Question about Refrigerators
I have a proline model PL166GWA i have a bad smell coming from the back of the fridge.There is a small black tray at the back that looks like it is full of muck.I can not get the tray to come out,any ideas how to remove?
  • Anonymous Feb 28, 2009
    i hsvr the smae problem what can i do, the smell is rising above the air freshners
  • 3 Answers
The tray can be removed by easing up the front and then pulling out. Use fingers both sides of compressor to release the tray from a sticky pad that sticks to the top of the compressor. Once free from the sticky pad the tray can be pulled out horizontally.
Posted on Jul 23, 2010
Proline tall fridge. Got water at back of fridge
Hi... Yes you will have... normally the self-defrost fluids exits the fridge through a tube at the back of the fridge... you will see a drain hole if you look (this can get blocked and if so... water will come out via the door into a puddle) this tube drains into a sort of tray which sits on the hot compressor... where it is supposed to evaporate.
May 17, 2014 | Refrigerators
Drainhole gets blocked with ice proline fridge freezer
Sounds like the defrost cycle is too short! What is the make and model number?
Jul 10, 2013 | Refrigerators
How do I remove the plastic drip tray from behind my Wesitnghouse Aurora Fridge Freezer.
we had a really bad smell coming from the back of our westinghouse aurora. and yes found it to be emanating from drip tray at the back. To remove this we had to undo 4 clips at the base of black motor thingy, that the plastic drip box sits on. Then we were able to lift whole thing a bit ,(10mm up and 50mm out, approx) so we could tilt everything forward and sweeze and wiggle tray out. then cleaned with bleach. also we unblocked hole inside fridge that allows water to drip into drip tray at back.
Jun 01, 2011 | Westinghouse Refrigerators
There is a bad smell coming from the back of the fridge. The inside smells fine, the freezer does not smell either. It looks like there is some kind of tray inside the back of the fridge. Its is filled...
If you are referring to the drip pan that on the bottom of the fridge, that could be the source of your odor problem. Take the pan out and check to see what is in it. Normally there should only be just water that comes from the defrost cycle.
May 13, 2011 | Refrigerators
We have a Meile fridge freezer and the smell seems to be coming from the back (no smell inside)It has been a constant smell but occasionaly gets worse. It has taken us a week to find out that its coming...
Self de-frosting tray at the back of the fridge was full of old stagnent water. Removed tray cleaned out, flushed out the pipe from the inside of the fridge to the drip tray. No more smell.
Nov 02, 2009 | Refrigerators
Bad smell in tray at rear of fridge
maybe you could use a wet/dry shop vac to clean it out
Jul 30, 2009 | Refrigerators
Bosch classixx fridge freezer - smell coming from fridge. Can only smell when door opened.
bad eggs smell coming from behind Bosch fridge freezer. There is no bad food in fridge. Any comments appreciated. Linda
May 02, 2009 | Refrigerators
Bad smell coming from fridge
Unplug fridge. Remove the panel on the back of the fridge look for dead rodents or fungal growth in the drain pan. consult your local appliance parts distributor for a product called kleene air or try
Apr 01, 2009 | Refrigerators
Nasty smell in garage.....think its coming from refrigerator
It's either the drip tray which is removeable from the front, or, mice are playing in the drip tray under the compressor. Soak in up, rinse with some ammonia water & repeat a few times. Rinse well when done. Line up some sticky traps behind the fridge. The mice found a playground amd they will return.
Mar 07, 2009 | Frigidaire FRT15B3A Top Freezer...
Bad smell coming from back of fridge
The adhesive is a contact adhesive and gets soft from the heat of the compressor. The idea is that condensate drips from the in cabinet drain onto this drainpan. The drainpan then is heated by the compressor running and water evaporates. The drainpan can get yucky from dust and bugs collecting in it. Difficult to remove but not impossible, you just glue it back in place when you refit. It is usually glued in place at the time the compressor is fitted. Your best bet would be to clean it in place and spong up the liquid. I usually put in a quarter teaspoon of granular chlorine (pool) into the drainpan and this keeps things a bit cleaner.
Mar 02, 2009 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
294 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
