Question about Sony Handycam DCR-PC100 Mini DV Digital Camcorder
Sony DCR-PC100 Camcorder
I can't turn on my camera anymore. The batteries won't even charge and the camera won't run on AC power. Also the zoom lense inside rocks back and forth when I move the camera. Both problems occured at the same time. Any help? Thanks a lot.
    Master:
  • 473 Answers
Sounds like it was dropped. Repair often exceeds replacement cost...
Posted on Sep 13, 2005
My sony handycam DCR-TRV340E is not charging at all, dont know if its to do with the battery or the AC power adaptor
First, check that the camera switch is in the off (charging) position.
If this is OK, Check the battery output connections for voltage: use a multimeter.
To check the charger, put a load resistor across the output terminals (about 1000 ti 2000 ohms) and again, using a multimeter, check there is a charging voltage. Alternatively, if the camera operates OK with the charger attached and switched on the charger is OK, AND, the problem is then in the charging circuit from camera to battery. If the battery checks OK as in the beginning, then you will need a Sony repair man who needs to know all the results from your testing above.
May 27, 2014 | Sony Handycam DCR-TRV340E Digital...
Sony DCR-dvd403 will not work on battery power anymore. Only on AC power
Maybe you need a new battery: if does it turn on when is plugged only the battery and it will stay on for only a bit or when you try to record it turns off the problem is only of the exhausted battery.
Jul 30, 2011 | Sony Handycam DCR-DVD403 DVD Camcorder
Do you need a working battery to run camcorder off ac power adapter? I havent used camera in 2 years and just bought replaceable power adapter and wont charge battery or work off outlet at all..camera was...
You do not need a battery to run the camcorder off ac power supply. It is one or the other. The only time that both will be used is when you are charging the battery on the camcorder with the power off.
Hope this helps.
www.austintelstarservices.com
Jul 21, 2011 | Sony DCR-HC52E Mini DV Camcorder
My camera wont charge in the tray or the charge light won't come on. Camera keeps saying low battery.
My guess is that with the age of the battery it isn't able to hold a charge anymore which means you'll need to purchase a new battery. Your best bet for that will be to go through Sony or the website Dr. Battery.
May 11, 2011 | Sony DCR-HC52E Mini DV Camcorder
Sony DCR-HC28E Camcorder tape won't eject
I\'ve got a Sony DCR-HC28E Camcorder power switch off position but it's turn on automatic when I put power AC adaptor in DC inlet and battery not charg
Dec 29, 2009 | Sony DCR-HC28E Camcorder
Sony DCR- DVD108 switches off automatically while recording
Follow this procedure to troubleshoot if the camcorder turns off by itself.
  1. Remove the battery from the camcorder.
  2. Connect the AC power adapter to the camcorder.
  3. Plug the AC power adapter into a working electrical outlet.
  4. Attempt to turn on the camcorder.
  5. Reset the camcorder back to factory settings.
  6. NOTES:
    • If the camcorder does not operate using the AC adapter, service may be required .
    • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
  7. Ensure the battery has been fully charged.
  8. Ensure the battery is properly inserted into the camcorder.
  9. Remove the AC power adapter from the camcorder.
  10. Attempt to turn on the camcorder.
  11. NOTES:
    • If the camcorder does not turn on, then the battery may need to be replaced.
    • If the problem persists using a different battery, service may be required .
Aug 13, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
My Sony Handycam DCR-HC30E mini DV is not working
In many cases I found DC Jack defective in this model and resulted does not charge battery through ac charger nor power up directly with ac charger.
I would suggest to check ac charger and battery on similar model Sony camcorder and I think your camcorder has DC jack problem thats why camera is not getting power from ac charger.
Jan 08, 2009 | Sony Handycam DCR-HC30E Mini DV Digital...
DCR-SR42 Camcorder does not power up
I think AC power charger of your camera got defective first and later on battery lost its charge so no power for camera now to power up.
Try to borrow same charged battery from friend. neighbors etc and test your camera.
If camera power up, it is sure that charger has gone and you need new one.
let me know in that case to guide you further.
Oct 05, 2008 | Sony Handycam DCR-SR42 Camcorder
Sony Handycam DCR-PC100 Mini DV Digital Camcorder Logo
158 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
