Question about Maytag Washing Machines
I own a maytag epic z front loading washer and dryer and when i wash clothes they never get all the way wet and i end up having to rewash them. Im not sure what else to do.
    Genius:
  • 1,028 Answers
Ck to be sure drain hose is not more than 6-8 inches in standpipe top of standpile nees to be 30-36 inches above floor and drain hose should be too snug in standpipe ..any of above conditions may result in water siphoning out and not leaving enough water in tub ..washer only uses 5-6 gals per fill based on load so if water is being siphoned out doesn't leave much left
Posted on Sep 03, 2008
Cloths are wet after spin cycle
ceck for kinks in the drain hose .if you have a wet vacuum try sucking on the drain hose, or fallow the drain hose into the back of the unit to see if there is a blockage or a belt off .. jay florida
Nov 23, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have a MayTag 4000 series washing machine that is 6 month old. Sometimes the water pump is working but then it does not spin. Then one hour later the washing machine finishes the cycle but the clothes...
the problem with the washer is simply the panel or it might be the belt if the machine is not direct drive machine or call ur technician alson to run a check on it
Jun 28, 2011 | Maytag EPIC MFW9700S Front Load Washer
Clothes are very wet at the end of the washing cycle
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Clothes are still very wet after cycle is over on maytag epic z
u might want to check your water pump take off that bottom panel there are 3 t20 troque bits at the bottom the pump should be in front then u take off the filter on the pump becareful its plastic and check to see if there is any objcets in that filter and check your drain hose two if that does not help u might have to replace the pump... good luck
Feb 08, 2010 | Maytag EPIC MFW9700S Front Load Washer
Epic washer doesn't spin fast. spins, but slowly. clothes coming out wet, very wet. it started after i washed a heavy wool sweater.
Check the filter, make sure rinse hold is not on, check the drain hose is not blocked, lastly check the brushes, remmember unplug first.
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
My clothes are wet at end on my maytag neptune washer machine
If you are spinning them on the highest setting try to put it on medium. Sometimes the highest setting is too fast and it will bang around and not spin properly. A lower setting will work better and the clothes will still come our dryer.
Sep 14, 2009 | Maytag Neptune MAH6500A Front Load Washer
Stains on clothes coming out of the LG washer
are ther brown stains if so the bearings are faulty.
Jul 07, 2009 | LG WM2455 Front Load Washer
Maytag washer
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Mar 31, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Disposable diapers
should resolve itself with repeated rinses
Oct 18, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
85 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
