Question about Sony Handycam DCR-TRV38 Mini DV Digital Camcorder
Sony DCR-TRV38 - cannot burn movie to DVD
I'm trying to burn a 1 hour tape on my Sony Camcorder to DVD - I'm using the ImageMaker software that came with the camcorder and connecting my Camcorder to the computer using the USB port. The image capture always stops after about 10 minutes - it will go no farther. Looking at the Sony website (their support is AWFUL, BTW) there appears to be a 10 minute limit? That doesn't seem altogether helpful - how am I supposed to burn a 1 hour tape to DVD? Any advice is appreciated. I also have Sonic DVD Burner software, but it doesn't recognize a USB connection, only Firewire. I didn't think this would be so hard! Regards.
    Novelist:
  • 196 Answers
I found the best way of editing the footage from these cameras is to put the DVD disc into your computer and copy the contents of the VIDEO_TS folder onto another folder on your hard drive. The uses a video editing application which is specifically designed for the MPEG format. I would highly recommend the low cost "Womble MPEG Video Wizard" which is available for a 30 day trial at www.womble.com.
Posted on Feb 13, 2006
Burning video clips to DVD, gets to 53%, error cannot write disc
pls try to make a copy of dvd on hard disk folder when in the end it asks where to put the dvd after processing dont put it directly on the dvd first process and put it on hard disk folder and then burn it using any free tools or like nero burning rom or any other dvd burning software it sometimes happen when u try to put the movie directly to dvd during processing avoid this
pls let me know if i can help u more , i will suggest DVD movie Factory for video editing and dvd making it is paid service but it is easy and worth it
pls rat eme fixya if i have fixed ur problem
Jan 26, 2009 | Sony Handycam DCR-TRV265E Digital...
No picture seen or recorded - only audio
I had a similar problem with my Sony 14E in that it would not record at all - sound or pictures. Prior to that I had the lines indicating head cleaning necessary. I did this, and still nothing. I then did the following which you might try.
1. Clean the heads (I did it about 3 times in the space of a couple of hours).
2. Leave the camera tape section open (with or without the tape in) for a couple of hours and the camera in a WARM PLACE. I had condensation message prior to my problems too.
3. Put in a recorded tape and attempt to view it. Immediately I had the "dirty" lines for a few seconds then it played the recording.
AT THAT STAGE I TRIED TO RECORD - NOTHING.
Repeat Steps 1 - 3 because this seems to be about dirt and cold.
4. When step 3 is reached again! try to record. Eventually this worked for me.
I hope this helps and works for you.
Jan 03, 2009 | Sony Handycam DCR-TRV38 Mini DV Digital...
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Transfer video to computer (sony dcr-trv38)
I had a same issue but now I found one way using the fireware that comes with the DCR-TRV38. I tried on my windows XP service pack 2.
1. hook up the fireware cable both in sony and the computer. If your computer does not have fireware card, you need one.
2. switch the camera button from "off" to "camera"
3. after few seconds you will see new hardware found and will ready for use. you may also see pop up window to capture the video if you have Microsoft Windows Movie Maker (WMM).
4. open the editing s/w and capture the video. I used the WMM which gives many option to capture the video (ie:DV-AVI, high quality format and many more)
hope this helps.
BG
Aug 06, 2008 | Sony Handycam DCR-TRV38 Mini DV Digital...
Downloading
Sony has an S-cable for use with theit DVD 201. It works well with a Dazzle device.
Jul 13, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
Windows vista
windows vista is niet compatible met usb driver voor sony dcr-dvd201e.
image mixer heeft geen nut om media bestanden te importeren.
kijk eens op de sony site, hier wordt al over een oplossing gesproken.
Sep 15, 2007 | Sony Handycam DCR-DVD201E DVD Camcorder
Sony DCR TRV38
Good Day, you need to supply 4.5V DC regulated to the loading motor, however you should disconnect the connector from main board to loading motor, in order not to damage the driver IC. If your technically inclined, and you have the equipment, do it, if your not sure, just refer it to the nearest svc ctr. thanks
Sep 04, 2007 | Sony Handycam DCR-TRV38 Mini DV Digital...
Unable to play Audio after Video Capture
I happen to have this setup... you need to set the audio source (the usb camera connection.) It is possible to hook up via the sound card, but that could be stressful for some.
Sep 14, 2005 | Sony Handycam DCR-TRV38 Mini DV Digital...
Sony DCR-TRV38 Transfering video to dvd at a high quality.
Wait a second. You have a DVcam which is at that quality so how can you get to DVD quality? You may need a better camera!
Sep 13, 2005 | Sony Handycam DCR-TRV38 Mini DV Digital...
Sony Handycam DCR-TRV38 Mini DV Digital Camcorder Logo
101 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
