Hello and Welcome to FixYa!
E45 error message sometimes means that the lens is misaligned, This error is also may be due to failure of the control system.
To solve this follow the given solution:
You can remove
battery and card replace battery and while switching on tap the lens
hood on your hands so as to disengage any dirt or mechanism being
struck.
Use some air to blow between the lens to dislodge any sand
particles struck inside. If none of these works then you can think of
taking consensus with the service center. You must keep in mind that to open the camera without good experience is not recommended and might tamper the delicate unit so best option is to Contact
Kodak to see if your camera is still under warranty, otherwise contact
any Kodak Cameras service provider, your problem will be solved.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you for using FixYa!
The
bad news is that this error means the lens alignment of your camera is
messed up and it will take repair service to fix it. The cost of this
might be equivalent to replacing the camera.
kodak-easyshare-v570-error-e45-users-guide.
Hope helps.
