Question about Samsung LN-T4671F 46 in. LCD Television
Connect PC to Samsung LCD series 550
I just bought a Samsung LCD 550 series TVand the salesperson had me buy a VGA cable so that i could hook it up to my PC I have now hooked it up but nothing happens, I'm not sure if I need something else...but I'm sure I need someone to walk me thru this process.
Thanks Mary
  • Anonymous Mar 23, 2009
    I have the same problem. I tried to to change the pixel size but that didn't help. Need help thanks
    Brian
For vista connect PC with lcd through cable that used with small LCD press right click on your pc disc top choose display setting from personalize then choose you will find 2 screens choose no.2 make resolution to the maximum select this is my main monitor and thatis it
A.Ramzy Cairo Egypt
Posted on Mar 23, 2009
  • 21 Answers
Check the source button, choose PC mode
Posted on Sep 06, 2008
Cable
I tried to connect my PC with LCD TV using an HDMI cable.
PC did not detect my TV; however everything works fine with VGA cable. VGA cable is the perfect choice.
Jul 08, 2013 | Toshiba Satellite L305D-S5974 Laptop
I have an ACER Aspire laptop that i would like to connect to my Samsung Series 5 500 tv but in the manual it only explains how to connect a PC how do i hook up my laptop to my tv?
Look for a VGA output on your laptop. You will also need a VGA cable. Also there are function keys along the top of the laptop (should have a small display icon) that you need to set to route the video signal to the external VGA connector.
Jan 13, 2011 | Samsung Televison & Video
Trying to hook up my laptop to my philips HDTV....got a vga coverter to a HDMI cable to the TVand have nothing...Do I have the wrong cables or something?
I would try using the standard VGA first, set up the picture speed and size first though. Take a look at the specification of the Plasma and match your PC to it. You will not gain much from using an HDMI upscaler. When you have a pisture then convert VGA from the PC to HDMI and at least you will know what is not working then.
Hope that helps.
Dec 10, 2010 | Televison & Video
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
Trying to connect laptop to Samsung HD LCD TV using VGA cable.
I had the same problem with my Samsung series 6 32" Lcd. After many hours of trying different settings and banging my head on the wall I found the solution. What the problem is your VGA cable not supporting the high resilotion of your Samsung TV. The simple solution is to buy a new VGA cable that supports HD. Take a look at this site you need something like this one! Hope this helps.....C
http://www.clearly-av.co.uk/PGM1110.html
Sep 19, 2009 | Philips 32PF7421D 32 in. LCD HDTV
How do i hook up my hp dv6500 LT to my hdtv?
for connectin it to TV u need a cable for it. like say HDMI cable. It comes very costly. and u should be havin a LCD tv..
Sep 03, 2009 | HP Pavilion DV6500T 15.4" NOTEBOOK LAPTOP...
Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Jul 21, 2009 | LG 22" FLATRON LCD Monitor
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Feb 24, 2009 | InFocus VGA Cable - 15 pin male-male, 4...
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Jan 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LN-T4671F 46 in. LCD Television Logo
559 people viewed this question
Henry  Thomas
Henry Thomas
