Question about GE Security Simon 3 Wireless Home Security System
Disarm door chime - GE Security Simon 3 Wireless Home Security System
    Master:
  • 397 Answers
According to my manual.
>Turn Chime Doors on:
1. System must be disarmed. Press Chime Doors button.
panel will announce,"Chimes On". Chime Doors button will be lit.
> Turn Chime Doors off:
1. Press Chime Doors button.
panel will announce, "Chime off". Chime Doors button no longer lit.
Posted on Sep 02, 2008
  • jenigunderso
    jenigunderso Sep 07, 2012
    Where is the "Chimes Door Button"?
Ihave a 1998 Buick Century, removed drivers seat to convert to RHD for mail carrier,now seat belt chimes all the time, need to be able to unhook chime?
Under the dash on the left hand side but if there was a wire plug on old seat buckle should be able to loop circuit together so acts like seat belt is always hooked
Apr 29, 2016 | 1998 Buick Century
How do you reset the alarm system on a 98 olds silhouette after it triggers without the remote entry
Theft Deterrent Arm/Disarm Modes
Important: Although mode 2 provides increased security, the content theft deterrent system disarms only by pressing unlock on the keyless entry transmitter. This can pose a problem if the keyless entry transmitter is damaged, lost, or inoperative for any reason while you attempt to disarm the content theft deterrent system.
Mode 1: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter. The system does not arm when you lock the doors with a power door lock switch.
Mode 2: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the doors with the keyless entry transmitter. The system does not disarm when you unlock the doors with the key.
Mode 3: The system arms when you lock the doors using a power door lock switch or the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter.
Changing the Feature Customization Modes
  1. Turn off the IP dimmer switch.
  2. Turn the ignition switch to the LOCK position.
  3. Remove the BCM PRGRM fuse.
  4. Turn the ignition switch to the ACC position. The BCM flashes the fasten belts indicator and sounds the chime 4 times, which indicates that BCM type 4 is installed on the vehicle. At this point, the BCM has entered the feature customization mode.
  5. In order to change the theft deterrent/shock sensor mode, turn the headlamp switch from OFF to PARK and back to OFF.
  6. The BCM flashes the fasten belts indicator and sounds the chime a number of times equivalent to the theft deterrent/shock sensor mode. A transition past mode 4 repeats the sequence starting with mode 1.
  7. Complete the following steps in order to change the theft deterrent arm/disarm mode:
6.1.
Insert the key in the left front, right front, or liftgate door lock cylinder.
6.2.
Rotate the key from the center to the unlock position.
6.3.
Press the horn button on the remote keyless entry transmitter.
6.4.
Count the number of chimes that you hear. The number of chimes tells you which mode you have set.
6.5.
Press the horn button again in order to change the mode. Continue to press the button until you hear the number of chimes that indicates the mode that you want.
6.6.
Turn the key back to the center position and remove the key from the door key cylinder.
In order to exit and save the current feature customization modes use the following procedure:
  1. Turn the ignition switch to the LOCK position.
  2. Reinstall the BCM PRGRM fuse.
If you are unable to change locking modes Theft Deterrent System Feature Customization Inoperative
Aug 25, 2015 | Cars & Trucks
How can I turn off chimes?
Read your manual; I do not provide any info regarding alarm system disarming questions etc...
Jun 06, 2015 | DSC Rf5501-433 Powerseries Wireless...
How do i disarm warning chime on 1998 GMC Sonoma
Worn out key cylinder or ignition switch. Cant tell when key is off. There is a wire which as you put in the key it makes contact as the the key pushes this metal contact up. You can unplug it. It should be a blue wire you should be able to see once you remove the covers of the colomn.
Jan 19, 2015 | 1998 GMC Sonoma
How do I turn off my 2001 sante fe hyundai chimes box it wont shut off
Each door on your car has contacts on door and on door post. Clean these contacts on all four doors. Any cleaner will due with a scuff pad. These contacts get dirty just from age. I think you can do it. Please let me know what happens. GOOD LUCK FRIEND.
Nov 15, 2014 | 2001 Hyundai Santa Fe
DSE wireless security alarm and door chime L7246...how do I program a number to arm and disarm it...I have no instruction manual, thanks
Hi. The default code is usually 0 0 0.
To Program a new code
Enter 000 and press the "PROG" button
Enter your new code (between 1 and 6 digits long) and press the "PROG" button again. The unit should beep twice to confirm that the new code has been stored
Nov 09, 2011 | Cars & Trucks
I think i have a vista keypad. I dont have a manual that shows the keypad features. I like for the doors to chime when opened. They stopped chiming for some reason. can this be reset.
On a vista system, enter your 4 digit code and press the 9 button. The keypad should read: Disarmed Chime. The keypad should ding ding ding when a door is opened. To turn the chime off, enter you code and press the 9 button again.
Jun 18, 2011 | Honeywell 6160 Vista Custom Alpha Keypad
Door chime will not shut off, is there a fuse to disarm the chime?
Should be one in tne fuse box ( it looks like a minaturized speaker). remove it and do a continuty and resistance check on It with a digital Voltmeter. if shorted, replace it. If not then your door switches is not turning it off. Check the door switches for shorts and opens. Good luck
Mar 08, 2010 | 1995 Jeep Grand Cherokee
Goes off even when disarmed!
This is from page 19 of the Simon3 manual found here:
http://www.safemart.com/manuals/simon3.pdf
It appears you have the "CHIME on Motion" enabled. Follow the Option 41 steps to disable it.
Option 41 - Voice Chime
The panel will verbally announce which chime sensor has been tripped if the chime
feature is on.
Add enables chime voice.
1. Open panel cover. Panel announces, Use numbered keys to enter ID.
2. Enter Access Code using the numbered keys. Panel announces, Please select from
Start Menu.
3. Press Add from the Start menu. Panel announces, Select from main menu
4. Press Option #. Panel announces, Option 1, press again for next option or done to
select.
5. Press 41. Panel announces, Option 41, press again for next option or done to
select
6. Press DONE. Panel announces, Option 41 is on.
Delete disables chime voice. The panel will not announce which chime sensor has
been tripped but will still chime 2 times for doors and 3 times for motion sensors when
a given sensor is tripped.
Start Menu.
3. Press Delete from the Start menu. Panel announces, Select from main menu
select.
delete
6. Press DONE. Panel announces, Option 41 deleted.
Dec 26, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
1,331 people viewed this question
Top GE Home Security Experts
Sean
Grantec 2000
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a GE Home Security Expert? Answer questions, earn points and help others
