Question about Apple Canon BJC 55 InkJet Printer
Won't print I put new ink in the printer but it will not print on the paper. It pulls the paper through fine but leaves a blank sheet. Canon BJC-55
    Problem Solver:
  • 18 Answers
If your ink tanks are good, reset the EEProm:
Power off the printer.
Unplug it, then plug it back in.
Wait until it stops its initialization sequence.
Press and hold the power button.
Allow the printer to beep 7 times, then release the power button.
This will reset the EEProm to factory default, and should clear your problem.
Posted on Aug 20, 2009
BJC-85 Not printing. New BC-10 and BCI-10. Paper loads normally
The problem you are having is with the print head and not the printer. Unfortunately, with these canon print heads, they are not dated, so it is possible to install a print head that was bought new and sealed, but is still dried out because it is old.
Try running the print head through one deep cleaning cycle, this sometimes will start to get an old print head flowing.
Deep cleaning cycle can be found by going to PRINTERS , right clicking on the BJC icon, selecting PROPERTIES from the drop down menu, and then selecting the MAINTAINENCE tab.
Check to make sure that the ink tank in the print head isn't dry. Even a new print head can have a dry tank if it's old.
Jan 10, 2010 | Canon BJC-85 InkJet Printer
When i print the ink is so light it looks like a blank sheet
get some paper towels and boil some water put in in an old coffee cup. hold the ink cartridges over the water (not in) the steam will clean out the nozzles on the cartridges. the ink will run a lil bit (hence the paper towels) give the printing a go again.
hope this helps..
Nov 10, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon BJC 4400 won't put ink on the paper
You need a new printhead, BC-21E, they wear out and plug with ink and the only repair is to replace the printhead.
Sep 16, 2009 | Canon BJC 4400 InkJet Printer
Canon BJC 80 prints blank pages!!
i think u already solved your problem...your printer's problem is its printer head...u cannot solve this problem by fixing it yourself.all u can do is to buy new printer head at printer's shop. it is true because i got the same problem with my BJC 200.i do the same solution as u r and lastly, i go to the technician and he said i need to replace my printer head at some price.....just think bout money n i discover that buy a new one is better(as for my problem)
not to discourage u, but try to plan either to buy new printer head or buy a new printer....
hope this solution help... ; )
May 26, 2009 | Canon BJC 80 InkJet Printer
Can I use only a black BJ cartridge on a Canon 620 printer?
Nope. You can use Cyan, Magenta and Yellow as well as Black.
Specifications (BJC 620):
  • Form Factor: Desktop
  • Connectivity Technology: Cable
  • Language Simulation: EPSON LQ • IBM Proprinter X24E
  • Media Type: Coated Paper • Envelopes • Glossy Paper • Labels • Photo Paper • Plain Paper • Transparencies
  • Max Media Size: A4 (210 x 297 mm) • Legal (216 x 356 mm, 8.5 x 14")
  • Total Media Capacity: 100 Sheets
  • Media Path Type: Straight
  • Operating System: Microsoft Windows 3.x
  • Product ID: 20152942
  • Exterior Color: White Product Description for Canon BJC 620 (From the Manufacturer, Canon)
    Simply a piece of printing marvel, with high definition printing, superior ink technology, innovative waste-free ink system and user-friendly Windows printing system. The BJC-620, simply a must buy for those who seriously considers printing in superior, high quality color. It comes with an Internet kit.
    This printer model is not being manufactured by Canon any more
    Related links for Canon BJC 620:
    Canon BJC 620 printer ink cartridges at PrintCountry.com
    Canon.com's site
    Canon printer ink cartridges
    Canon BJC 620 Driver
  • Apr 18, 2009 | Canon BJC 6200 / CanoScan N650U InkJet...
    Canon BJC-2110 Printer
    Try cleaning the nozzle using the software that came with the printer, if it's been a while since you have printed, try cleaning the head with a cotton swab and some isopropyl alcohol.
    Aug 25, 2008 | Canon BJC 2100 InkJet Printer
    Canon bjc-85 printer doesn't print anymore
    Have you tried changing the green carrier? That solved my problems with no ink.
    Dec 04, 2007 | Canon BJC 85 InkJet Printer
    No Print
    remove the cartridge and set it on an alcohol-soaked paper towel in the kitchen sink for about 15 minutes. If the towel has not begun to draw ink out, then tap cartridge firmly against your other hand which is holding the towel. if still none, then try heating the alcohol to about 150 degrees and repeat. if still nothing, then ink is either spent or cartridge head is dried up. take it to cartridge world (or similar outlet store) and they can get a cheap replacement.
    May 31, 2007 | Canon BJC 3010 InkJet Printer
    Canon bjc-80 - no print appears but cartridge & paper move normally
    I had this problem too. It turned out there was old dry ink in there clogging up the printerhead and it was fixed after I ran the cleaning programme several times. However I can't for the lifeof me remember how to do that now. I know I found it online but it has since vanished. Maybe check your manual?
    Nov 12, 2006 | Canon BJC 80 InkJet Printer
    Apple Canon BJC 55 InkJet Printer Logo
    292 people viewed this question
    Top Apple Office Equipment & Supplies Experts
    jasbo
    jasbo
    Don  Farrell
    Don Farrell
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
