Question about Abit BE7-RAID Motherboard
Startup problem hello when i start my pc in the morning there is no beep cpu fan is running,lights are on but no post. after 5 to 10 minute letting it run like that if you shut down from the power button then on it. The pc starts fine. I tried swapping everything psu, memory, battery bios update nothing work. can you help Thanks in Advance Faruk Vakil
  • 781 Answers
It has to be your M/board battery.
I had a similar problem and fitted another M/board battery and it fixed it
What is happening when you first turn it it on and it does not start and leave for 10 mins then reboot the battery has slight charge enough to boot computer
I would ensure you M/board battery is fitted correctly and that the fittings for it are good
Posted on Sep 02, 2008
I turn laptop on an screen is black... fan comes on power button lights up but no display
Do you get any beeps when the laptop starts up? There is a POST (Power on Self Test) routine that attempts to diagnose startup problems and send beep codes (pattern of short/long beeps) before the main programs start up. If you get any beep codes, you can search for your computer model with 'POST codes' added if you have access to another computer. That might tell you what was wrong. Also try disconnecting from AC and removing the main battery for 15-30 minutes and then put both back on and see if you can get any different response from the laptop. Watch for any other activity such as the hard disk light or WiFi LED lighting also. If you don't get any response other than no startup, a tech would have to diagnose the problem from the motherboard.
Jul 24, 2014 | Computers & Internet
Dell VOSTRO 460 beeps during startup and will not startup.
many times if the fan over the cpu chip on the motherboard fails to run or blow, an beeping alarm will begin and PC will not start. the cpu has to be kept cool so if fan fails the startup is stopped. have found lose wire connections from fan to motherboard terminal, or power supply may be blown, try checking those first. if nothing lose then wiggle those wires to see if the fan starts.
Jan 30, 2014 | Dell XPS 200 PC Desktop
Computer wont boot, the fans keep running
Does it come with any beep sound, because beep sound clarify the fault. Check it by the way.
The list is given below.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Compaq Presario S4040SE - (refurbished)...
T6528, when trying to power up, no video, no beeps, cpu and case fan run at full speed. Tried removing memory, no beep at startup. PC was working fine before, and fans only came on when necessary. Some...
If there was a video error generally you would get beeps that are similar to removing the memory.
when this happens you are looking at a failed CPU or Motherboard. For the system to get to the POST it has to get past the CPU hence you have no beeps.
First thing would be to clear the bios and cmos. use the jumper and remove the battery.
If clearing does not work then you would remove the cpu, turn the system on, then off. then reseat the cpu and try it again (remember heatsink as well never turn a system on without the heatsink on it)
Jun 29, 2011 | E-Machines T6528 PC Desktop
Power on but no display processor fan running power switch light off
Power light possible means nothing, maybe a burned out led.
No display: Try feeling the cpu heatsink to see if its getting warm. If it is cold after 15 minutes running, the CPU may have failed. If warm, move onto the graphics. If using onboard, try using an aGP card and see if you get a display then.
(I'm assuming that you get a beep on powering up? If you get no beeps at all, confirms CPU is at fault, if 8 beeps on start up, probably graphics. any other beep codes, post them and I (or somebody else will help)
Dec 28, 2010 | PC Chips : PC-Chips M909G P4 /FSB...
Computer won't start up ,makes beeping for 4/5 times then fan kicks at super high speed . worked just fine in the morning and then moved to another room and this started..HELP
check that all your plugs are in the correct sockets 4 or 5 beeps indicates startup hardware error usually the keyboard. hope that helps. let me kmow how you go.
Dec 27, 2010 | Dell OptiPlex GX280 PC Desktop
Fans run at high speed , blue light comes on, i get no video.
OK, firstly., if the fan runs at hight speeds, it is an indication of the CPU overheating.
If you do not get any beep codes, Your motherboard might also be damaged.
Let me know if you are getting any beep codes.
Also, if the CPU is blown, you will not get any video, because the CPU is not processing anything.
please let me know if you are receiving any beep codes, so we can start troubleshooting.
Kind regards
Sep 10, 2010 | Dell (E210882) Motherboard
Computer does not fire up. I do have steady green light on power supply. All motherboard connections appear to be tight.I have come home before to a beeping noise in the past. After resetting the machine...
That beeping noise may be due to over heating.
Most machines today have a temperature setting that will turn the machine off once the temperature reaches a certain point.
Safety feature to avoid damaging your cpu and components.
The shut down and restarting allows the CPU to cool down briefly.
Thus allowing you to start the machine again. Usually it will shut down again once the temperature threshold is again reached.
Good test is let the machine sit for 30 min. If it immediately starts up and shuts down a few minutes later. Heat build is usually the problem.
Typically this is due to heat sink or Fan on the computer CPU.
Check to be sure both are connected to the CPU and functioning.
If you have a fan on top of the heat sink above the CPU. Make sure it is working correctly. Dust build up over time will eventually kill the fan bearings or reduce airflow. Heat sink can and will become clogged with dust also. Replacement fans are easy to find. Heat sinks are even easier to clean.
Depending on your machine and CPU position replacing the fan can be a challenge. But can be done in a few minutes with minimum tools.
Each bios has different post codes and it is difficult to tell what is happening with out knowing the bios of your particular machine. Listen for the beeps and check your computer manual.
You can also google for this. Here is a web site that lists a few bios P.O.S.T codes.
Once you know the beep sequence you can look it up. Usually points to the problem and you can go from there.
Oct 06, 2009 | Computers & Internet
The desktop won't reboot. The power light stays yellow. I hear a fan running, but the monitor says no signal.
If your fan runs and the hard drive spins up, then you have a video card problem.
I'd do this: Disconnect everything inside the case but the CPU, memory, and video. Now try to boot. Also observe the fan on the CPU--does it spin?
If this fails, then your video has probably gone bad. Also--does your computer usually give you a "beep" when it starts up? If so, is it giving you a beep now? If not, you're failing the hardware startup test (POST).
So, your problem may be the video card. If your video is part of the motherboard, then you need to replace the motherboard.
Oct 01, 2009 | Computers & Internet
When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
Nov 07, 2007 | ASUS A7V8X Motherboard
Abit BE7-RAID Motherboard Logo
204 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
