Question about Samsung Televison & Video
Hello I just purchased a Samsung LN 32A450 32" LCD HDTV. What should I have in terms of wiring to hook it up? I have a Comcast box, and I will be hooking up a HD DVD player as well. Carol Ouellette carolineat203@comcast.net
5 Suggested Answers
  • 30 Answers
SOURCE: 42H81 -- display's all green
Check to see that none of the component cables came out...
Posted on Mar 27, 2006
SOURCE: Comcast Remote Control Code
comcast sucks and its tech support are a bunch of idiots. the book that comes with the remote is wrong (and for some reason no one in tech support knows this). the remote requires 5 digit codes and all the codes in the book are 4. typing the number 1 in front of any of the codes in the book, for any device and manufacturer, should fix this problem.
Posted on Dec 07, 2008
abhishek33
  • 1239 Answers
SOURCE: MITSUBISHI 65 INCH HDTV, GREEN LIGHT BLINKING, WILL NOT POWER UP
There are four (4) caps on the 'DM' board that need to replaced. Parts: 680ufd 16 volts, orig are rated at 1,000 ufd.
Posted on Jan 07, 2009
arquetteg
  • 37 Answers
SOURCE: HD Picture is Scrambled, but Has Sound
A Sure fire way to fix this is to see if your cable box has a HDMI output and your TV has a HDMI input. If they both do , get a HDMI cable to solve your resolution issues. A plus for this also is better signal quality than component cables. Also, the HDMI carries audio so no need for the RCA cables.
If your cable box does not have a HDMI- go to Comcast and trade it for on e that does. Should be free.
Posted on May 27, 2009
Slinteriors
  • 8617 Answers
SOURCE: RCA D52W20 52 in. Rear Projection HDTV has lost
Sounds like you have a defective Red CRT drive board. Heres where you can get a replacement one.
http://servicemanuals.vstore.ca/product_info.php/pName/itc222-red-crt-drive-board/cName/rca-parts
Posted on Jun 14, 2009
2004 hlp4663w component and hdmi signal error message
Chances are the analog board ( One with the Inputs) need replacement. You can get one at the following link. www.tvrepairworld.com
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
When i hook my comcast box up to my samsung hln467w tv the picture is blue with flashes of green and fuzz
First of all what output/input are you using for video for the comcast box? Have you tried using a different output? When you connect a dvd player or a different source does it work? First thing is to figure out if its a problem with the tv or a problem with the box. If the tv works fine then you have to figure out the problem with the box or the connection between the two. once I have more information I can assist you further.
Thank you,
lee
Nov 07, 2009 | Samsung HLN467W 46" Rear Projection HDTV
HD TV - Comcast - Samsung TV - "Component 3 not supported mode"
Hello willardlang,
This is because of the type of Component Video being used. Let me explain We got so use to the term RGB to explain component video we for got that there are two standards for component video and they are not compatible. These two standards are Component Analog Video (Y, R-Y, B-Y) and Component Digital Video (Y/Pb/Pr) or (Y/Cb/Cr)
Now, the problem is they never told us the public which one to use and when, they only told us RGB. Now to complicate things, you have have to figure out which one to use. So here is a helpful yet flawed hint:
If the TV was made after 2003 use Component Digital Video (Y/Pb/Pr) or (Y/Cb/Cr)
If the TV was made before 2003 use Component Analog Video (Y, R-Y, B-Y)
Yes this is flawed but for the most part it's good.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 02, 2009 | Samsung HLN5065W 50" Rear Projection...
Comcastt HD Box indicates "Component 3 - Not supported mode"
Try HDMI if the TV has the inputs or swap the component cable.
Samsung LN-T4065F
clicking sound coming from television
Jun 18, 2009 | Samsung HCN4226W 42" Rear Projection...
NO SOUND FOR TV BUT I HAVE SOUND ON DVD
the bose has to be hooked up to the cable box output and video 1 on the bose. This is the only way it will work
Nov 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
My hdtv component jacks will give a clear pic then pop back and forth into double images. Can anyone help?
Oct 03, 2007 | Philips 60PP9202 60" Rear Projection...
Hd signal not being picked up
your comcast box is not hdcp compliant.this signal tells the tv it isok to display the image.It is similar to video copy guard
Oct 30, 2006 | JVC AV-48P775 48" HDTV
Televison & Video Logo
29 people viewed this question
cce772000
Level 1 Expert
