Cannot switch btvision box off - Televison & Video
  • Anonymous Oct 23, 2008
    Cannot switch off BT Vision box using remote, also channel button will not switch channels
I had the same problem,i changed the batteries and it then worked ok
Posted on Nov 04, 2008
Btbt com help btvision
BT Vision uses Freeview plus catch up TV. Freeview requires a retune because they are making way for new channels. Retune the DTV part or your BT Vision box.
Sep 05, 2014 | Televison & Video
Bt com help btvision
contact bt vision its a free service you have to push some of the buttons in a particular sequence only they can tell you
Jan 14, 2014 | Computers & Internet
Setting up btvision+box
call to helpline no given in your service manual or in broucher.....come along with device....they will guide you for the same or send some technician to fix it
Dec 18, 2013 | Lands Phones
My home was built in 1906 and there is only 1 white wire and 1 black wire in the existing outlet box. I am installilng a Combo Switch and Receptacle device and I'm able to get the switch to control the...
Receptacle needs 1 Hot wire and 1 Neutral wire to complete circuit.
It sounds like you have 1 Hot wire and 1 Load wire but no Neutral wire.
Neutrals are not always present in switch box.
As a general rule, if a switch box has Neutral wires, they are twisted together and covered with wire nut, and then pushed to back of box.
Every receptacle box has Hot and Neutral wire. Hot connects to brass screw, and Neutral connects to silver screw. The two wires together complete circuit when you plug in a lamp.
So each receptacle box has Neutral wires, and you can get a Neutral wire from receptacle box and bring it over to the switch box. This work takes every tool and probably touch-up paint.
Here is a link showing how to drop a wire down to your switch box:
You have to tear out old switch box, and then install 'old work box.'
Old switch box is nailed into 2x4s. Pry box out a bit, then reach in with hacksaw blade and cut nails.
http://waterheatertimer.org/Install-owb.html
Here are two more links that show basic 240V and 120V circuits:
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on electric.
Jan 02, 2011 | Cooper Wiring Devices Combination Switch &...
How do you wire a GFCI light switch and outlet combination? There are 2 black wires coming out directly from the back of the switch side.
If I understand correctly, you are replacing a single switch that has two wires.
You want to install a switch/plug-gfci similar to one shown below.
You are working on wires inside a box:
To wire this kind of device you need at least 2 cables entering the box.
Each cable has a black-white-ground wire.
Cable 1) One cable comes from breaker box. This is the Hot cable
Hot cable has black-hot-from-breaker & white-neutral-from-breaker
Cable 2) One cable goes to the Load (light, fan motor). This wire is controlled by the switch. This is the Load cable
Load cable has black-to-load & white-to-load.
Leviton combo GFCI and Switch
There are 2 screws on either side of switch
There are 2 screws to either side of plug
There are two wires on back of device
2 screws on either side of switch: there is a brass-colored screw and silver-colored screw.
Black-hot-from-breaker connects to brass colored screw on side of switch
White-neutral-from-breaker connects to silver colored screw on side of switch
2 black wires on back of device
Black-to-load connects to black wire on same side of switch as brass-colored screws
White-to-load connects to black wire on same side of switch as silver-colored screws
2 screws on either side of plug
These screws are used when your box is a 'junction' box that feeds wires forward to another box ... for example you have 4 receptacles in a room, the cable enters first box and then goes to the next box and to the next box. Suppose your switch was one of the boxes. Wire arrives from a previous box (this is the Hot cable, every box has 1 Hot cable). Your switch box sends one cable to the Load (light, fan etc), but it also sends another cable to the next box which has a receptacle or another switch.
If your box has a third cable that feeds forward to other boxes, then the screws on either side of plug are used. The black-to-next-box goes to brass screw. The white-to-next-box connects to silver screw.
And all further boxes and devices are protected by the GFCI device.
If you need more information, please answer back and I will help.
Oct 24, 2010 | Cooper Wiring Devices ACE6001V-K "ACE"...
Can i use talktalk with btvision
If you mean can you run the BT Vision service using a TalkTalk broadband connection, no you cannot.
BT Vision runs on BTs network only, it speaks to its own servers which you wil not be able to connect across another ISPs network.
Nov 14, 2009 | Compaq Computers & Internet
Have a problem
Currently, your switch box likely has several inputs, which as you said are occupied by your DVD Player, XBOX, and your television source. The output of the switch is then fed to your TV.
What you will need to do is insert the DTV converter box BEFORE the switch box. If you have an analog antenna on your TV (rabbit ears) you will need to put the converter box between your antenna and the switch box (the cables, not the box itself) so that your wiring goes like this:
Antenna ---- converter box ---- Switch box
XBOX ---------------------------------switch box
DVD -----------------------------------switch box
And the switch box still goes to the TV. However, you do not NEED to use the converter box until February of 2009.
Jun 11, 2008 | Insignia Digital-to-Analog Converter for...
HELP WITH REMOTE CONTROL
Remote codes
http://www.remotecentral.com/index.html
Feb 22, 2008 | Televison & Video
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
