 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
