Question about E-Machines eMachines Desktop PC
Emachines when I boot up my computer the Emachines logo appears, fan turns on and does not boot.
    Scholar:
  • 152 Answers
Hi Che,
There are a variety of issues regarding a computer not booting up. There are hardware and software issues associated with it. You can approach the problem through the following steps:
1. Clean your unit with a soft brush, avoiding too much pressure applied to the sensitive components. See if the cards inside your computer are free of dust. Brush off dust from the cards and your mainboard.
2. You may remove the cards (video card, memory modules, sound card, LAN card, etc.) from their slots and reinsert them. Interfacing parts tend to be clogged with dirt through time. Just make sure you have removed static electrical charges in your body by placing your hands on the sides of your CPU. Hold the cards by their edges.
3. Make sure that all connections are firmly plugged.
If this doesn't work, you can try booting your computer using a bootable disc (such as those used in installing OS) and choose repair. When the c: prompt appears, type scandisk (for Windows 98) or chkdsk (for Windows XP). Once it's done, this should repair boot problem.
Posted on Sep 02, 2008
I bought a used emachine laptop and want to know how reboot to factory setting
As soon as you see the eMachines logo appear on the monitor screen, press the "left-Alt" and "F10" keys simultaneously. Wait a few seconds for the Windows boot screen to appear, then press the "Enter" key. Click the "Restore Operating System to Factory Defaults" option after the eRecovery Management window appears. This is the default for most eMachines. If this doesn't help please let me know the exact model number and I will check if there is a different method than the one I wrote. Good Luck.
Oct 14, 2017 | Computers & Internet
How do i change boot order on emachine t3604
You will need to change the boot order in the bios set-up.
Turn your computer off, and turn it n again (alternatively Restart it) These things may be initiated by clicking the Windows button at the bottom left of tour screen, and from the shut down drop down menu selecting the appropriate option) As your computer is starting up, and the Emachines logo appears on the screen
"Press the "Tab" key repetitatively: If that fails to take you into the BIOSsetup, repeat and try either the "Escape," "Delete," or "F2" keys instead of the Tab key.
Once in the BIOS setu[p, Look through the options until see Boot order, and then change that to CD first, HD 2nd. Exit the BIOS setup with save changes option. Done.
19.February.2015
Feb 19, 2015 | eMachines T3604 PC Desktop
How do you remove case on emachine T5048
1) Close out any open applications and restart the computer.
2) As the machine boots up (at the eMachines logo), press F2 (to enter the BIOS).
3) Once you are in the BIOS, navigate (use the keyboard directional arrows) to the Exit Tab.
4) Under the Exit Tab, choose "Load Optimal Defaults". When you are asked to confirm, select "Y" (for "yes").
5) Save the changes and Exit the BIOS.
6) No more loud fan!! Awesome!
Sep 24, 2013 | E-Machines eMachines Desktop PC
Default boot order for emachine laptop 732
Step 1:
All computer systems go through a set of instructions called the Basic Input/Output System (BIOS) when they are turned on. The BIOS checks all of the hardware and software installed on the computer to make sure they are working properly before loading the operating system. You may need to access the BIOS menu periodically to find out the current version of the BIOS you have if there are upgrades available. The command you use to access the BIOS settings on an Emachines computer will vary depending on the specific model you have.
Access the Start menu and click "Shut Down." Select the "Restart" option. Wait for the Emachines logo to appear on the screen as the computer begins booting up again. Press the "Tab" key when the logo appears and see if the computer switches to the BIOS menu. Press the "Escape," "Delete," or "F2" keys if the "Tab" key doesn't take you to the BIOS menu screen. Use the right arrow key to highlight the "Main" entry and press Enter. Scroll down to the heading labeled "BIOS version." Check the long string of numbers and letters under the "BIOS version" heading to locate the current BIOS version your Emachines is using. Press the "F10" key to exit the BIOS menu screen and finish booting up the computer's operating system.
Access/Enter Motherboard BIOS http://michaelstevenstech.com/bios_manufacturer.htm
Feb 22, 2013 | eMachines Computers & Internet
Im using a emachines T3646 computer,only pwrled and 1syst fan wrk
Yes. Got RAM? The heatsink fan? How about a video card, and all the 12V (4 to 6 pin) connectors? All plugged in suitably?
May 02, 2010 | eMachines T3646 Refurbished AMD Desktop...
Emachine
The power supply is probably faulty. You'll need to replace it, and go from there.
Keep in mind to make sure you UNPLUG everything and let it drain for at least a full minute before you touch it..unless you want the shock of your life.
Sep 02, 2008 | E-Machines eMachines Desktop PC
System Recovery message appearing during boot up for no apparent reason
The change would be in your bios i believe. are you comfortable with working in there ?
Robert
Aug 20, 2008 | E-Machines eMachines Desktop PC
Only getting EMachines/Windows XP Logo when boot up T3882
you have not set the cdrom as first boot device in the bios (press F2 or Del on boot up to get in bios), choose cd as first boot device, save settings and restart the pc with your cd in the drive and then when prompted press enter
Aug 18, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
76 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
