Question about Toshiba TDP-S8 Multimedia Projector
Won't turn on
Noticed that the fan was running. turned unit off. than tried to turn on, Turned on for 1or 2 seconds than turned off.
    Problem Solver:
  • 3 Answers
What worked to fix this projector when it wouldn't light..
Posted on Oct 26, 2008
My goodman condensing units fan won't start to turn on its own
Hello, usually this is a sign of a bad capacitor. Replace the capacitor.
May 21, 2012 | Heating & Cooling
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
Hi, I have a goldStar GA 1866VHR split Airconditioner, (5050w cooling and 5040w heating capacity). Today I noticed that compressor/condenser unit was still running after I turned off the aircond: from the...
Thanks for your detailed information. But solution is very simple. The compressor contactor in out door unit. Struck. And hence, when you power on, without indoor commanding, the out door starts running.
Replace same type Contactor relay (In out door unit) immediately. Hope, it's helpful.
Jan 19, 2011 | Heating & Cooling
My 1998 mercedes ml320 starts for 1or 2 seconds and then stalls.
You either have to replace the battery in your key fob or have it reprogrammed. Verify this by trying the second key, if you have it. AAA told me that you can reprogram it by leaving it in the ignition, with the key turned to the first position, overnight. I haven't tried it.
Nov 20, 2009 | 1998 Mercedes-Benz M-Class
Suddenly stopped cooling
Sounds to me like the run capacitor is bad. It is a dual one which means runs the fan and the compressor. No big deal capacitors are only 10 bucks and easy to replace.
First turn off the electricity to unit at breaker would be best. Next after you open the access panel locate the capacitor and make a note which wires go where one side is marked fan the other is herm. in the middle is comm. Take the old one in and get a new one same size and reinstall. Now parts only have one year warranty but they should have a discount on a person that bought a unit from them if you talk to them and tell them how can this happen only 2 years old. you know the story they might just throw one in for free to keep good business practice. Let me know how it goes. ken
Apr 16, 2009 | Intertherm P3RA-060K Air Conditioner
Cooling fan on Philips DVDR3576 runs on when the unit off?
I noticed the same thing on mine. I determined that the unit turns on the fan AND Hard Drive during the period of 11:59 to 12:00 BOTH AM and PM and continues to run until the unit is cycled on and off either with remote or by a program. I used a stethoscope to listen to the Hard Drive humming inside; when the unit is cycled off I could hear the Hard Drive shut down, and a second or 2 later, the fan shuts off. I had purchased several other new units thinking I would return the "defective" one. Testing them, (by setting the clock to 11:57 and wait) both other 2 units did the exact same thing. So I assume that's a software "oops" on probably all units.
My "solution" is to set up "dummy programs" to record for 1 minute after those time periods: like 12:03 to 12:04 AM and PM on a daily schedule, and I pick a channel I usually don't record. The 00:01:00 recording time and "special" channel number make it easy to quickly identify the unwanted "dummy programs" and I use the "multiple title delete" feature to periodically delete them.
So I accumulate 2 titles per day, but I prefer that to having the hard drive run all the time.
Incidentally, I talked to a sevice rep at Philips, and the only thing they could offer is to set up a return for refund. The Philips 3576H is, in my opinion, a fantastic unit and I think the little glitch is well worth the benefits of the features it provides. How did I ever live without it???
Mar 25, 2009 | Philips DVDR3576H DVD Recorder
Runs -6far. for about 2 weeks, then alarm sounds, unit is warm.
its the problem of the motor which runs the fan.that motor needs replacement.a very chance it can be possible that the motor is perfect but the wirings from the motor which connects to the fan are faulty and got cut in between.but it can be possible.so first check out the wirings if they r perfect then its faulty fan  motor.get it replaced. thanks.
Feb 10, 2009 | Kenmore Freezers
Toshiba TDP-S8 Multimedia Projector Logo
1,095 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
